Question about HP DeskJet 1220c InkJet Printer
I can't know when my cartridges are empty screen messages : Impossible de fournir l'?tat de l'imprimante usb (Impossible to get the printer state) Information sur la cartouche : L'imprimante est ?teinte ou elle ne peut fonctionner qu'en mode unidirectionnel (Cartridge information : The printer is off or it can only work in unidirectional mode)
  • cjab Apr 28, 2009
    My HP1220C will not show as it used to with the bidirectional printing mode. I am using vista 64 bit with SP1.I cannot communicate with the printer.
  • 944 Answers
Here is the link to the user manual in french; http://h20000.www2.hp.com/bc/docs/support/SupportManual/bpd07922/bpd07922.pdf or here in english; http://h20000.www2.hp.com/bc/docs/support/SupportManual/bpd07920/bpd07920.pdf The solution to the unidirectional issue depends if you have the printer connected in parallel or by USB. In USB connection the printer can be set to bi-directional mode in the "ports" tab of the printer properties, assuming that the USB is setup correctly. In parallel mode this option is not available to change. On some other HP models, there are a bank of DIP switches inside that allow uni/bi-directional switching, but i found no info detailing these for this model, so i suspect it is only possible with the software. Hope this helps :)
Posted on Apr 13, 2007
How do i fix cartridges error
It's almost impossible to give you a sensible answer Larry as you have not indicated any details - nor even the model or make of the printer. For example, is the message about any of the cartridges being empty? What make of printer? What model? What operating system? Is it USB connected or WiFi? Come back with a better set of information and I will do my best to help.
Jan 06, 2015 | Office Equipment & Supplies
Je viens de recevoir mon imprimante MG 6150 et lors de la mise sous tension, le message suivant apparait: 6A81 printer error has occurred. Turn off power then back on again. If problem persists, see the...
Bonjour nduvignac
J' essayerais de d?sinstaller puis de r?installer le pilote . D?branche l' imprimante pour ces op?rations , relance ton pc apr?s installation et reconnecte l' imprimante . Si le probl?me persiste , il faut retourner chez le vendeur avec l' appareil et le ticket de caisse .
Cordialement ,
fanaudi .
Jun 30, 2011 | Canon MG6150 Printer
J'ai une imprimante epson TM-U200PD et n'est pas reconnu dans windows, j'ai achete le cable pour transfert en usb et n'est pas reconnu que dois-je faire
Vous devez aller ? www.epson.com et choisissez votre pays, puis vous choisissez de soutien et de recherche pour votre imprimante. T?l?charger le pilote pour votre imprimante, et l'installer.
Jun 06, 2011 | Office Equipment & Supplies
Is there somebody speaking french ?
Oui je parle francais, quel est ta question?
Feb 15, 2011 | Office Equipment & Supplies
Dando erro de SERVICE FUSOR ERROR
S'il vous plaît essayez d'éteindre l'imprimante pendant au moins 30 secondes.
Assurez-vous que l'imprimante est connectée à la prise d'alimentation correcte. Vérifier l'étiquette énergie sur le dos de l'imprimante pour voir si elle fonctionne sur une source 110 ou 220 volts. Vérifiez que la prise d'alimentation correspond à sa tension nominale de travail
Pour plus d'assistance s'il vous plaît contactez le support technique de Lexmark.
Jan 06, 2011 | Lexmark X642e All-In-One Laser Printer
Pas de contacte entre mon ordinateur
Je suis d?sol?, veux-tu dire que l'ordinateur ne peut pas d?tecter l'imprimante?
1. Assurez-vous que vos pilotes d'imprimante sont install?s.
2. Cliquez sur D?marrer-> Panneau de configuration, et d'ouvrir le Gestionnaire de p?riph?riques Syst?me->.
3. Assurez-vous que l'imprimante est connect?e ? l'ordinateur, et qu'il est branch? sur une prise murale qui fonctionne. Allumez-le.
4. Gestionnaire de p?riph?riques Watch, pour voir si elle change / ajoute votre nouvelle imprimante. Si c'est le cas, faites attention ? l'indicateur de p?riph?riques (si l'?l?ment est un code de couleur jaune), et un clic droit sur elle-> choisissez Propri?t?s pour v?rifier l'?tat du p?riph?rique. Il devrait vous donner de plus amples informations s'il ya des probl?mes.
5. Si le Gestionnaire de p?riph?riques ne d?tecte pas l'imprimante, essayez un autre c?ble USB. Si ce c?ble ne fonctionne pas, vous devrez contacter le fabricant de votre imprimante pour le service, que l'imprimante peut ?tre bris?e.
Dec 28, 2010 | Dell 926 All-In-One InkJet Printer
Possible to speak with somebody in French??? My printer is now isntalled on a IMAC. I see it. Ican give the command to print through that printer. It goes as far as I can see the doc in the task, but...
no expert is employed by Fixya, we just use the site to help people, as far as i know in the years i have used this site there are not any French speaking experts, most all of us are in the USA.
Mar 06, 2010 | Office Equipment & Supplies
HP DeskJet 1220c InkJet Printer Logo
190 people viewed this question
Clive
Clive
