Question about HP Media Center m7060n PC Desktop
Unable to boot up in normal mode
I have recovered using low grade formating but it is not fixed
  • 15,935 Answers
Startup in safe mode then start-run- type MSCONFIG and uncheck every program slated to startup.
Posted on Dec 24, 2008
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
How to repair corrupt emails in MS Outlook 2010 ?
Hi
You can do this using inbox repair tool or scanpst.exe provided by Microsoft free of cost. If this tool is unable to repair PST file then you can use any third party tool like SysTools Outlook PST Repair tool or PCVITA PST Repair tool.
Aug 12, 2014 | Microsoft Outlook 2010 - Windows
Low format
You probably have a messed up partition table. You can download the hiren boot cd and use the linux rescue environment. Once loaded use Gparted to create a new partition table and format the drive. If that doesn't work there is a low level format tool under the first menu on the hiren disc
Apr 30, 2013 | Samsung Computers & Internet
Forgot password, need to reset
You can reset any user password by logging in using the Administrator account through Safe Mode. In Windows XP Home you cannot log into the Administrator account in normal mode.
When your computer is starting up, hold down the F8 key. This will bring you to a black screen with white text. Use the arrow keys to highlight "Safe Mode" and then hit enter. This will boot the computer into Safe Mode, which will look normal except the resolution will be very low. Log in as the Administrator (should have a blank password). Once logged in, open the Control Panel, then User accounts, then reset the password or whatever user you want. Reboot the machine to get back into normal mode.
Jan 20, 2010 | Dell Microsoft Windows XP Home Edition
Why is my acer starting up repeatedly? It goes to the screen where i highlight the windows to start normally but it keeps shutting down and returning back to the same screen.
Try something else but start normally.
Start in safe mode (Press F8 right after boot) then reboot.
Start in the last good configuration.
If none works reinstall the system.
Change Boot sequence in BIOS to CD-HDD.
Insert Installation CD in CD-Rom drive
Choose install.
Choose C; partition
Choose Format (do not do a quick format). Any formatting will erase all on the Hard Drive.
Complete installation and reboot.
There is something else you could do before resorting to a reinstallation, and that is to use The Recover Console. You acces it when setup asks wether you want to reinstall, or repair. If you answer Repair you boot into the recovery console.
But before using it you should query Microsoft knowledge base about Recovery Console, and know exactly what should do.
Hope it helps.
Sep 06, 2009 | Computers & Internet
Everytime i turn-on my laptop, it abruptly shut down and back to normal like a blink while initializing to start.
It is normal for the screen to go blank while a PC is starting up. Maybe if you could explain in detail what you're seeing it would help us to help you...
Sep 03, 2009 | Computers & Internet
Have HP DV 9540 us laptop. Yhe motherboard took a dump. I can read hard drive on another computer. Can I recover my verisoft passwords for my websites?
Passwords are encryped, the chances are slim to recover except by booting the system on the hard drive and logging in. Boot in safe mode so that windows won't try installing drivers for the host system. If you try to boot in normal it is going to complain, but safe mode should let you in to recover the passwords. If you have the drive connected through USB with adaptor, use the boot options (usually F-12 on recent stuff) to boot from the usb drive.and F-8 before the Windows logo appears to get into safe mode.
Hope this does it for you.
Jul 16, 2009 | HP Computers & Internet
No Operating System; Cannot Format User Partition - Gateway MX595
It seems that you have a corrupt user partition on your drive which is stopping you from doing a recovery.
What you will need to do is delete the partition(s) on your Gateway by using a system repair utility CD. ERD Commander 2005 or Bart are utilites that will allow you to boot from a CD and then delete the partitions.
You could also use a friend's Windows XP CD just to delete the partitions.
Once this is done, you should be able to re-install your OS (assuming there is no physical damage on the hard disk.
Hope this helps.
Mar 25, 2009 | Gateway MX6956 Notebook
Windows recovery problems
If you still have the recovery discs available then press F11 or F12 depending on which one is the boot menu and boot from the CD and reinstall Vista from it onth the hard drive.
Apr 18, 2008 | Acer Aspire 5520-5908 Notebook
HP Media Center m7060n PC Desktop Logo
41 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
