ChannelReceiver/tape playerModel 2350, with the number 56150529.
I do not have a manual for this product and therefore am having difficulties setting up the channels to run with a channel/film commanding item. Could you please let me know if we can get the manual from you. Thank you, Pastor Bill Styles
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 94 Answers
Google the model for a manual.Have you tried contacting the manufacturer?
Posted on Feb 08, 2018
sandrew
  • 2961 Answers
SOURCE: dont seem to be able to install channells in
Auto installation should search for local tv stations, or add new channels, then it will search for new ones.
Posted on Feb 20, 2007
  • 236 Answers
SOURCE: Channel set
Apparently your TV is set to the "standard TV" position. Before you auto program your set, set it to the cable mode and then do the autoprogramming. In the standard TV setting, you just get off the air channels 2-13 vhf and 14-83 uhf.where as in the cable mode you get vhf channels 2-13 plus your cable channels. Stargazer
Posted on Mar 17, 2007
SOURCE: INPUTING CHANNELL ON REMOTE
using the meniu of tv select fine tuninig end memoreyschen
Posted on Apr 22, 2007
  • 125 Answers
SOURCE: Quasar VV-2001 TV/VCR combo - msg: Check Antenna Cable Connection
Check first the antenna using another TV. If there is no other TV available, check using an ohmeter. If you are 100% sure tha the antenna is ok then the antenna connector on your Tv is not making a good connection to the antenna plug.
Posted on May 24, 2007
BMW Rider
  • 232 Answers
SOURCE: TV. dpops channes
Bill, your set has a bad tuner, only fix for that is to R & R the tuner, 2nd option would be to use your vcrs tuner input and then RCA out cables from vct to input on back of tv, If you have never done this re-post and I`ll walk you through it, let me know, BMW Rider
Posted on Dec 05, 2007
Samsung retune
Hi, Try this go to menue on tv run the channel scan function.
If you are using a PVR or Tivo do the same with that, But you will have to set your TV to channel 3 to get your PVR/Tivo going. or in some TVs TV1 or TV2...depending how you hooked it up.or if you have HDMI cable... Good luck
Feb 11, 2014 | Televison & Video
How do I program a Midland GXT760VP4
After installing and charging the battery pack (or installing alkaline batteries), turn on the radio by turning . Then press Menu once to set your Channel. Press Menu additional times to set other features. To set the channel to listen to Weather Radio, continue pressing Menu to the Weather Channel sub-menu (Channel 1 is 162.400 MHz). If you press and hold Menu for more than 5 seconds with the radio in GMRS mode, the radio will scan all 10 weather radio channels.
Midland has the manuals to many of their products here: http://www.midlandradio.com/Two-Way-Owner-Manual . The direct link to the manual is http://www.midlandradio.com/Resource_/OwnerManual/201/GXT760%20Owner%27s%20Manual%20.pdf .
Please let me know if there is a specific item you want to set up on the GXT760VP4.
Nov 18, 2011 | Midland Radio Communications
I bought a FERGUSON F20320DTR Digital TV Recorder At first I really liked the product but when I changed my TV from a really old one to a new LG 37LD450 I started to lose channels. At first I was unable...
If you are in an area that is being switched over from analogue to digitial you might lose channels to do with that. Another reason could be the leads between the TV and Aerial connections. Make certain that they have good connections and use proper screened cables. Some people also have several transmitters around them, some of which have weaker signals than others. Some channels will therefore not appear. Check the box is tuning into the strongest signals.
If you manual retune then find out the frequencies of the strongest transmitter in your area first and set it on them.
Aug 23, 2011 | Televison & Video
Finally bought anRCA antenna for my new Dynex TV.Nothing no signal,no way to scan for channels I can see.AGGH.Is it a lemon?
Which Dynex TV do you have? The manuals for most Dynex TVs are available from the product page. Start at http://www.dynexproducts.com/products/televisions.html . If you have an older Dynex that isn't on the main list, check under Discontinued Products. Alternatively search for your model. Then click on the Support tab to find the manual for that model.
For at least one Dynex TV (DX-32L152A11), the procedure to scan for channels is below.
To scan for channels, first make sure that the current input is set to TV. (Press the input button on the TV or the remote). Then press Menu and use the left/right arrows to select TV. Then press Enter or down arrow (the manual says the right arrow). Use the up/down arrows to select the entry to change. First, make sure that the Tuner Mode (first item) is set to Air (use the left/right arrows to change this). Press Menu to go back to the TV menu. Then go down to Channel Scan and press Enter. You may need to confirm the channel scan and press Enter again. Wait for the scan to be completed.
On a discontinued model (DX-32L151A11), the procedure is slightly different. With the input set to TV, press Menu. Select the Channel submenu and press Enter or down arrow. Set the TV mode to Antenna (use the left/right arrows to change the value). Then press the up/down arrows to reach AutoScan. Press Enter. Move cursor to highlight Yes and press Enter again. Wait for the scan to be completed.
I hope this helps.
(There were some Dynex monitors built. They usually do not have a coaxial antenna in port since they didn't have tuners.)
Jul 29, 2011 | Olevia LT32HVE 32 in. LCD Television
I have microsoft office97 with a 11 digit key code my computer want a 25 digit code?
Follow the steps below to locate your Microsoft Office 97 product key code.
Difficulty: Easy Time Required: Finding your Microsoft Office 97 product key usually takes less than 15 minutes Here's How:
  1. Manually locating the Microsoft Office 97 product key from the registry is nearly impossible due to the fact that it's encrypted. Luckily, a number of free programs exist to help find product keys.
  2. Choose a free product key finder program that supports Microsoft Office 97.
    Note: Any product key finder that locates Microsoft Office 97 product keys will locate the product keys for any edition you may have including Microsoft Office 97 Professional, Small Business (Versions 1 and 2), and Standard.
  3. Download and run the key finder program. Follow any instructions provided by the software.
  4. The numbers and letters displayed by the program represent the Microsoft Office 97 product key. The product key should be formatted like xxx-xxxxxxx - one set of three numbers and one set of seven numbers.
  5. Write this key code down exactly as the key finder program displays it to you for use when reinstalling Microsoft Office 97.
    Note: If even one number is written down incorrectly, the installation of Microsoft Office 97 that you attempt with this product key will fail. Be sure to transcribe the product key exactly like its shown in the key finder program.
Dec 11, 2010 | Microsoft Computers & Internet
Need a copy of manual
You can get the manual on the link below.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et8215c%20-%20english.ashx
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 25, 2010 | Intermatic ET8215C- 7-Day Electronic...
Need to know how to set up the program.
Jasco carries wide number of GE products, including timers
GE timer manuals can be found at:
http://www.jascoproducts.com/support/manual-downloads/index.asp
Your manual: GE 15079 manual
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/GE-15042-15079-15089.pdf
There are a number of programming options that are too long to list here. Read manual. If you run into difficulties, re-post a specific question.
Sep 23, 2010 | Jasco 15079 SevenDay TwoOutlet Digital...
I tried to set up a password with my wireless 2350 broadband router and now its saying that the settings don't match my network.. i need help
Change your wireless settings on your computer. Use the router's password. that way you will be able to gain access to your router. when you changed the settings on your router it does not automatically update your computer's connection settings. you have to manually change it. try right clicking the icon for your wireless on your computer. go to the connection settings and add a password that corresponds to the settings you changed on your router.
Mar 11, 2010 | Dell Wireless 2350 Router
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
