Question about Kenwood DDX7019 6.95 in. Car Monitor
DDX7019 Controlling Ipod through touch screen is not working
Upgraded DDX7019 software to 1.0.9. Everything worked fine for about a day. Then I noticed selecting an artist or songs or trying to control the Ipod through the touch screen quit working. It plays the same songs over and over. I cannot switch the songs through the touch screen. The Ipod works fine unconnected. A couple of times after shutting the radio off it began to work ok again. Then a day or two later it began the same thing. Now it has been stuck again for a week. All other parts of the radio are work fine. It appears to have been the upgrade. I guess I could back it out. Any ideas or fixes? Or anyone else with the same issues?
  • 78 Answers
SOURCE: Player says "CALL" upon startup
It sounds like the telephone mute wire at the back of the set has got trapped and is shorting to ground and it then mutes the radio, remove the set and look for a trapped tel mute wire and wrap insulation tape around it to prevent it happening again
Posted on Jan 04, 2008
  • 6 Answers
SOURCE: Kenwood iPod Interface
I have a Pioneer Premier Deck in my van and I get the same problem I just unplug it and plug it back in
Posted on Jun 22, 2009
SOURCE: kenwood kvt-815 dvd touch screen not working
did you ever find a solution for this problem, I am currently experiencing the same thing
Posted on Dec 16, 2009
  • 35 Answers
SOURCE: I have a kenwood KDC-MP438U stereo. Ipod error.
Hi If anything the stereo was probably designed and tested using a certain version of the Iphones software, now that version 4 has been released the way the IPhone communicates may have changed.
As a result the stereo is no longer able to talk to the phone and vice versa. your probably best off contacting Kenwood direct to see if they are aware of this problem and if there is anything that can be done about it.
Posted on Jul 28, 2010
  • 733 Answers
SOURCE: Just bought the used car
Check the power from the harness. The yellow wire which is usually for constant 12v power and the red wire which should only have power when the key is turned on. check those wires and if you have power on both then the radio is fried. Try pushing the pins in the back of the radio harness in and see if maybe there is a loose pin, other than that, like i said , the radio may be bad.
Posted on Jun 28, 2011
My new Panasonic SC-HC57 is showing a 'checking connection' message when I put in my ipod Classic into the dock. I've upgraded my ipod to the newest software through iTunes, but still no
Not all ipod classic work with your SC-HC57 you need an older Panasonic SC-HC30 to work with that ipod :( or an iphone or ipod touch to work with your SC-HC57
Dec 26, 2012 | Panasonic SCHC57 SC-HC57 SC HC57 Compact...
My ipod touch screen is cracked but everything works perfectly
Is it the glass or the display beneath the glass? Cost will depend upon which of these is broken. There are many mail-in services available online, ifixit.com comes to mind. If you are a do it yourselfer, there are tons of videos and step by step instructions out there as well. I recently purchased an LCD display from ebay for an ipod touch, took me about 15 minutes to R&R the part for the device after reviewing videos on youtube.
Jan 05, 2010 | Apple iPod touch
Dropped itouch now half of screen is gray everything else works fine just can't see half the screen
It's most likely a broken LCD. You can use a ipod repair guide that will show you how to replace the screen step by step, or you can go to the ipod repair nyc.
Jul 20, 2009 | Apple iPod touch
Sync locks up PC
Try restoring or resetting the iPod.
Apr 21, 2009 | Apple iPod touch
I have an older 30 gb video ipod and that worked jus fine but when i pluged in a newer ipod nano it doesnt connect and it does with a brand new 16 gb ipod touch. is there anyway to fix this problem?
When you synced to a newer version of iTunes, everything was fine, until you connected the nano and
the touch, which worked fine, and then you tried the 30 GB again and it would not work, right?
Upgrade the software in the 30GB, not with your original 30GB disks, but with newer disks supplied NOW
by Apple, since iTunes went to version 8.1.1 and everything should be back in sync.
Apr 10, 2009 | Dual Electronics XDVD8183 Car DVD Player
Static noise/no sound from ipod touch
Sounds like you just need the ipods headphone jack replaced.
Try either http://www.ipodrefresh.com or http://www.ipodrecharge.com. They specialize in ipod repairs.
Mar 16, 2009 | Apple iPod touch
My ipod touch feel into the water for about 3 sec
Maybe it is't completly dried out.I saw somewhere to put a wet cell phone in apan of rice,the rice draws the moisture out.hope it helps
Jan 01, 2009 | Apple iPod touch
Ipod touch
Hello bobsomos123,
Even though the product is within the 30 day return / exchange period you will be unable to exchange the product. Damaged products are not accepted for exchanges.
Your local Best Buy® store may be able to assist you in having the product sent out for repair. However since water damage is not covered by any warranty, you would have to pay for those repairs.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 24, 2008 | Apple iPod touch
Ipod Touch Safari, Mail, and Youtube Malfunction
http://www.ziphone.org/
Use the Ziphone ipod touch and iphone jailbreak GUI to put the ipod in recovery mode. Then restore it using iTunes.
You don't have to jail break it if you dont want to.
Jun 02, 2008 | Apple iPod touch
Kenwood 7019
Try updating the ipod software from the kenwood website, I had the same problem and it worked for me. My album artwork didnt work either until I updated the software.
Mar 19, 2008 | Kenwood DDX7019 6.95 in. Car Monitor
Kenwood DDX7019 6.95 in. Car Monitor Logo
166 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
