Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE TFX20JR BK WW side by side won't cool or freeze
I've got a GE side by side refrigerator model # TFX20JR BK WW and I noticed late last night that it didn't seems to be cooling and it's worse this morning. I emptied the freezer and took the back panel off and the coils are covered with ice.... and it's Christmas Eve :(
  • Anonymous Dec 26, 2008
    my GE Gss201EmBWH has the same problem help
  • packrdiane Jan 03, 2009
    My GE side-by-side seems to have stopped working on the freezer side, especially on the upper racks. There was a lot of frost buildup on the back, inside, and I've removed that but it didn't seem to help. Turned freezer temp to coldest setting, didn't help. The fridge side seems a little warm too....
    Problem Solver:
  • 4 Answers
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Posted on Jan 01, 2009
My GE 19.7 TFX20JR only partially freezes in certain areas and not cold on refrigerator side. This all happened at the same time it stopped making ice. Water still dispenses.
Check for frozen, iced over evaporator coil caused by defective defrost timer and/or heating element. Ice maker will not work unless freezer temp is around 10 degrees or less.
Mar 15, 2015 | GE Refrigerators
GE 19.7 TFX20JR not cooling or freezing
I think you fridge is low an gas, refill it
Mar 14, 2013 | GE Refrigerators
I have a GE 2003 25 cu ft side by side, model #: GSS25LGPA WW. All lights, fans, controls work and I do not hear any "clincing" sounds. The refrigerator just stopped cooling/freezing and I can not hear...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 19, 2010 | GE GSS25LGM Side by Side Refrigerator
Ge Side by Side Refrigerator model GSS22JFMC ww Is not cooling not frezzing properly and not making ice. The motor is still running ok
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
rggasd
Jul 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE TFX20JR
how is the freezer? if it is ok is the freezer back panel full of frost if so then you have a defrost problem and the ge is really good for the heating elements to go bad
Jun 26, 2009 | GE GSH22JFR Side by Side Refrigerator
Ge tfx20jr side by side
make sure your freezer freezing if freezing check water valve check icemaker
Mar 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model TPH 21 PRSM WW not cooling in reefer
The 'baffle' is controled by a small electri motor,This is a renewable part.If you want to manually open it,you should be able to gently move with you hand,after removing the guard. Hope this helps!!
Nov 14, 2008 | GE GSH22JFR Side by Side Refrigerator
Freezer not working - GSS20IGPA WW
All cooling starts in the freezer section where the evaporator is. Too much stuff in the freezer can inhibit the necessary airflow around the evaporator and cause it to freeze. Usually, the next defrost cycle will thaw it, but it can keep the cool from coming out. There are so many things that can cause the lack of cooling, but most often, it is NOT the compressor. e.g. - if there's water pooling on the inside at the bottom, you have a bad door seal. If no real cool ever happens and you don't hear the hum of the compressor often, you defrost timer is bad.
Jun 09, 2008 | GE GSS20IEP Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
1,210 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
