Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Top drawer sticks
When we opened up our dishwasher this morning, we found it very hard to open and close the drawer. my guess was that something was obstructing the drawer slides, but couldn't find anything right off. it also looks as though the drawer may be tilted down a little bit, but have noticed this before with no problems. The resistance is so bad you really have to push it hard to get it to go back all the way, and even then, the sensor doesn't recognize that it is shut. any ideas??
  • 3 more comments
  • djbrisvegas Dec 26, 2008
    looks like the top is jamming it. i opened the unit and couldnt see why it would.. Dont know so surfing trying to find out why
  • Anonymous Dec 29, 2008
    The top drawer stuck a few days ago, with exactly the same symptoms as you describe. Now the bottom drawer has started to do the same thing. It feels as if there is something sticking in the drawer slides but nothing is obvious
  • jbuttery6 Feb 18, 2009
    I have the same problem ,but after I did this , I could hear the top lid closing and opening ,,but not the bottom. after I turned the machine off for a while ,then on ,I could hear something that I think is the motor trying to raise the bottom lid ,,is it possible to start the motor manually by turning the threaded spindle?
  • marcoweinman Apr 11, 2009
    Thanks so much RT. I had the same problem and your solution fixed it! Can you send me the service manual so I have just in case the problem returns?
    marcoweinman@hotmail.com
  • lfle May 11, 2010
    Wow! Oh wow! You saved me $$$. Thanks.
  • 145 Answers
Hi and welcome. I think I can help here.
Read over my instructions first before pressing any buttons- Set the machine in diagnostics mode by first pressing the small lock button and holding it down, followed by the center button. (hold them both together, but start by pressing the lock button FIRST) for about 6 seconds. (you have to press the center button down right after you depress the lock button or else you will just set the machine in LOCK mode) You will hear a BEEP. Now push the far left button once. Now look at the display and press the center button to scroll thru the codes. You want to find "LD", I believe you will see it after three sucessive codes from the begining, but either way, scroll thru until you see LD, and then press the small lock button once. You should hear the lid motors retract now, and you will feel the drawer "come loose" again once the lid motors are back in the retracted position. Then simply turn the machine off. This clears the diagnostic mode. That should free the drawer up. Try this first and if you still have problems, let us know.
Happy New Year from the FixYa crew!
Posted on Jan 01, 2009
My dishwasher fisher pykel twin dish washer model # DD 605 , SHOWS AN ERROR CODE f7 first then shows error code f9
The top dishdrawer is hard to open or close as the lid seal actuator motors are most likely faulty or lost power. The scraping is the lid seal touching the drawer lid. The F7 and F9 error are a result of this fault with the actuator motors.
At the base of the dishwasher housing under the bottom drawer is the power board. From there the power is supplied to the controller and the motors. These motors move the lid seal into position. First turn the mains power to dishwasher off and then back on. See if this resets the motor position. If not you will have to call the technician to fix the problem. But if you are technical savy you could go to the base of the dishwasher and take the connectors of drawer 1 out from the power board and swap with drawer 2 which is working.
If power board connection is not making any difference, then motors are the likely problem. Needs a lot of expertise to replace and adjust the motors.
Mar 23, 2014 | Fisher and Paykel 23 in. DD-603 Built-in...
Kitchen Aid KUDD03DT top drawer won't stay closed
The lock lever on the unit --- that is shaped like a U --- if you have it ---may be bent a little. You can move it to the correct position - usually down a little --and your door will stay closed
Mar 04, 2014 | KitchenAid 24" Double-Drawer Dishwasher...
Top drawer won't close
After completing a cycle the top drawer feels like it will not open or the top of the drawer has fallen down. I've since forced it open but, now it feels like it will not close. I did not force it to close. How do I remedy this problem?
Mar 02, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Botton door sticking hard to open and close
It is likely the drawer seal assembly is not working properly.
You will have to get the drfawer out from the housing and check the top inside of the housing to see if the seal is broken or can be more complex if the seal actuator motors are out of alignment. Will need to call technician if you are not familar with electrical components.
If you keep operating like this then water leak can cause damage to dishwasher.
Jul 14, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer of 2 drawer f and p dishwasher was very hard to slide open and have to really push hard to close, like something is binding
Hi,aside from any obstruction is thet DishDrawer® square and level?. Is the DishDrawer® fastened securely to the cabinetry to prevent flex or movement? If not, the square geometry this appliance requires with affect drawer performance when opening and closing.
This is the most common cause for your problem. I'm not 100% sure, but it is something to take into consideration. Just a thought.
Feb 07, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
Bottom drawer locked (stuck) open
fisher and paykel sent me a solution - turn off at wall and unplug then turn back on. The dishwasher reset itself and the drawer unlocked.
Nov 24, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
The top drawer intermitantly makes the drawer opening noise
On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. Wipe these areas with a clean dry cloth.
May 31, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & paykel top drawer stuck again
Sounds like the lid is not opening all the way. Rubber may be coming off lid seal during opening and closing. Check you lid actuators replace both right and left if needed.
May 15, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
F&P dish drawers model DD6031
It may be that the DW thinks the drawer may have been pulled open. On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. This is how the drawer senses whether the drawer is open or closed. Wipe these areas with a clean dry cloth.
Apr 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
242 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
TomDicker
Level 1 Expert
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
