Question about Haier HC125FVS Wine Cooler Beverage Cooler
Haier HC125FVS does not cool.
We have a Haier HC125FVS that does not cool. Power is good since light comes on when door is open. I hear a loud click from the back, but no fan, no cooling. Warranty covers "sealed system" but not labor. How can I determine if the problem is in the "sealed system", and if so, how difficult would it be for me to fix it? Labor cost for someone else to fix it is more than it would cost to replace the unit. Thank you.
What kind of light bulb for haier beverage center model hc125fvs
Just take out the bulb and go to Wallmart and match it up. They have a wide variety, long tube bulbs etc.
Apr 08, 2014 | Refrigerators
My microwave has stop heating up food. What is the cause?
There are several things that can cause this:
1. Bad high power diode failure (most common and usually causes a loud humming sound when it fails initially then never heats again)
2. Bad capacitor (open or shorted)
3. Stuck Magnetron oscillator (Makes a loud humming sound when the Diode and capacitor are known to be good.) / Magnetorn failure
4. Door interlock safety switch failure. (You should hear 3 clicks on most microwaves as the door just opens or closes... if your microwave light does not come on when the door is opened you only have 2 micro-switches and only hear 2 switch clicks.
5, Main control board relay failure / main board failure.
Those are the most common reasons listed in order of usual failures. Each one of the above possible failures has a different troubleshooting procedure.
Thanks for choosing FixYa,
Kelly
Sep 21, 2011 | Heating & Cooling
Suddenly fridge not working
Two things to check.
Is the door light coming on? If yes you have power
Is the compressor running? Turn the thermostat knob until you hear a click. Did anything happen?
If no you will need a new thermostat
Mar 31, 2011 | Haier Refrigerators
I have a Haier HC125FVS Wine Cooler that has stopped cooling. The compressor hums but will not start. Is the starter #6R8MC a two piece part? I have unpluged the black part with that number, but there is...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 25, 2011 | Haier HC125FVS Wine Cooler Beverage Cooler
Haier refridge actgs like it wants to start, then you hear a click and it shuts off. Model HC125FVS
what u hear clicking is the relay on the comp. try getting another relay and see if that works if not sounds like a bad comp. ok try that.
Feb 12, 2011 | Haier Refrigerators
I LOST MY KEYS FOR THE COOLER WHERE CAN I BUY,OR HOW DO I OPEN THE DOOR
you will like this,same thing happened to someone i know and they went into thier local dealer and asked to borrow a key,the dealer said yes but will take a $25 deposit for the return within 48hours.
guess what.....the first key did not fit,but the third one did.....happy ending......i supose they could have taken the cooler to the dealer,but is was full of beer......
Aug 14, 2010 | Haier HC125FVS Wine Cooler Beverage Cooler
Is clicking on and off but does not cool or run
Sounds like an "overload and relay" on the compressor. This is the equivalent to a starter on a car. When they go bad, the compressor just does a "buzzzzz.. click" about every 5 to ten minutes. In the worst case, you may have a bad compressor, but this is less common. Hope this helps!
Dec 06, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
Power is on, lights come on but just hear a click
Odds are you have had an electrical storm and you need a new logic board.
Sep 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
I HAVE A HOLE IN THE REFRIG.LINE OF A HAIER MO.HC125FVS
Hi, unfortunate, sorry to hear that, but it could be repaired, you should immediately dried up water/ice around punctured area, prevent water/ moisture entering punctured area (evaporator. lines), it's one of the worst thing, that could happened to any refrigeration system, it will be costly to repaired, if water get into your evaporator lines, compressor oil have to be replaced, evaporator will need to be flush out, repair puncture, change filter drier, it's better to replace compressor, vacuum system for about 2hrs. then recharge. it's better to use welding/ soldering, to repair punctured line, epoxy repair kit can be used to repair punctured (evaporator) lines . you will have to call a mechanic, if very little water entered punctured( evaporator) lines, then flushing of evaporator, (internal cleaning of lines (tube) changing of filter drier, with overnight vacuuming will do the job. take note, job like this, cannot be guaranteed. check cost for repairs, sometimes it's better to purchase a new one, and save yourself some headaches.next time never use sharp instruments in your freezer, it happened to me sometimes, it's what you get your hands on, what's available at the moment, good luck.
Aug 15, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
Haier HC125FVS Wine Cooler Beverage Cooler Logo
277 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
