posted by nmort90 on Apr 13, 2007
The Cd player at times does not read cds that it has played in the past the display flashes no disk........ i can open the tray and sometimes it will play sometimes it does...... basically it plays cds at random ?!?!?!?!?!
2 Other Users Have The Same Problem
Comment by Guest, posted on Jun 22, 2008
CD player says NO DISC
Comment by jan_ca, posted on Jun 17, 2008
Mine stopped recognizing CDs all together. It says No disc.
And when plugged in power, without choosing any button (CD/Tuner/Tape/Aux) it will start flashing through Demo. It does this even when I push the power off/ standby button. So the only way to turn off the flashing lights and buttons is to unplug it.
Best Solution
posted on May 02, 2007
Hi
As you describe the problem, there are three likely possiblities, either the laser lense is dirty, the laser is beginning to fail, or there is a dead spot developing in the spin motor.
Cleaning is the first step, and the least expensive...If you have some electronics experience, they are not difficult to clean, but you must expose the laser to do it, and I don't want to advise someone to do that, and forget to unplug the unit. It's free laser eye surgery, but I doubt you would be happy with the results.
I would advise you to call around to local repair shops, and see what they charge to check it out and/or clean it, and then descide if it is worth proceeding.
Hopr this helps, good luck!
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Philips 3-Disc Changer FW320C
Email this problem
Email this problem
Can you Help with these Boomboxes problems?
Repair Service
Find Boomboxe Repairman Near You:
