Question about Kenmore 62602 Electric Dryer
Can't get replacement parts back on Kenmore 60 series dryer.
Kenmore 60 series dryer tub quit turning. Pulled out dryer and found broken belt and pulley on floor. Got a new belt. Can't fiqure I how to put pulley back on with belt correctly. Any way I've tried still won't spin tub. I can spin by hand. Dryer puts out heat,no spin. I have no diagram or manuals.Help!
    Problem Solver:
  • 4 Answers
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Posted on Dec 26, 2008
Dryer was drying clothes started making real loud noise, tub quit turning the belt is broken.
You need to change your idler wheel, your support rollers and your belt. If you have the model number, I can help you further.
Oct 20, 2014 | Kenmore Dryers
Kenmore 96282100
Some models you can replace by tipping dryer on its back. Tough part is sneaking the belt between frame and tub. Otherwise remove back panel, remove lint screws, remove control board. Now remove the shell and you can easily replace belt. This is a def diy project. Check youtube for general description. Whirlpool and roper would be similar.
Jan 10, 2014 | Dryers
My dryer heat but tub want turn i open the back and the belt was laying on the floor on the rt. side i would like to know if i would be able to replace it or not.
Hi again, Your parts can be found here:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11086880800/0582/0151200?searchedModel=86880800&blt=11
The belt is item 30 of this page:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11086880800/0582/0151200/00041279/00002?blt=06&prst=&shdMod=
The manual that will help you is here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
Removal of the top is on page 19 / 14 printed of the pdf file
Removal of the toe panel is on page 20 / 15 printed if the pdf file
Removal of the front panel in on page 24 / 19 printed of the pdf file
The belt is installed with the ribs against the drom and the udler pulley / motor routing for the belt can be found here:
http://www.repairclinic.com/Dryer-Belt-Diagrams#DiagramH
Once you have the drum loose inspect the rear bottom drum rollers and idle pulley for any signs of wear. Flat spots or hard to turn = replace.
Thanks for choosing FixYa,
Kelly
Mar 16, 2011 | Dryers
Kenmore 80 series dryer. was working fine, now
Hello. When ever a dryer will not turn the first thing to suspect is a broken dryer belt. lift the top on your machine and visually inspect the belt. If it is broken, it is easy to replace. Joe
Apr 21, 2010 | Dryers
Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
May 05, 2009 | Kenmore Dryers
Belt replacement
Take the belt with you to an appliance store and they will match it up. Much like a fan belt on a car. You won't necessarily need the model if you have the belt. Next, it sounds like your assembly is broken. If this assembly looks to be in pieces, you may need a new one.
Feb 03, 2009 | Kenmore 73952 Gas Dryer
Broken Belt--kenmore 70 series dryer
it is not that hard to replace the belt if you have the front panel off of the dryer. place the idler pulley in the holes located below the motor pulley put the belt around the drum pull the idler back and the belt loops around the idler and onto the motor pulley
Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
Dryer wont turn
Yes, it will save you alot of money and work just fine. You will have to shut off the dryer, turn off the gas and/or electric(disconnect it to be sure it is power free). Look at dryer carefully as you may be able to access the belt from the lower front. The belt is easily available at Sears Parts Stores. Do not use it until fixed as it might overheat!
Dec 09, 2008 | Kenmore 63942 Dryer
Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Sep 25, 2008 | Kenmore 63942 Dryer
Broken Kenmore dryer 80 series
Hi Dave. The problem is the drive belt. They aren't that difficult to replace and can be done with just a few tools. I'll need the exact model number off of the dryer to explain how to gain access to it, though. The number can be found behind the door on the cabinet (it'll start with 3 digits then a decimal point then more digits, like this; xxx.xxxxxxx)
The part number for the repair is 4392065. This is a complete maintenance kit for your dryer. I recommend it because since your belt wore out, there are other parts that should be taken care of at the same time. Here's a picture and a place to order if you can't find it locally.
Oct 18, 2007 | Dryers
Kenmore 62602 Electric Dryer Logo
275 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
