Question about Roxio Creator 2011
Unable to load skin in Roxio Creator 2011
Error mesage comes up when i click on create DVD
SOURCE: Can't install Roxio Creator 2009
There is a patch from Roxio to resolve this error!
http://kb.roxio.com/content//kb/Creator/000217CR
Deadog4201
Posted on Feb 24, 2009
  • 70 Answers
SOURCE: roxio creator has problem and will shutdown
If you haven't already, you might want to uninstall then reinstall the program. Sometimes a program will seem to install correctly when it hasn't or, become corrupt over time. If you do this and continue to experience the same issues with the program then you may need to move onto troubleshoot the issue further.
Posted on Mar 25, 2009
  • 1341 Answers
SOURCE: I re-install roxio creator 9, after install
Windows7 is still being developed and as far as I know it has some compatibility issue with many hardware etc..Check compatibility with manufacture before you look any further.
Posted on Jul 02, 2009
venkatesanr2
  • 101 Answers
SOURCE: I cannot load my roxio creator basics v9 DVD
check the sound card cable.check whether if it is inserted properly
Posted on Sep 18, 2009
warlock13
  • 100 Answers
SOURCE: Create DVD's gets no permissions error
Go to your control panel and to your accounts. Look at your account on the computer, make sure your account is administrator and not limited account. as a limited account, you generally have few application permissions if not leave a comment that it is still having issues and i shall do some research >.<
Posted on Feb 25, 2010
How do I burn multiple slide shows to DVD using Roxio 2011
Create the multiple slide shows and store them in a directory that you have created on your hard disk just for those slide shows. When all the slide shows are present in that directory, start Roxio, use the Add Files function and go to that directory and select all of the files you want on the DVD. Name the DVD to something that indicates what is on it and start the Create/Burn to make your DVD.
Feb 07, 2017 | Roxio Computers & Internet
Creator 2011 says it is not combatible with Windows System 7 Home Premium and will not install.
Based on the Microsoft Website
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Search.aspx?l=en-us&type=Software&s=roxio%20creator%202011
Roxio Creator Pro 2011 is compatible with windows 7 so all you need to do is call Roxio and check if there is a discount for the Pro version since you already have the Creator 2011 and upgrade to Roxio Creator Pro 2011.
You can call this number: 877-793-7471 (North America only)
Mar 25, 2011 | Roxio Creator 2011
Recently bought & installed Roxio 2011 on Windows XP and it worked fine. Upgraded laptop to Windows 7. Roxio stopped working. Uninstalled all Roxio programs and reinstalled Roxio Creator 2011. No...
If you are getting the error at startup, roxio service might not started or disabled. What you can try to do is to enable all roxio service. refer to the steps below.
- click start > run - type services.msc - look for all roxio service i.e roxwatch.db - double click it then select the startup type to automatic - save the changes then restart computer
Cheers . . .
Feb 02, 2011 | Roxio Creator 2011
Cant load roxio 2011 code error oood plaese tell me what to do its been 6hrs now cleaned everything please please
Please refer to the steps below and follow it carefully as it will help you resolving the problem.
  1. Disable your startup applications using MSCONFIG. This will disable any unnecessary background or system tray applications from loading.
    • Go to Start -> Run. Type "msconfig" (without quotes) then click OK.
    • Select the Startup tab.
    • Click the Disable All button.
    • Click the Apply button, then click the OK button.
    • Click the Restart button.
    To reverse this at the end of installation, go back into MSCONFIG and select Enable All and restart (that can be done once installation is complete).
  2. If you are installing from a physical disc, please try to copy the content of the disc to a folder on your hard drive then install from the hard drive. To do this:
    • Create a new folder on your Desktop.
    • Go to Start -> My Computer, then right-click on the Creator installer disc and select Explore.
    • Select ALL of the files in the installer window and copy to the folder you just created.
    • To install from the folder, double click the setup.exe file.
  3. If you are installing from downloaded files, please follow the steps below to delete the temporary files then try to reinstall again.
    • Go to Start -> Run. Type "%temp%" (without quotes) then click OK. The Temp folder will show up.
    • Go to Edit -> Select All.
    • Go to File -> Delete.
    • Reinstall software
Jan 06, 2011 | Roxio Creator 2011
Unable to install roxio 2011
Instead, access: http://www.MajorGeeks.com and search for 'AShampoo Burning 6'.
This is _FREE_ software for creating/burning CD/DVD/BluRay disks.
Free!
Dec 20, 2010 | Roxio Creator 2011
Error loading skin on roxio 10- everything else works but making dvd
This error is usually caused by corrupted MSXSL 4.0 files. Download and install the latest XML 4.0 update from Microsoft. Please refer to the link below:
http://www.microsoft.com/downloads/details.aspx?FamilyID=7F6C0CB4-7A5E-4790-A7CF-9E139E6819C0&displaylang=en
Cheers . . .
May 21, 2010 | Roxio Easy Media Creator 10 Suite
Roxio 9 compatibility with windows 7
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Apr 04, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
Cannot Initialize API
1. Try to launch Creator Classic to see if it can repair the engine files. a. Double click on the "Roxio Easy Media Creator Home" icon. b. Click "Creator Classic" under the "Applications" section. c. The Windows installer should launch and ask you to insert your installation disc
Try this and see how it works, if it does not, contact me and give me more details
Mar 25, 2008 | Roxio Easy CD & DVD Creator 6...
DVD RW - Installation Problem
Ok. What I am going to suggest may seem like a daunting task but if you are careful and do only what I suggest you should be ok. The first thing you are going to have to do is manually make a change to the Windows registry to fix the permissions. 1. Fix registry permissions a. Click on "Start" choose "Run", then type "regedit" and click "OK". b. In the Registry Editor, click on the "+" next to "HKEY_Local_Machine". c. Now click on the "+" next to "Software". d. Right-click on the key (folder) called "Roxio" and choose "Permissions". e. Make sure that "Administrators" and "System" have checkmarks for "Full Control" - "Allow". f. If you had to add those checkmarks, click on "Apply". g. Click on "Advanced". h. Put a checkmark in "Replace permission entries on all child objects with the entries shown here that apply to child objects". i. Click "OK". j. Click "OK" again. k. Now close the Registry Editor Next, you will have to uninstall the Roxio software. 1. Remove Roxio Easy Media Creator 7 a. Go to Start--->Settings--->Control Panel--->Add/Remove Programs b. Select Roxio Easy Media Creator 7 and select "Remove" c. Once the uninstall is complete, reboot the computer. 2. Reinstall Roxio Easy Media Creator 7 a. Insert the CD and install as you did before and then reboot. If you have any issues uninstalling the Roxio, go to the following link to download the Microsoft Cleanup Utility... http://support.microsoft.com/kb/290301 Run the utility after the unistallation attempt and then reboot and reinstall Roxio. Hope this helps. Good luck.
Jun 19, 2007 | LaCie 8x DVD+/-RW USB 2.0 External Dual...
Roxio Creator 2011 Logo
205 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
