Question about RCA HD56W66 56" HDTV
Reset button search. RCA Model# HD56W66,Serial# F305CG081, Chassis# ITC222A
Hi, my mom has this TV and one day she was vacuuming and the TV just went out. She had no protector plugged into the outlet and I was wondering if there is a reset button. I looked in the back and no sign but before I went on taking thing a part I thought I would get a few suggestions on what I might do. Thanks
  • mracey Dec 31, 2008
    where is the reset button ?
    Genius:
  • 1,030 Answers
Televisions haven't had reset buttons in awhile. Of coarse i say that and there will be one that does.. standard reset on most television is to unplug and plug back in in about 30 min to and hour. THis set does not have a reset button. first question is the set completley dead. does the front light flash. If it does it means the sets processor is getting power and is detectecting a condition and shuting it down for safety. if it does not flash it means the processor is not getting power.
Posted on Jan 01, 2009
The picture looks 3D and when you select the menu all writing is in a U shape. The TV is a RCA HDTV and the model # R52WH74YX51. Serial #G402C10DZ, chassis #ITC222A, and was manufactured Oct. 2006.
Its more than likely the FL231 fuse has blown due to carcked solder joints on the flyback. very famous issue with that model if the auto convergence feature is no longer listed under the setup menu then you will need the convergence option missing repair kit from www.tvrepairworld.com
Aug 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA R52WH74 chassis # ITC222A wont turn on. The green power light comes on for about 10 seconds then shuts off. No picture, no sound. How do I fix it? Buying a new TV just isn't in out budget!
That model is famous for having issues with the deflection board failing. Replacing the deflection board should solve the issue. You can get replacement deflection board for the ITC222A chassis from www.tvrepairworld.com under the RCA circuit boards catagory.
Aug 05, 2011 | RCA R52WH73 Projection Television
Hi, my tv RCA model HD56W66 chasis ITC222A not work, just the botton swich led flashing and pause, flashing and pause, and no more nothig, somebody tollme the proble is power/deflection module 264102, but...
I'm not sure but a simple test might be for you to unplug the set and wait about 5 minutes then plug it in again and try. Sometimes the set will correct itself for some simple problems, it is kinda like rebooting your computer. Give it a try.
Jan 22, 2011 | Televison & Video
RCA R52WH77 ITC222A chassis convergence problem - FL231 changed!
did you hear an arch before it went if so , one of your crts is arching
and sorry they are not avail anymore
Sep 20, 2009 | RCA Televison & Video
Television will not powwer on
Hello al1895,
This model of TV uses the ITC222A chassis. This is a common problem in this unit. The problem is usually centered around 4 capacitors (CP140, CP150, CP110, and CP114) They usually vent (becom bloated or puffy) and develop an internal short which causes the TV to shut down. This is usually caused by power surges (even when connected to a surge protector). The repair for this problem does not cost much, and I would suggest that you have a TV repair technician examine this TV due to the other problems that can happen with this chassis (ITC222A).
I hope this helps,
Thank you,
Shuttle83,
http://www.electron-age-technologies-llc.com
Jul 27, 2009 | RCA HD52W59 HDTV Projection Television
Power wont come back on TV
the most common component to fail with that sympton is the flyback. If the chassis is a ITC222A the flyback will be 259296 or 265409 as they were both used in that chassis and model number. If you need more assistance let me know the Chassis number from the tag in the back.
Mar 13, 2009 | RCA R52WM24 52" HDTV Projection Television
Tv will not power up
Flyback transfromer is bad,part number 259296,part is around 60.00,you might find it at mcm electronics,phone number is 1-800-543-4330
Mar 28, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD56W66 56" HDTV Logo
466 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
