Question about Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe...
I have a Maytag side by side refrigerator and lost my manual. How do I remove the inside water filter cartridge, which rotates either direction but does not easily come off?
  • 700 Answers
First shut of trhe water and then let the pressure off of the line by openoing up the water dispenser . then turn it counter clockwose and then it sjhould come right off
Posted on Dec 24, 2008
How to change water filter on msd2352kew
Instructions on how to change the water filter are found on page 20 of the user manual Here=> MSD2352KEW User Manual
I will be here should you have questions, Thanks Sea Breeze
The water filter is located in the upper right-hand
corner of the fresh food compartment.
1. Remove blue bypass cap and
retain for later use.
2. Remove sealing label from
end of filter and insert into
filter head.
3. Rotate gently clockwise until
filter stops. Snap filter cover
closed.
4. Reduce water spurts by
flushing air from system.
Run water continuously for
two minutes through
dispenser until water runs
steady. During initial use,
allow about a one- to two-minute delay in water
dispersal to allow internal water tank to fill.
• Additional flushing may be required in some
households where water is of poor quality
Mar 22, 2013 | Maytag Refrigerators
By mistake, when removing the water to replace it, I turned the cap and it came off. realizing my mistake I replaced the cap, pressed the button and tried to pull it straight out per the instructions on...
the directions state To change the filter you would 1.) remove the cartridge cap (counterclockwise to a vertical position) and pull the filter out through the base grille. Directions state there will be water in the cartridge so some spilling may occur. 2.) remove the cartridge cap by sliding it off the end of the old cartridge. The cap will slide to the left or right. Do not discard the cap. 3.) Take the new cartridge out of the package and remove protective cover from O-rings. 4.) Slide the cartridge cap onto the new cartridge. 5.) With cartridge cap in the vertical position, push the new filter cartridge into the base grille until it stops. Rotate the cartridge cap clockwise to a horizontal position. Its the first part of doing this thats a real pain but after you get by the first instructions the replacement becomes easy if you have any further questions message me back Thanks again Rick
Jun 14, 2011 | KitchenAid Superba Architect KSCS25INSS...
We never received a manual and now need to replace the water filter. model no. ASD2522WRW03 - ser. no. S01831393. also how do we order a replacement manual
The direct link to the manual from Amana is http://www.kitchenaid.ca/assets/pdfs/literature/User%20Instructions%20-%20W10237701A.pdf . If the direct link doesn't work, start here: http://shop.amana.com/product_literature/search_results.jsp?searchTerm=ASD2522WRW03&siteCd=AMA&userType=Consumer . The manual is also available at Manage My Life: http://www.managemylife.com/mmh/owner_manuals/17324/AMANA-Side-by-Side-Refrigerator-L1002225?brand_name_search=ASD2522WRB03+AMANA .
The filter you need is T2RFWG2 and P2RFWG2 (part number 4396841) . The filter is in the base grill on the freezer side of the side by side. There is a cap over the filter. You need to push the release button on the cap to remove the cap and filter. Save the cap and put it on the new filter before replacing the filter. If you replace the cap, you can use the water and ice dispenser without the filter.
If you want a printed copy of the manual, you can order it from Sears Parts Direct. They also have the filter. See http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ASD2522WRW03/1268/0165000/W1009009/00001?blt=06&prst=&shdMod= . The manual is part 1 ($5.99) and the filter is part 30 ($54.98). The filter is also available from Partstore.com http://www.partstore.com/Model/Maytag/Maytag/ASD2522WRW03.aspx for $37. Amana sells the filter here: http://www.amana.com/accessories/refrigerators/water_filters/refrigerator_water_filter___in_the_grille_fast_fill_push_button_4396841.pro?scr=category for $40. If you go here: http://www.amana.com/accessories/refrigerators/water_filters.cat , you can order several filters at once.
I hope this helps.
May 22, 2011 | Amana Refrigerators
Is the water filter on the top of the refrigerator
on my Maytag the water filter is inside, on the internal "ceiling" , a long tubular form with a tab on front that says "push" inside is a filter cartridge.
I have never changed it as believe it will show on display when it is needed.
Feb 24, 2011 | Maytag MFI2568AE Side by Side French Door...
Were is the filter located on this model of frige we just bought it of a firend and he has lost the manual for it and we would like to replace the filter.
On my Maytag bottom freezer French door model the filter is inside, at top right tubular form on "ceiling" with a tab on front says "push". Cartridge filter inside.
Feb 23, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
How do I change the water filter on my GE Profile French door refrigerator?
The filter on the one I know (see below) has the water filter in the upper right of corner of the refrigerator. In my experience, you should move all food from that side of the top shelf of the refrigerator and put a shallow pan underneath. Some water will spill.
First get the cover out of the way by pressing in on the tab on the front and tilting the cover down. Remove the old cartridge by rotating it counter-clockwise. The front end of the cartridge is shaped to make a handle. Use care in case any air bubbles have built up behind the cartridge; they could force the cartridge out suddenly. Remove the foil from the end of the new cartridge. Line up the arrow on the cartridge and the arrow on the cartridge holder and then rotate the cartridge clockwise until it stops. You will feel a "click" as it locks into place when properly installed. The grip on the front should be positioned vertically. If the cartridge is overtightened, it will leak. Close the cover and the refrigerator doors. Run the water dispenser for 3 minutes (1 1/2 gallons of water) and discard the water. This will clear the line and prevent future sputtering. It will probably sputter while you do the inital clearing.
Reset the water filter replacement light by pressing and holding the Reset Water Filter pad for 3+ seconds.
The manual for most GE refrigerators are available online from the geappliances.com site. A very similar unit has the manual here: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=PFSS5NJWSS .
I hope this helps.
Dec 16, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
I CANNOT REMOVE THE WATER FILTER LOCATED IN THE UPPER RIGHT INSIDE THE REFRIGERATOR. I TRIED TO TURN IT COUNTER CLOCKWISE BUT IT WILL NOT COME OUT. THE PART NUMBER ON THE FILTER IS UKF8001. ANY...
  1. 1. Look for the water filter cartridge. On some refrigerators it is located in the back, upper right corner of the refrigerator compartment. Some refrigerators have it in a tubular-like slot under the door and accessible from outside.
    2. Remove the old cartridge. On the cartridges that are located inside the refrigerator, the cartridge should be slowly turned to the left. Don't pull down on the cartridge. A small amount of water may drip. On the type that are under the door, follow the arrow labeling for the direction to unscrew it. Slide it outside.
    3. To replace a filter, fill the replacement cartridge with water from the tap. This will speed up water flow after installation. Run water from the dispenser for three minutes after replacing a filter to clear the line. Refrigerators with a filter warning light require you to reset the light. Press and hold the Reset Water Filter button to do that.
Jan 18, 2010 | Refrigerators
How do I replace the water filter in my Maytag Refrigerator it is a side by side with the ice maker in the freezer door. The light is on and I can't find my boodk
iF THE FILTER IS IN THE UPPER LEFT HAND CORNER OVER THE ICEMAKER. iIF YOU HAVE A REPLACEMENT FILTER ON HAND. YOU NEED TO TURN OFF THE WATER SUPPLY AT THE SOURCE. DISCONNECT THE VINYL TUBING AND LET IT DRAIN INTO A BUCKET OR ANY OTHER VESSEL. THEN YOU CAN TWIST THE WATER FILTER COVER COUNTERCLOCKWISE AND REMOVE THE OLD FILTER CARTRIDGE AND INSTALL THE NEW NEW ONE. THEN JUST REATTACH THE WATER SUPPLY LINE AND TURN ON THE WATER SOURCE. THERE SHOULD BE AIR AT FIRST THEN WATER SHOULD COME OUT OF THE WATER DISPENSER.
Jul 19, 2009 | Maytag MSD2756G Side by Side Refrigerator
Change water filter for a maytag plus refrigerator
press the light switch button inside of the refrigerator five times.
Apr 03, 2009 | Maytag MSD2436GR Side by Side Refrigerator
Water filter
Inside filters usually need to be pushed up and rotated, then pulled down (bayonet lock). In line filters (outside of fridge) usually need to be unscrewed, both ends. Inside ones are really expensive.
Apr 13, 2008 | Maytag MZD2766GES Side by Side...
Maytage MSD2652KE 26 cu. ft. Side-By-Side Refrigerator w/ Electronic Ice/Water Dispenser & AdjustiTe... Logo
95 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
