Question about Freezers
Whirlpool s20brsb21-a/g not getting cold
Every thing working but not freezing or getting cold in the fridge
  • plong59 Jan 07, 2009
    compressor starts and gets warm after a while but still not getting cold in fridge or freezer
  • plong59 Jan 08, 2009
    tried switching off for five mins even been off for two weeks but still not getting cold at all in fact seems to get warm if any thing
  • Freezers Master
  • 4,806 Answers
Hi there
If the compressors working fine then you will have to take a look at the thermostat that regulates the temerature,
Good luck
Posted on Jan 08, 2009
  • Freezers Master
  • 3,463 Answers
If it is running continuously, and not freezing in either compartment, then it could be the compressor not pumping due to internal malfunction of compressor,or there could be blockage in the system.
Another possibility is shortage of refrigerant due to an internal leak , thereby losing it's gas charge.
A clue to it being short of gas is to listen carefully in the frig compartment, and see if you can hear it hissing, if you can then it is short of gas.
If the coils are wet and dripping water, then again, probably short of gas.
Depending on age of appliance, then it could have thermistors that control the temp, as opposed to a conventional thermostat, this being the case, then there is usually more than one fitted.
You really need an experienced refrigeration engineer to check it for you.
Plz rate my soluion.
Thanks.
Posted on Jan 07, 2009
    Genius:
  • 1,239 Answers
Hi IF THE FREEZER IS AUTO DEFROST, DO YOU SEE A FROST BUILDUP ON THE BACK WALL? IF SO, YOU NEED TO DIAGNOSE THE DEFROST FAILURE. THERE ARE THREE ITEMS TO THE DEFROST CIRCUIT. THE TIMER, HEATER, AND BI-METAL. FIND THE TIMER, USUALLY ON THE BACK OF THE FREEZER DOWN IN THE CORNER NEAR THE COMPRESSOR. IT WILL HAVE A CONNECTOR WITH FOUR WIRES ATTACHED TO IT. IT HAS A KNOB THAT CAN BE TURNED TO PUT IT INTO A DEFROST CYCLE. WITH THE FREEZER RUNNING, START TURNING THE KNOB UNTIL THE COMPRESSOR STOPS. THAT WILL BE THE DEFROST CYCLE. THEN WAIT 5 MINUTES AND LISTEN IN THE FREEZER FOR A SIZZLING NOISE AND LOOK FOR A GLOWING FROM THE BACK BOTTOM. IF THE HEATER IS ON, THE TIMER IS THE PROBLEM. IF THE HEATER IS NOT ON, THE HEATER OR BI-METAL IS AT FAULT.
IF THE FREEZER IS NOT AUTO DEFROSTING, CHECK TO SEE IF THE COMPRESSOR IS RUNNING. IF IT IS, ARE THE SHELVES ALL FROSTED? IF NOT, YOU HAVE A SYSTEM FAILURE. IT COULD BE A LEAK, RESTRICTION, OR FAILED COMPRESSOR.
  • 716 Answers
Do You Hear The Fan Running In The Freezer?
    Novelist:
  • 123 Answers
Something aint working ...lol most likely the thermostat failed.
  • 3,037 Answers
Hi plong59
First defrost the Fridge overnight, then make sure there is air flow from the vents at the back and that air is actually coming from the vents, if not, then you need to replace the fan. I assume, the compressor is working and the coils are cold. Is this correct?
bestdarngood
    Scholar:
  • 76 Answers
You have of course set the temperature to "cold"
Try unplugging it and waiting 5 minutes and plugging it back in.
You may have a failed compressor after all
Let me know if this helped
    Genius:
  • 1,011 Answers
Sir,
First and easiest thing to check is defrost timer. Look for defrost timer, probably be a black box about 2" square, have 2-4 wires to it and be held in place with two small screws. You will know it when you see it. It will have a hole in center of box in which will be the end of a shaft. Shaft will have a slot for screwdriver. Slot will be such that you can only turn it clockwise. Turn about 1/4 turn. Should feel clicking. If this solves problem temporarily replace defrost timer. Available at most appliance parts stores. Defrost timer most likely in compressor compartment but can be anywhere. Some models in the past have combined with ice maker motor.
click this link for more info.
Posted on Dec 24, 2008
  • Asfiya Ahamed
    Asfiya Ahamed Jan 08, 2009
    Is there any clicking noise near the compressor? A lot of frost or ice build up on the inside rear wall of the freezer?
    also click this
  • 15,935 Answers
Compressor has failed.
Freezer not working but fridge works
It uses the same compressor for both. One of two things, the opening that is allowing cold air in the freezer , is closed or the freon is leaking out and it will be soon before the fridge is not working.
Feb 21, 2013 | Whirlpool Freezers
Our chest freezer isn't keeping food on top frozen although the bottom is still frozen solid?
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this help in solving the problem....
Jan 11, 2011 | Freezers
How long should it take for a 18 cu ft. chest type deep freeze to get cold?
From room temperature if just plugged in rule of thumb is 24hrs to properly reach temp. Place a glass half full of water in shelf when is frozen solid the unit should be plenty cold enough to keep food. It is always a good idea to get a small fridge thermometer to make sure of temp.
Oct 26, 2010 | Whirlpool Freezers
Frosting up badly despite having just been defrosted
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for cold control and air deflector As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout.....
Aug 08, 2010 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
Whirlpool ED25RFXRWFreezer/Fridge temps unstable...either too hot
check the defrost timer but the cold control could be bad
Mar 01, 2010 | Whirlpool Freezers
I have a servis fridg freezer and the fridge is
sounds like the thermostat has packed in, it works as a switch for the compressor (which will be constantly on) if its a conventional model and should be replaced. if its a frost free it will be a control module thats faulty.
never work on a live appliance and get expert advice if you are at all unsure when replacing parts as if not isolated properly you will give yourself a nasty shock.
Jul 22, 2009 | Freezers
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Whirlpool sidexside m-gd25dq does not cool properly
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 15, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer not working
sounds like a cold control problem
Dec 17, 2007 | Freezers
Freezers Logo
508 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
