Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Brushes wont rotate
My brushes are not rotating but my belt is good
bissell 7901-1 pro heat
  • Anonymous Mar 01, 2009
    belt is fine but slips off
  • mwinf34105 Mar 01, 2009
    the metal gear that the toothed belt wraps around falls out of the hole..... I thought this was a one-piece axle?
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
uyk
Posted on Sep 30, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Cleaning brushes wont rotate
I understand how important the brushes are when cleaning.
You may want to the check the pump belt for breakage for the brush belt and pump belt work in conjunction with the pump.
If you're still experiencing difficulty, you may want to have your machine inspected at one of our Authorized Service Centers. Here's a quick link to help you locate one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Mar 17, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
I have a Bissell Pro Heat Carpet cleaner and the brushes will not turn. The pully is not turning the belt.
if the motor shaft that rotates the belt to turn the brush does`nt turn you have motor problem`s if it does you need to free up what ever is keeping the brush froom turning freely
Nov 06, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Brush not moving in Bissell pro-heat
if the belt is more then 6 months old or more, then the belt will have to be replaced reguardless of the way it lookes. belts can stretch over time and when you put the machine on the carpet the friction causes the brush to stop because the belt has stretched. i would try this first. hope this helps
Jul 30, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
The brush will not turn
Hi! Your question has come up under Bissell ProHeat, so I'll assume that's the model you're talking about.  There are several possibilities. The simplest is that the drive belt has broken. There are two drive belts on the ProHeat and you're best advised to go to the Bissell website (www,bissell.com) where you can download a manual for your exact model.  Worst case scenario, which I have seen, is where the brush drive motor has become wet, it has corroded and will no longer rotate, and this burns out a little circuit board that's located in the handle. If your belts are OK, and the brushes are free to rotate, there's probably a problem with the motor and I strongly recommend consulting a professional repairer. Getting in to the machine is a minor nightmare, and getting it back together is worse. The cost of such a repair may well exceed the value of the machine. Good luck!  I value your feedback.  If this has helped please remember to rate me.  If it hasn't helped, please re-post with more details and I'll try again.
Feb 17, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Pro heat 9500 2X
I had this same problem, even went out and bought a second machine, same problem. Here was my problem....I was checking the brushes while the handle thingie was in the upright position. You have to be sure and RELEASE THE HANDLE. Now i have 2 perfectly good Bissells.
Jan 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Pro Heat 2x steam cleaner, problems!
Must likely the brush motor is bad. The top cover has to come off to check it, this is where the tank sits on. Part # 2036757 and is #35 in the pix.
Mar 14, 2008 | Vacuums
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
133 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
