No matter what setting, light level, program setting; AE or manual aperture setting on any lens, the lever in the camera itself (the one to the right as you look at the front) stays high up. this means the aperture is always wide open. have checked looking straight through the camera from behind and the aperture does not stop down when the shutter is released. so a bit stuck. any help would be appreciated.
On a film camera, the internel electronics determine the shutter speed and aperture. The camera computer figures out a higher shutter speed against the aperture speed. You have a lever on your lens that, when mounted on the camera, will keep the aperture open until you fire. That allows viewing in the brightest light. Then that aperture arm is allowed to close to what the exposure setting the camera determines when you click the shutter. You should be able to take off the lens and easily move the aperture arm and have it snap closed. If it takes a few seconds to close.. then the lens has oil on the aperture blades or the grease inside the lens is bad. These days, unless is it a very expensive lens it's replacement time. Canon lenses will fit any Canon (except Fd) film or digital camera.
SOURCE: Automatic aperture setting on canon FD lenses not working on AE-1
You have a case of AE(auto exposure) Unit faulty or getting bad. It suppose to register as it move within the AE unit according to the exposure calculation but somehow it is broken. Technician usualy replace the AE unit and takes care of the problem. It can also be rebuilt if new parts are not available. This requires complete disassembly and mirror box removal. The average cost of repair probably runs around $100. Yes, "A" mode is correct for most of the shots and it was a state of art electronic system and more computerized than you think. It has 3 IC chips in there for precessing and 1 chip for the exposure. All works together for good. -James
