Question about Mitsubishi WS-55805 55" Rear Projection Television
First looked concave Now its dead
My set is 7 years old and worked fine the other day I turned it on and the picture looked bowed out like it was bulging out but had sound and then I turned it off and back on.The relay clicks and the little green power lite comes on but no picture or sound.....may be protection mode? There is a lot of dust in tnside and I sorta tapped on things in with power off but the set does not do anything and does not respond to the remote even power on button of remote.only thing works is the power button on the set.Oh yes with power on I hear a slight low pulsating hum. Any thoughts Thanks Zap
    Genius:
  • 1,074 Answers
Call a tech to repair you tv it is having problem in the power supply or related circuit.good luck.
Posted on Apr 14, 2007
2yrs old. Went thru 3 sets of batteries to get 20 pictures. Dead again. What`s the story?
Sounds like you have a short in the wiring. This is repair shop stuff, or buy a new camera time. Usually, if it is a point and shoot , it is not worth sending for repair as you'll playas much as a new camera is worth. I would look for a new camera, personally. Good luck.
Oct 20, 2014 | Cameras
Picture was fine, then lines diagonally, now light
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 10, 2009 | Mitsubishi WS-55909 55" Rear Projection...
Same situation, the tv picture is bowed on all edges
That is a convergence problem. You can get complete parts and instructiosn for this fix from TvRepairKits.com. They put together a kit for this. I used them for a convergence problem recently and they helped me fix my set.
Sep 05, 2009 | Hitachi 60UX58B 60" Rear Projection...
Picture in concave on all sides and blue and red are off
The shape of the picture indicates that the convergence circuit is not working properly. Generally speaking this occurs without making any sound at all. The popping you heard may have been a capacitor in the power supply. If the power line effected supplied the convergence circuit, repairing the supply should return the set to normal. If not, then the convergence ICs may be faulty. If you can solder, and are confortable working inside the set where potentially dangerous high voltages exist (even when unplugged), you may be able to repeir this yourself.
Let me know and I'll provide additional details and instructions.
Dan
Jan 27, 2009 | RCA P52960 52" Rear Projection Television
Picture is concaved and all the colors are off.
you will need to get a convergence done and the resistors on the conversion IC's checked and bad ones replaced
electech
Oct 30, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Picture Problem
I have the same situation. Called my repairman, who knew exactly that it needed a "570 kit" . It will be repaired this week. Cost $360
Sep 26, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi VS50707
convergence ICs stk392-110 you will need 2 of them.
Mar 07, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Convergence issue resolved but concave picture remains
Set will need new convergence IC's.Requires chassis pull===technical & mechanical skill mandatory.After repair,re-aligment necessary.
Sep 26, 2007 | Philips 55PW9363 55" Rear Projection...
Hitachi 61SDX01B picture...
Sounds like the blue convergence circuit still not working.
Assuming both IC's are good, look for open soldered-in pico fuse.
Once bowing problem is solved,then convergence should adjust ok.
Jul 27, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Mitsubishi WS-55805 55" Rear Projection Television Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
