Question about GE DBL333EBCC 5.7 cu. ft. Electric Dryer
How do I take the front off the dryer.
The model number for my dryer is: DBXR453GVOWW.
  • 71 Answers
First remove the top by opening door then remove the 2 screws holding the top down, lift top off then remove the screws located on each side holding the front on then tilt the front out and up.
Posted on Dec 24, 2008
Where do i find the model number on my dryer
Hi Mary-
Some dryers have the model number on the front control panel. If not, there will be a label or metal tag on the back of the dryer along with the serial number of the unit and city/state of the manufacturer. Hope this helps!
Apr 01, 2014 | Dryers
Washing machine
I see a little confusion here...there is LG WD-1280FHD which is the MODEL number, WD= washer-dryer, LG=Life's (not so) Good. The "F" is for Front Load... HD for dryer Heated Dryer. The numbers correlate to date and assembly plant location. IDK this other number your showing is a Part Number
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Mar 15, 2014 | LG WD-1280FHD Front Load Washer
Maytag ensignia
follow this steps and fix it. God bless you
Drive Motor
The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer stops the motor might be defective. If the dryer stops and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. Also try rotating the drum by hand with the belt off, it should rotate freely. If the drum doesn't turn freely, determine what is causing it to bind. The dryer motor can't be tested easily. If the drum turns freely and the blower wheel is clear, and yet the dryer still keeps stopping mid-cycle the motor may be defective. it will need to be replaced. It is not serviceable.
Enter your model number to see parts for your dryer.
Help me find my model number
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
Drum Roller
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If they are worn out or start binding the motor can get overloaded and the dryer stops. If the dryer stops mid-cycle, check to be sure the drum turns freely with the belt removed. If not, check the rollers. Do not lubricate the rollers or roller shaft, lubrication will attract lint and cause the roller bearings to wear out faster. If the rollers don't turn freely, replace them. The roller shaft can often be reused, unless it has worn down. Clean the shaft thoroughly before installing the new rollers.
Drum Support Roller & Axle
This dryer has drum support rollers.There will always be two supporting the rear of the drum and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely. If not, check the rollers and rollers shafts. If they are worn or do not turn freely they will need to be replaced.
Drum Slide, Glide, or Pad
The front of the dryer drum is supported by small pieces of plastic-like material. As the drum rotates, it slides on these plastic pieces. If the dryer stops mid-cycle, it may be that one or more of these plastic slides or glides has worn out. When they wear out the drum can start binding and put strain on the motor. The motor then shuts down and the dryer stops. Check the glides for wear and replace as needed.
Drum Bearing
The drum bearing supports the rear of the dryer drum. Over time this bearing will wear out and may cause several different problems. If the dryer stops during the cycle it may be that this drum bearing has worn out and is putting too much strain on the motor. If the belt is removed and the drum spins freely, the drum bearing is probably not worn out. If the drum bearing is worn out, there may be some grinding or squealing, and the drum will be hard to turn.
Drum Support Bearing
Dryness Control Board
The dryness control board shuts off the dryer when the clothes have reached the level of dryness selected by the user. If the dryer stops too early, the dryness control board might be defective. This is not very common and other possibilities should be checked first.
Jul 21, 2013 | Maytag Dryers
Dryer will not come on after setting timer and pushing start. No light when door is open.
Most likely the door switch is bad. Listen for a click when the door is just opened or closed. Noclick = bad door switch. The number you passed is NOT the model number. The model number will have 3 digits followed by a period and up to 8 more digiits after the period. i.e 110.xxxxyyyy or 110.Cxxx.yyy (examples only as it can be other numbers depending on the manufacturer.) There are other numbers starting with 417 and 665 also.
This is what I think your model number is: 11064672400
The door switch is item 41 below link: PN 3406107
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11064672400/0582/0151200/K0404036/00002?blt=06&prst=&shdMod=
Detailed view:
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Dryer-Parts/3406107/0026/110/Model-11064672400/0582/0151200?keySuffixId=NA&productTypeId=x&searchModelNumber=11064672400&subCompDesc=Cabinet%20parts&brandDesc=KENMORE&modelDesc=RESIDENTIAL-DRYER&blt=11
This manual will help you:
http://applianceassistant.com/pdf/27gasElectricDryers.pdf
The top has to be opened and the front panel taken lose and tipped out to change the door switch.
The manual is not straight forward as to the sequence of remofing things but you remove the top... open the toe panel loosen the lower front panel screws and then take out the 2 upper mounting screws for the front panel to gain acccess to the door switch. POWER OFF at the CB or dryer unplugged of course!
Thanks for choosing FixYa,
Kelly
Jun 25, 2011 | Kenmore 64672 Electric Dryer
Where can I get the model number for for my Kenmore dryer?
Look in these places to find the model number:
Inside the door on the cabinet frame
On back of unit near the top.
On side of unit near the front.
These are the normal locations to find the model number. Kenmore models always have a three digit prefix such as 110 or 665 then a period, then more numbers.
Hope this helps and best wishes.
Aug 03, 2009 | Kenmore 700 6972 Dryer
Purchased a damaged GE dryer. Model and Serial number removed.
Model tag is inside door frame or at the bottom corner on the side. It may have been removed or not replaced if the front panel was replaced, Eric
Jul 07, 2009 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
When our dryer is turned on it has a very high pitched noise as if some metal is rubbing on the drum. It is model number DBXR453GVOWW.
It's noisy If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Mar 07, 2009 | GE Dryers
Don't know if this is right model
Okay...took me a while to get a good cross reference on this one. Drop the last four characters of your model number and place a "110." in front of the remaining numbers. That way the number reads 110.86921100. The "110" identifies the manufacturer. Your dryer is made by Whirlpool. If you go to searspartsdirect.com and type in the model number I provided, there are a series of drawings on the next page showing an exploded view of the layout of your dyer. Does this look familiar to you? Under the "Cabinet" heading you will find the dryer belt listed as item number 56 (part number 341241). For a diagram of how the belt goes on, go to repairclinic.com and you will find a dryer belt diagram link listed under the "Repair Help" section. Locate the Whirlpool diagrams and you will use drawing "K". I apologize if this sounds like absolute madness. If you get confused, please post back and let me know. I hope this answers your questions.
Jul 23, 2008 | Kenmore 62872 Electric Dryer
GE dryer
if you can get the correct model number of the dryer I can find the part number for you. the number you have in not the model number of the dryer. look in the door or on the back of the consol for it and get back to me. thanks
Jul 20, 2007 | GE DCSR483EA Electric Dryer
GE DBL333EBCC 5.7 cu. ft. Electric Dryer Logo
124 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
