Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
I cant use the printer
Hi,printhead missing,not insalled correcly or hass come looose install prinhead and printcartridges alreadyinstalled.remove ink cartridges and printhead,then reinstall
    Sergeant:
    Champion:
  • 304 Answers
may i know the exact model of your printer,.
and also did you already change the print head.?
Posted on Dec 24, 2008
0xc18a0206 error
ink system prime failure- the printer is no klonger able to hold pressure in the ink tubes- suggest you replace ALL PRINTHEADS in one go ( the problem may lie in just one printhead or the tubes themselves
If the prinhead replacemnet doesnt wotk then a new set of ink tubes and heads will be needed- this costs about the same as three new c6180 printers and is not worth the money- sorry for thew bad news
Jan 20, 2014 | HP Photosmart C6180 All-In-One InkJet...
My printer keeps saying that the prinhead is missing and need to be installed, I took it out and installed it again and it keeps saying the same thing
it could be more serious, but I would put in the printhead and then unplug the printer and then wait a few seconds and plug it back in. it might clear the code. otherwise it might be your print head bad.
good luck
Jan 09, 2012 | Kodak ESP 5 Printer
Canon S520 Printer won't print black!
Hi.
Remove Black cartridge,
make sure its not dry, if that's ok make sure that the small air vent is not blocked (hard to find sometimes)
Dec 30, 2017 | Canon S520 InkJet Printer
Printing pink
My printer keeps telling me my printhead has come looose or is not properly installed to remove and reinstall the print head and the ink jets. I have done this three time. It is tight and properly installed. Now What?
May 04, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Plotter HP1050C asking to change Black Printhead over and over...Installed two new ones and still asks to replace printhead??? SteveO
remove the printhead turn the machine off.using a damp cloth clean the electrical contacts on the back of the prinhead and also the contacts on the machine(where the head is installed)
Feb 11, 2010 | HP DesignJet 1050c InkJet Printer
We have installed new inkjet cartridges for the inkjet 1200 printer, however there is no inkflow on the paper when printing documents. Please advise on what to do
Sounds like you need to replace the printheads. The business inkjet printers have seperate ink and prinheads. In home use printer models the printer cartridge is all in one with ink and printhead in one unit.
Oct 03, 2009 | HP Business InkJet 1200D Printer
Print quality
CHECK INK LEVELS RUN DIAGS AND IF YOU NEED A NEW PRINTHEAD TRY THIS;
try try again..........
I had this problem;
Printhead replacement instructions are in the users guide.
THIS WORKED FOR ME --AND IF YOU CALL THE TECH SUPPORT # KODAK WILL SEND YOU A REPLACEMENT HEAD........
Power on printer, the printhead rides on a carriage that is connected to the ribbon cable. When the printhead is in the center position and movement is stopped REMOVE THE INK CARRIAGES. DO NOT TOUCH THE INK-PADS OR THE CONNECTION POINTS. You can just place the ink carriages on their side on a clean piece of paper.
......... To separate the printhead from the carriage press the release botton(above the bulls-eye sticker) in the top center of the printhead. You will hear a click and the top of the prinhead will pop forward about 1/4 of an inch. GENTLY lift from back (where you pressed the botton) to front and lift the printhead up and out of the printer.
---------U will see where the printhead and the carriage connect-------
It is best (very important) to not touch the shiny contact area
Now you are ready to install your new printhead.
BE CAREFUL BE GENTLE............Place the new printhead into the carriage and again at the center top back bulls-eye press back until you hear the click and the printhesd is secured in the carriage.......... replace the ink carriages.......
I would power off the printer and wait about 60 seconds then power on and run self test.
TO RUN SELF TEST
power on the printer and wait until the printhead is in the center position THEN press photo and copy buttons at the same time, you will hear the printhead carriage start to move and a test print page will print.
CHECK for print quailty; run all diag. from the help tab as needed.
REMEMBER; IF YOU THINK THE PLASTIC WILL CRACK U ARE PRESSING TOO HARD....... KEEP IT CLEAN, BE SAFE
Jan 01, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error message re printhead.
To resolve the error condition:
  1. Open the printer access door.
  2. Remove the color and black ink cartridges.
  3. Remove, then reinstall the printhead
To reinstall printhead follow the link.
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Nov 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak all in one printer instalation error codes
Unfortunately, the only way to possible fix this error is to get the printhead out and reseat it. You can do that by removing the ink cartridges. Right above where the black ink cartridge was, at the top left hand corner of the printhead, if you push up towards the ceiling there should be a button that releases the printhead. You should now be able to tilt the printhead forward and pull it out of the printer. Reseat the printhead by putting it back in the printer and pushing straight back on the back wall of the printhead. It should snap into place. Replace the ink cartridges and close the printer. If the error clears, download the newest firmware from kodak.com so this never happens again.
If these steps do not clear the error however, call Kodak AiO tech support at 1800 421 6699 to get a new printhead.
Jul 20, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
18 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
