Question about HP iPAQ hw6915 Smartphone
Charging issues for HP Ipaq 6915 in my car - HP iPAQ hw6915 Smartphone
  • HP Master
  • 13,433 Answers
Hey,
If you only have issues in your car and it charges fine in the house the the problem is with the car charger
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 16, 2009
IPAQ hw6915 memory card
maximum limit recomended buy HP is 2GB,
Jun 21, 2012 | HP Cell Phones
HP ipaq Bluetooth&Camera Problem
Hello alone-cowboy,
Here is the manual for you with step by step instructions on how to use your unit. I have link you to the complete manual with specifications, resources, Picture illustrations as well as trouble shooting section. I hope this helps you. If this does, please if you can, rate my solution accordingly and some nice words would be appreciated.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000036051.pdf
Also if you like, here is my link to my own pages on fixya of other areas in my expertize. I am also completely trained and certified in Automotive, Appliance and of course Electronics. Here is my personal Link to my page. Thanks Mike
http://beta.fixya.com/users/mc1bean
Feb 25, 2010 | HP iPAQ Bluetooth GPS Navigation
The hp ipaq 6915 i have just shows the serial,hp
Ciao,bisogna premere le due cornette(telefono verde e rossa)) + on/off e soft reset insieme,poi sul display per 2 secondi appare la scritta CLEAR OK,dopo premi solo le due cornette(telefono verde e rossa) e il softreset insieme per qualche secondo almeno 15 finch? non si avvia per centrare il display.Tutto qui.ciao Dario
Nov 16, 2009 | HP iPAQ hw6915 Smartphone
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
My HP Ipaq 6915 goes off at 60% battery level or when i try to connect to wi fi, and switch off my bluetooth. At 85% battery power level i cant make or receive calls. It just loses network connectivity,...
The batteries from Ebay that are from China have lots of issues. I use an HP 6945 phone/pda and had the same issue with my original battery. I tried a cheap battery and it died within 2 months. I ordered an HP original battery and have been using it again full strength for 7 months. The new battery works bluetooth, wi-fi and gps as well as phone down to about 15% before I recharge. The HP batteries are more expensive but they are worth the extra price.
Buddy
Corporate Computer
Over 21 years of PC and printer service/support
Mar 10, 2009 | HP iPAQ hw6915 Smartphone
How to format hp ipaq hw 6915
Download the user manual on the right hand side of this link:
http://safemanuals.com/annexe_Reference%20Guide_HP_IPAQ%20HW6915-_E.htm
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 20, 2009 | HP iPAQ hw6515 Pocket PC
HP IPAQ HW6915 get stuch charging non original battery
I forwarded the request to some more professional forum.
Feb 19, 2009 | HP iPAQ hw6915 Smartphone
Charging pin of my ipaq damaged
hi
I can fix your sync&charge connector very fast in our lab.
you can send your device to us and we will charge you by paypal and return it to you in less than one week.
thanks
Gery
ipaq Lab
Nov 27, 2008 | HP iPAQ hw6515 Pocket PC
HP Ipaq 4155 not recognizing battery
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Nov 07, 2007 | HP FA162A for iPAQ 2215/4155 Keyboard
HP iPAQ hw6915 Smartphone Logo
140 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
