In tray one there is a hidden compartment take a flat blade screwdriver to the cover as you are looking directly down at the top of the front of the drawer you should be able to open the top of the compartment. In there is what is called the birtcertificate for the machine and the original NVM settings are in there.
I have a Xerox 5826. It is giving me a message LL--MCB NVM faillure. call for service. Is there any good man to help? Thanks
This step will delete any print or copy job that is in process, and then perform a reboot.
To execute: simultaneously press and hold the 1, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
Spool Initialization
This step will delete all pending print or copy jobs in the job queue, and then perform a reboot.
To execute: simultaneously press and hold the 6, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
HDD Initialization
This step will delete all pending print or copy jobs in the IOT job queue (DC 3535: does not delete any job data stored in the Network Controller), initializes the IOT HDD (refer to ADJ 9.8 for details), and will and then perform a reboot. All customer data on the HDD will be deleted.
To execute: simultaneously press and hold the 4, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
ESS NVM Initialization
CAUTION
This routine will set all IOT ESS NVM values to default. Do not attempt this procedure unless there is a known-good Machine Settings floppy, an accurate Configuration Report and/or other data that will enable you to reload the correct NVM values for this machine.
This step will initialize the IOT ESS NVM (SYS-System and SYS-User) and then perform a reboot.
To execute: simultaneously press and hold the 3, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
If these do not work the system software needs reloaded or the ESS network board needs to be replaced.
3-315 Fault Code indicates that a communication failure
between the IOT PWB and the Post IPS PWB was
detected.
You may be able to enter diagnostic mode and reset:
Entering Diagnostic Mode: First of all... to enter the User Interface (UI) Diagnostic Mode: Turn on the power... then while holding down the '0' button, press 'Start'. The screen will prompt you for an "Access Number"... use the keypad to enter '6789' which is the Default Access Number. This should bring you to a menu of options to choose from:
• NVM Reset (Non Volatile Memory) / NVM Initialization
• NVM Read / Write (memory adjustments)
• Component Control (for testing sensors, motors, etc.)
• Print (for running Test Patterns from Diagnostics)
• Subsystem Check (for fuser nip measurement check out, and developer unit check out)
• Max Setup (for setting up copy quality)
If reset does not work, you need service on the unit.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
