Question about Tascam 2488 Portastudio Multitrack Recorder System
I can't import midi files
I have a tascam 2488 mkii and a vista computer. The tascam will let me export files to the computer, but I can't import files from the computer to the tascam. Is it a campatibility problem?
  • drmoe2000 Mar 26, 2009
    I have the same problem with importing midi files. Your answer was about audio files. This is a midi file import problem through USB. Midi files are not showing up in Fat Partition even though computer states that you are replacing an existing file.
    Maurice Turmel
    Novelist:
  • 189 Answers
There shouldn't be any compatibility problems, especially since you can transfer files one way already. You might want to make sure any wav files you are trying to import to tracks on the 2488 are saved as 'mono' waves rather than 'stereo'. The 2488 won't import a stereo wav file.
Another problem sould be naming. Try to stick to the old dos 8.3 naming standard (xxxxxxxx.xxx) for any files which you wish to import.
Hope this helps.
bd.
Posted on Jan 02, 2009
Yeah, I agree with you on the 'mono' wave file format rather than 'stereo' wave file. The manuel explains that on the first few pages.
It also states you must, on mine it does, use CD RW 1x-4x only or, CD DA type blank CD's.
I tried this but it did'nt work. However, I have a theory that like all computers, after all that's what it is, it may need to be restarted after a failed attempt.
I'll give it a go and let you'all know. Any other suggestions people?
Posted on Apr 02, 2009
MY PC wont recognize my Tascam Portastudio device2488, i have Vista
Tascam 2488:
I use Vista and my 2488 MK1.
When you plug in the USB cable from the 2488 into your Vista PC, Vista will always say 'not recognised'.
You do not need any PC drivers for the 2488. On the Tascam 2488, go to 'Menu', then 'Disk', then 'USB Open/Close', then click 'Yes'.
On your PC the 2488 will appear as a new hard drive in the 'Computer' folder, called HDR2488.
You'll see three folders in there: WAVE, SMF and BACKUP.
Use the WAVE folder to import and export WAV files, the SMF folder to import midi files to the 2488, and the BACKUP folder is where you can import and export Backup files to and from the 2488.
Hope this helps!
May 09, 2012 | Tascam 2488 Portastudio Multitrack...
TRANSFERING OLD TRACKS TO THE NEW TASCAM 2488-NEO
You'll need your PC as the intermediary. You'll have to do a USB export of the tracks you want from the DP01 to your PC and then connect the 2488's USB to the PC and do a USB import of those tracks into new tracks on the 2488.
Page 40 of the DP01FX manual will explain using the USB connection and page 43 details the steps for performing a USB export.
In the 2488 NEO manual refer to pages 80 and 81 for using the USB connection and importing the tracks.
Hope this helps. Best of luck.
bd.
Oct 14, 2009 | Tascam 2488 Portastudio Multitrack...
Making Midi Files for Importing to Tascam 2488
You should always work in wav format if possible because there is a loss of quality with mp3 which is a compression format in which bits are lost in order to compress the file size.
There are a number of wav editors available which will allow you to load a stereo wav and then save it as a mono wav. The free one I use is called Audacity.
When working with FL or Reason I will sometimes import files to the Tascam, or I will take the outputs from my PCs sound card and line them into the tacams inputs and record them live. I only tend to do this with programs (like synths) where I am using an external midi keyboard and can play live what I want to record.
With basic drum pattern tracks I'll usually create them on the PC, save as wav, convert to mono, and then import to a track on the Tascam.
hope this helps.
bd.
Jun 25, 2009 | Tascam 2488 Portastudio Multitrack...
Control midi program sampletude
The Tascam has no midi In,Out or Thru so the answer is No.
Apr 21, 2009 | Tascam 2488mkii 24 Track Recording...
Play and Record button not working
I have the same problem with all three of my Tascam 2488 MKII's.
It's a software problem and starts to show up when the harddisk gets full.
Backup your song files ( something you have to do anyway ) and then reformat the entire hard disk.
Then restore the songs you were working on lately.
Before doing this rather huge task, you can copy your latest song to another partition and go on with this copy.
This is only a provisional solution.
Hope this helps !
Best regards
Jan 24, 2008 | Tascam 2488 Portastudio Multitrack...
2488 to pro tools
There is no way to 'sync' with protools from the 2488. In order to use your 2488 tracks in protools you have to first export your tracks as wav files and move them to your computer via usb and then import them into protools.
To get Protools files into your Tascam 2488 you'll have to export your Protools files into mono wav files first. They must also have a sampling rate of 44.1KHz and can be either 16 or 24 bit. Then load these files into your 2488 via usb and import them into tracks on the 2488.
Nov 21, 2007 | Tascam 2488 Portastudio Multitrack...
Instructions
Link to Tascam 2488 documents page:
http://tascam.com/Products/2488_downloads.html
Individual Items as Listed:
Link to the Tascam 2488 product brochure:
http://tascam.com/Products/2488/2488_bro.pdf
Link to the Tascam 2488 application guide:
http://tascam.com/Products/2488/2488_AppGuide.pdf
Here's the link to the Tascam 2488 quick start guide:
http://tascam.com/Products/2488/2488_quickstart.pdf
Link to the updated Tascam 2488 manual:
http://www.tascamcontractor.com/ftp_resour...w_additions.pdf
Link to the Tascam 2488 manual additions:
http://www.tascamcontractor.com/ftp_resour...e_additions.pdf
Link to the Tascam 2488 MIDI Parameter Mapping
http://www.tascamcontractor.com/ftp_resour...ontrol_v0.2.pdf
Link to TASCAM 2488 Hi-Res images:
http://www.tascamcontractor.com/ftp_resour...488_images.html
Nov 10, 2007 | Tascam 2488 Portastudio Multitrack...
I can't figure out how to record on 8 tracks at the same time.
Nov 07, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
Oct 23, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
311 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
