Question about Saeco Odea Giro Plus Coffee Maker
How can we clean our saeco pot.
We are snowed in , how can we clean our coffee maker vinegar? if not why, we need help.
  • 333 Answers
White vinegar will work well. After you run the vinegar through, run about 2 pot of water through it to rinse. This should do the trick.
Posted on Dec 24, 2008
Hi guys I have saeco idea and it says maintenance caf any got idea what that is , thanks.
It probably needs a cleaning. Run 1 pot of white vinegar through it just like where you fill it with water. But do not use any water. Then run 2 full pots of water through it to clean out the vinegar. Warning do put cold water into a hot glass pot or it could break. If it has a filter for the water, change it with a new one.
Jun 09, 2014 | Coffee Makers & Espresso Machines
How to decalcify
Make a solution of ½ pot vinegar and ½ pot water.
Run a cycle thru the machine. If there is a cleaning function on the coffee maker, use that.
If very calcified, run a newly made solution thru again.
Rinse by cycling fresh, plain water thru, 2 times.
Jun 16, 2013 | Saeco INCANTO DELUXE Espresso Machine
How can I descaling my Saeco Odea Giro? What can I use to do it if in my country I don't find the descaling solution?
50/50 solution vinegar 50% filtered water and 50% vinegar. fill reservoir with this solution as if you were making a pot of coffee. Run 2 or 3 pots fresh filtered water thru unit to clear out vinegar taste.
Feb 20, 2013 | Saeco Odea Giro Espresso Maker -...
My coffee pot is black inside & using vinegar does not clean it
Use a coffee pot cleaner such as Dip-IT. Walmart sells a product in the coffee maker area that is for cleaning the coffee maker. It cleans the coffee pots too.
Feb 24, 2011 | Cuisinart DTC-975 Coffee Maker
What can I clean my Bunn proffessional coffee maker with ?
mcdevito75 here, Contact Bunn for their recommended cleaning material for your coffee maker, or see any large store that carries coffee makers for their cleaning kits.
Jul 11, 2010 | Bunn VPR Coffee Maker
I put in 12 cups of water and only 4 cups come out with coffee what is wrong with this. It is only one month old
This occurs occasionally if the unit needs cleaning or you are brewing a new pot of coffee immediately after emptying a hot pot of coffee.
Run a cup of vinegar through the coffee maker twice, run at least 2 pots of clean water through to rinse the vinegar out.
This should clear the problem until it needs cleaning. The suggested frequency of cleaning is every 30 pots, but this varies depending upon the type of water you use.
Nov 16, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
It appears to need a cleaning for the water processes slowly to the drip basket. It worked faster last year. I keep all of the equipment clean. We love our machine!
Run a mix of 50% WHITE vinegar and 50% water through the machineWait about 5 minutes and run a couple pots of plain water to rinse it out. The vinegar will dissolve the buildup in the tubes and ports. If you don't get it all out, it's totally harmless, unlike the chemical cleaners.
Nov 06, 2009 | Saeco Renaissance XX Coffee Maker
Self cleaning the quisinart coffee maker
I always use a mixture of 50:50 of cold water and white vinegar to help clean the internal parts of any minerals and scaling.
Unplug the coffee maker first, then add the water/vinegar mix to the reservoir.
Place a new, clean paper filter in the basket to help catch any deposits that will be dislodged and cleaned from the coffee maker.
As far as having the coffee pot dry, there is no need for that. I do tend to wait about 15 minutes to let the cleaning mixture disolve any deposits in the main water reservoir and then I turn on the coffee maker and let it process the water/vinegar solution through it.
Once it's done, turn off the coffee maker and discard the solution in the pot. And rinse out the coffee pot/carafe with clean, fresh cold water. Remove and throw away the used paper filter element andrinse out the basket with warm water and put it back on the unit.
Now fill the coffee pot/carafe with fresh, clean water and pour that into the coffee maker's water reservoir. Put in a new, clean, paper filter and turn the unit on and run a plain pot of water. This will help to clean out any remaining residue and clear the unit of the vinegar taste and odor.
Now you're all set to start making fresh tasting coffee again. I always recommend using filtered water for the best tasting coffee, as the taste is a direct result of brewing temperature, water purity, and the coffee you use.
Hope you find this Very Helpful and best regards!
Sep 22, 2009 | Cuisinart DCC-1200 Coffee Maker
My coffee maker works very slowly after about three weeks of use. Specifically, the water does not pass through the filter and into the pot quickly, if at all. Suggestions?
Try cleaning it with white vinegar. Put in one cup with a potful of water, and let it soak. To get more cleaning, pour the water/vinegar through again, hot. Put in a coffee filter to catch/strain the debris, and you will be able to see if it's helping. When you're through cleaning, pass fresh water through the machine by potfuls, until no traces of vinegar can be detected.
Best regards, --W/D--
Aug 15, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee has a greasy taste
You will need to pull you coffee maker out and take the top off and clean inside the water tank. Someone has put coffee from pot of old cold pot of coffee back threw. or something loke this. just clean inside and out. clean coffee maker and pots. hope this helps
Have a cup on old saw
Aug 09, 2009 | Bunn VPR Coffee Maker
Saeco Odea Giro Plus Coffee Maker Logo
206 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
