Question about IBM eserver xSeries 350 8682
Bonjour, Configuration: Xseries 350 Bios version: 14/12/2001 PB: Un message d?erreur concerne l?absence de clavier attach? au serveur. Si nous faisons un red?marrage avec un clavier sur le serveur, tout se passe bien, et lorsqu?il y?a pas de clavier il entre dans le setup pour signaler qu?il y?a pas de clavier. Question: Je sais tr?s bien que c'est possible de booter le serveur sans clavier a partir de menu start option au niveau de bios par contre je cherche l'option exacte qui permet de faire ?a. Merci pour votre aide
SOURCE: Boot problem with IBM xseries 206 - SCSI Drive and SATA drive
Not a solution: just a follow up. Did you work this out, as I have the same problem now. For others info: the xseries 206, has 2 sata connections which can be configured as a sata raid. It also has 3 hot pluggable scsi slots. When the sata drives are not connected it boots off the scsi to win server. As soon as the satas are plug in ( 1 or 2, raid or not) it wants to boot off the sata drive. Any help would be great.
Posted on Dec 15, 2010
puertobori
  • 7733 Answers
SOURCE: Bonjour, mon ordinateur refuse de s'allumé,
Il peut être la carte mère ou l'alimentation.
Si vous avez besoin d'aide après plus de retour!
Le pouce et les témoignages sont les bienvenus!
Posted on Jan 22, 2011
info2u
  • 596 Answers
SOURCE: IBM xseries eserver x236 Bios problem: a yellow
Try this:
Light path diagnostics
Many errors are first indicated by the illumination of the system-error light in the operator information panel on the front of the server. One or more lights inside the server might also be lit that can direct you to the source of the error. The system information LED lights to alert you that there might be important information recorded in the system-error log. 2. Removing the left-side cover and look at the light panel. These LEDs indicate the type of error that has occurred.3. Once you know the general type of error and the general location of the component involved, the next step is to check the system service label on the outside of the server. This label gives an overview of internal components that correspond to many of the LEDs on the light path diagnostics panel and can help to view lit LEDs inside the server. Note: Some of the LEDs on the light path diagnostics panel will not have a corresponding LED lit on the system board.
Good Luck
C2Solutions
Posted on Jan 24, 2011
aviral_srms
  • 1216 Answers
SOURCE: I am attempting to access
best thing would be to flash your BIOS.
use the update file and flash your bios.
you may read here how to do it
or
watch this video
Posted on May 13, 2011
IZON code error 200-299 got 503-10-11 Comment on peux corriger cela
La chose la plus simple ? faire est de fermer la session puis d'?teindre votre IZON. Proc?dez ensuite au red?marrage, puis reconnectez-vous pour voir s'il corrige l'erreur. Si ce n'est pas le cas, il s'agit d'une erreur de serveur que vous ne pouvez pas corriger. 503 est le code pour l'erreur de serveur.
Oct 11, 2018 | Office Equipment & Supplies
Samsung microwave CP1395 malfunction E-32 in manual. If I use oven function or a combo like microwave & grill it stops midway and will not work again!
Bonjour
nous avions une erreur 32 sur notre four
ce n'etait pas l'element damper ci-dessus (test? manuellement)
nous avons trouv? la cause un peu par hasard : en appuyant tres tres fort sur le plateau interieur l'erreur 32 disparaissait et le four refonctionnait qqles secondes
donc :
debrancher le four
demontage de la tole de dessous le four
demontage de la piece qui detecte la presence (ou qui mesure - tres mal - le poids) : 3 vis
Sans lui debrancher ses fils electriques
avec un petit boulon par exemple et un serre joint : ecraser doucement le centre du capteur
poser le capteur er le serre joint derriere le four et remonter le four
rebrancher
ca marche
sans l'option mesure de poids mais comme c'est une fonction qui ?est pas au point c'est pas grave
stephane
bretagne
contact@armorstudio.fr
Apr 24, 2013 | Microwave Ovens
BONJOUR JE POSSEDE UNE IMPRIMANTE LASER COULEUR SAMSUNG ELLE NE FONCTIONNE PLUS ET AFFICHE UN MESSAGE D ERREUR SYSTEM ERROR CYCLE POWER QUE PUIS JE FAIRE
Bonjour cevale358 ,
Il n' y a malheureusement pas d' autre solution que de rentrer l' imprimante chez Samsung pour r?paration . Il s' agirait malheureusement d' une panne assez courante sur ce mod?le qui concerne le fusible et l' unit? d' alimantation .. Voici quelques pr?cisions si tu comprends l' anglais ... http://www.fixyourownprinter.com/forums/printer/66821
Cordialement ,
fanaudi .
Aug 27, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Bonjour au depart c'etait un probleme d'alimentation du papier et quand j'ai nettoye l'imprimante j'ai trouve un crayon de couleur a l'interieur maintenant je veux relancer l'imprimante mais j'ai le...
Bonjour ipty2004
Je suppose que vous avez vérifié si le capot ou tout autre couvercle sont bien verrouillés .
Je crois que si vous désinstallez le logiciel / pilote et le réinstallez ensuite après un redémarrage de votre ordinateur , le problème ne se posera plus .
Cordialement ,
fanaudi .
Mar 28, 2011 | Lexmark X5470 All-In-One InkJet Printer
Bonjour, nous avons acheter un téléscope de marque édu-science chez toys r us au canada. Il n,y avais pas le cd à l'intérieur pour le mode d'emploi. pouvons...
Vous n'avez pas besoin du CD. Il a ?t? un programme de plan?tarium. Vous pouvez t?l?charger un programme plan?tarium gratuite sur:
www.stellarium.org
Clear skies!
Jan 07, 2011 | Edu-Science Optics
Bonjour merci de me fournir la ersion "word 2003, 2007 ou 2010" Merci beaucoup
Demandez-vous que nous vous donnons une version de Word? (S'il vous pla?t pardonnez-moi si cela est indiqu? ? tort, je suis en utilisant un traducteur).
Nous ne pouvons pas vous donner une version de Word, mais un programme de bons offices libre OpenOffice.
Vous pouvez obtenir ? openoffice http://fr.openoffice.org/
Nov 13, 2010 | Computers & Internet
Bonjour, je viens de faire une mise a jour de mon nokia e71 pour passer à la version 500.21.009, et depuis plus de connexion internet, je lance internet la barre de chargement débute...
C'est plus utile que les clients communiquant avec Service, ou trouver un meilleur fournisseur de services Internet, tels que votre compagnie de téléphone cellulaire ou d'accès sans fil Poiint
Aug 23, 2010 | Nokia E71 Smartphone
Pourquoi code erreur 52030
Bonjour,
Mon nom est Brandonmxb. Je veux essayer de vous aider du mieux que je peux. Je ne parle pas anglais, mais puisque vous parlez français, j'ai appris la belle langue, ou bien je viens d'utiliser Google Translate. Bref, voilà votre solution.
Certains utilisateurs ont un problème de reconnexion à la fonction WiiConnect après la mise à jour il ya des systèmes.
Si vous avez trouvé soit un 32002 ou une erreur 52030 essayez de changer votre canal sur le routeur à 11 ou 1. Si votre déjà sur l'une de ces chaînes aller de l'avant et mettez-le à tout le reste, laissez le cycle de routeur, au moyen (redémarrera après le changement), puis changez-le sur le canal 11 ou un. Aussi, si vous avez un téléphone sans fil aller de l'avant et de l'éteindre juste pour s'assurer qu'il n'y ait aucune interférence. Si rien de tout cela fonctionne aller de l'avant et appeler Nintendo sur l'organisation d'une unité de remplacement ou de dépannage mai ils vous fasse.
Pour les "routeurs Linksys WRT54G" Entrez l'adresse IP du routeur (par défaut est 192.168.1.1) le mot de passe et nom d'utilisateur (par défaut admin / admin) puis cliquez sur l'onglet sans fil, maintenant sélectionner un autre canal sans fil dans le menu déroulant. Ce correctif mai ne fonctionnera pas pour vous, mais il vaut la peine d'essayer, et à nouveau ce correctif n'est pas garanti de fonctionner pour toutes les consoles.
Si cela a permis, s'il vous plaît taux de moi.
Besoin d'aide?
Aller à: http://www.nintendo.com/consumer/
Appelez: 1-800-255-3700 *
Dec 12, 2009 | Nintendo Wii Console
Bonjour! c'est fanilobiz@yahoo.fr
bonjour,
si jai bien compris vous voulez contcter les gestionnaires du site
alors vous leur ecrivez sue l'une de ces addresses mail (en anglais de preference)
jespere que ca peut aider
Media Inquiries: info@fixya.com Advertise on FixYa: advertise@fixya.com
Jul 10, 2009 | Microsoft Computers & Internet
IBM eserver xSeries 350 8682 Logo
52 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
