Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Microphone not working
In volume function i not work with volume but work with wave [for up down the volume]
    Sergeant:
  • 366 Answers
Right click on Systray Speaker icon.
"Open Volume control"
Do you see Microphone column? Be sure is NOT muted.
If you do NOT see it: Option / Properties check if sound device is the correct one (if you have multiple),
Set Playback and mark the control to show (including Mike)
You can now see and tune your Micro volume.
Same process for recording devices: set Recording etc..
Posted on Dec 29, 2008
1. no volume control for microphone sound 2. no windows sound wave
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
click start control panel sounds and audio devices you can adjust the volume there also select recording or playback you should find something there
hope this helps
Apr 30, 2011 | Computers & Internet
I have a Frontech E-cam JIL 2221 webcam and have installed driver as specified. Still the microphone (inbuilt in webcam) is not functioning. How to make it work and check its functionality?
hope this helps
don
Feb 20, 2011 | Computers & Internet
How to unmute laptop sounds. Its mute and i am not able to unmute it?
  1. Click START
  2. click CONTROL PANEL
  3. click SOUNDS and AUDIO DEVICES
  4. Look at the box labelled SOUND RECORDING - if the DEFAULT DEVICE is listed as WAVE DEVICE (may have some letters and or numbers in front of the words WAVE DEVICE - they are only the name of the device) go to step 6 otherwise click the little downward arrow at the right hand end of the DEFAULT DEVICE box. Scroll down the pop-up list to WAVE DEVICE and click on it.
  5. click VOLUME in the SOUND RECORDING box
  6. A window will open entitled 'Recording Control'
  7. Put a tick (check-mark) in the little white box under the heading of MICROPHONE and make sure the Volume slider is at the top of the scale.
  8. Close the window to go back to the Sounds and Audio Devices Properties Window.
  9. If you also want to hear what you are saying into the microphone over your own loud-speakers / headphones click on the VOLUME button in the SOUND PLAYBACK box.
  10. A VOLUME CONTROL window will open. If MICROPHONE is in the list of sound sources go to step 11 otherwise click OPTION on the tool-bar at the top right of the VOLUME CONTROL window. Then click PROPERTIES. With a little green dot in the PLAYBACK box look where it says 'Show the following volume controls' - place a check-mark against microphone and then click OK
  11. In the VOLUME CONTROL window remove any check-mark from the MUTE box under the MICROPHONE heading and also make sure that the MUTE ALL box (bottom left) is also un-checked.
  12. Close the VOLUME CONTROL window. Press OK to close the Sounds and Audio Devices window and exit CONTROL PANEL
  13. That should be it but if you are using MSN Messenger / Skype or other similar program you will need to start that program and click on the TOOLS button followed by SOUNDS and TEST AUDIO - follow screen prompts thereafter.
Jan 30, 2011 | Toshiba (P000257700) Microphone
My laptop is compaq presario cq40. my microphone is not working but i can hear the voice of the person on the other side
Firstly please check that you have pugged the microphone into the correct (red) socket.
If that is correct the problem is likely to be in the audio settings. You don't specify which operating system you are using. My answer is for Microsoft Windows XP but Vista and Windows7 will be broadly similar.
  1. Click 'start' or go to 'my computer'
  2. click on 'control panel'
  3. click 'sounds and audio devices'
  4. click 'advanced' button in the 'device volume' box. This should open a long window of audio volume controls.
  5. On the tool bar click 'options'
  6. click 'properties'
  7. There is a drop down menu with the label 'Mixer Device' - click the down arrow at the right hand end of this menu. If there is more than one device listed select 'wave device' from the list.
  8. Further down the properties window there are 2 options 'Playback' and 'Recording'. Click on 'Playback'and then look at the list of devices in the box labeled 'show the following volume controls'
  9. Make sure that there is a tick (check-mark) against microphone.
  10. click ok
  11. Now look at the devices listed in the long window of 'volume controls' make sure that there is NOT a tick (check-mark) in the 'mute' box against microphone and that the volume slider is up at or near the top of the scale.
  12. Make sure that the 'mute all' box (far left) is not checked
  13. click on the 'options' tab on the tool bar once more
  14. Click on 'Recording' and repeat steps 9 to 12
Your microphone should now be working but I assume, from your question. that you are trying to use Voice over Internet Protocol / Skype / Messenger or other chat program. If so you will now need to go into the appropriate program and test the audio properties. Exactly how you do this will vary with each different program but most have a fairly simple test wizard. With Skype the easiest way is to select the test call button.
Jan 28, 2011 | Compaq PC Microphone (Black or Beige)...
I cannot get the volume to go up or down...it is stuck at one level. I have just replaced the battery, and all other functions work fine. The remote is about 2yrs old.
If you have other (Universal) remotes in your home try programming one of them to operate your Bose.I have a different Bose system for my TV and can operate the on/off and volume from my universal remote. The code I use is 440, I show another code of 302 that may work.
Nov 28, 2010 | Bose Wave Music System Remote
I just bought a new gigaware earclip monoheadset with mic. the problum is i cant seem to get the mic working the sound works great but i just cant get that voice to work
Hello Mithmar hi, try setting the volume for your microphone, (i'm assuming you are using X P) to do this right click the speaker icon (or the mixer icon) on the lower right side of your screen, you will go to the volume controls section, goto options, then properties, select recording. check the microphone, then click apply/ok. On the mixer there is now the microphone slider. Test your microphone by loading the sound recorder program (start, all programs, accessories, entertainment, sound recorder, press the red button) then shout to the microphone, you should see wave patterns on the recorder, your microphone is working fine. at this point let me know your progress.
Oct 09, 2010 | Audio Players & Recorders
The person I am speaking with does not hear me. The microphone function does not appear to be working. I have adjusted the volume and that's not the problem. I have plugged both jacks (microphone and...
The person I am speaking with does not hear me (He is deaf).
The microphone function does not appear to be working. I have adjusted the volume and that's not the problem (You must speak as well).
I have plugged both jacks (microphone and speaker) into my PC hard drive and am using my PC to talk on Skype (You cant plug even a single jack in the hard drive).
Problem solved!
Apr 14, 2010 | Logitech (980361-0403) Headphones
My internal microphone doesn't work
If you are refering to the internal microphone on your computer then try this. Open up your windows sound recorder from Start - Program - Accesories - Entertainment. Hit the record button and talk or yell something if you would like. You should see recorded sound waves in the middle of your sound recorder. If you do not see the recorded waves this might mean that your microphone is turned off. To turn it on just Double click on the little speaker icon on your taskbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure the microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder and try to record again. If this does not work your internal microphone may not be working or your computer may not have come with a built in microphone.There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
Mar 17, 2009 | Audio Players & Recorders
Microphone is muted
per page 10 of the manual, start a call then press up / down buttons to control mic volume. good luck
Feb 05, 2009 | Panasonic KX-TG1100 Cordless Phone
Microphone does not work
try to download sigmatel audio at dell support
Dec 04, 2007 | Dell Latitude D600 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
43 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
