Question about Toshiba 57HC85 57" Television
I have a 57HC85 with a bad Green CRT tube
Had a repair man out yesterday and he tried to adjust, however when he turned the TV off then back on it aooears to have "burnt a hole in the tube" I would like to replace the tube myself but I can't find anywhere any kind of instructions. Can you please help?
Thank You,
Aaron
  • aaronworkman Dec 24, 2008
    I have been to the Toshiba web site and there is not any instructions....I am hoping someone can tell me how?
    Genius:
  • 1,011 Answers
Sir,
click this link for instructions
thanks
good luck
Posted on Dec 24, 2008
  • 15,935 Answers
    Brigadier General:
  • 3,614 Answers
It's better to wait your repair guy be back, it is dangerous for you to work on that if you have no idea how to troubleshoot or experience servicing a tv
  • 92 Answers
I would go to the website of the people who made the tv or go to a sears or best buy
Turns on for 30 sec then goes bright blue and goes back into standby. turn back on it does it agian
This is blue CRT problem in tv as it is rear projection tv that has three CRTs red-green-blue inside to project color picture on front screen.
Blue CRT (tube) will be replaced to fix the issue and it is job of Pro because lots of adjustments are required after replacement of tube.
Local tv repair shop will help you for that.
Thanks
Oct 02, 2010 | Sony KP-51WS500 51" Rear Projection...
D52W20BYX1 Green problem
I would go back to green tube disconnect ,unplug CRT board to green tube if set stays up playing its the tube.
Sep 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cathode ray tubes (crt) for a Sony Rear Projection TV Model# KP-65WV600.
We have a problem with the blue as well. Sometimes it is good, then it fades to green. Then it went out and back on again. Repair man said it is a bad HT Block and would cost $350 to remedy.
Mar 13, 2008 | Vizio GV42L 42 in. LCD Television
Sony Trinitron KV-32XBR37
This may be a bad crt or picture tube. Take a good look at the picture when it's on and see if it has a pinkish or greenish tint. This is easiest to see if you turn the color adjustment all the way down. If it looks like the tint is green or pink and the focus isn't great then it's probably a bad crt. Not worth repairing if its the tube.
Jan 04, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Green Screen
Your picture tube is bad,pull back off/ unplug crt broad on neck of tube make sure it does not touch anything ,turn set back on if set stays on tube is shorted!
Dec 18, 2007 | GE 13R100T 13" TV
My TV has blue lines,flashes then turns off
Bad blue CRT common problem.....................T.
Nov 09, 2007 | Sony KP-51HW40 51" Rear Projection...
Bad picture color. red LED blinks 5 times. Replace picture tube?
Definitely bad picture tube==not worth fixing......T.
Oct 11, 2007 | Sony KV-36FS16 36" TV
Green s
check for bad solders on the crt socket . If it turns off again try running the tv with the crt socket off the tube but 1st try to time how it takes for the tv to turn off then disconnect the crt socket. If it does not turn off the tube may be bad, if it does not turn off check the voltages at the crt socket and see if all the voltages at the colour outputs are close to the same, if so then you have a bad tube when you connect the tube and the voltages change conciderably the tube is gone
Mar 08, 2007 | Toshiba 32A42 32" TV
Green Picture with 40H80?
This is a CRT type projection TV set. You could have a bad green picture tube, a bad connection on one or more of the picture tube sockets and or driver boards, or there is a RGB driver problem in the video jungle IC or the output driver transistors. If you have had any experience with solid state TV repair, there should be no problem figuring out whats not or is working in this set. If you have not had any experience, there is alot of high voltage on these picture tube sockets, and one wrong move and you will get a perm of a lifetime. That voltage hits you so hard, I have seen it make a grown man cry. Play it safe and call in a pro to assist you in this repair. Good Luck PS Please do not forget to rate this thread.
Dec 11, 2006 | Toshiba 40H80 40" Rear Projection...
Lamp issues
No its a tube and not a bulb. If thew line is green then theres an issue with the red and blue as the green is stationary on most sets unless thers a green centering ? Its a componet on the convergence board thats bad or going bad but if you replace any components on the board most likly your gonna need to do a convergence alighnment I would let a pro handle this repair unless your an experineced repair tech Good Luck
May 21, 2006 | JVC AV-56WP30 56" Rear Projection...
Toshiba 57HC85 57" Television Logo
158 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
