Question about IBM ThinkPad A20 2629 Notebook
IBM Laptop A2629 LCD Problem
I have a IBM Thinkpad 2629
When the computer first starts up there is a pinkish hue to the screen and after a few minutes the screen goes black. if I press the lid close button the screen will come back on for a few more minutes but then go black again.. I can do this over and over again.. I've turned off all the suspension and hibernation settings i the bios and that didn't help..
My thoughts where the screen inverter or the video circuit on the mother board... other that this the computer runs fine... this happens even before the system goes to boot into Windows so I excluded windows being the problem...
    Master:
  • 413 Answers
Sounds like your video is going out wheather its your card or lcd not sure but kinda sounds like the screen
Posted on Dec 24, 2008
What size hard drive 4type2629
Welcome to Fixya. The size of the hard drive of your A20 2629 Thinkpad was 18GB. You can refer to the link below about the specs of the laptop.
Thinkpad A20 2629
Thanks for using Fixya.
Apr 14, 2011 | IBM ThinkPad A20 2629 Notebook
We don't know how to open the IBM thinkpad type 2629. We need a manual.
ibm has all the info you need just go to ibm support and look up your model and download the pdf it will show you everything you want and need to know. :)
Jun 15, 2010 | IBM ThinkPad A20 2629 Notebook
T23 Ibm laptop no video
Hello !
Test with an external monitor. If it works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Hope this helps.
May 08, 2010 | IBM ThinkPad T23 2647 Notebook
I power the device on and get the 'IBM ThinkPad' logo screen. Nothing happens after that
Since you are getting the IBM Thinkpad Logo it is confirmed that you have no hardware error. All you need to do is restore the operating system. most of the IBM laptop has an inbuilt recovery option. just press the access IBM/ Thinkvantage (blue button) immediately after pressing the power button and follow the screen..
hope this helps.
Apr 06, 2010 | IBM ThinkPad A22p 2629 Notebook
MY screen will stay on for 30 seconds, then goes black.
you Screen has a Soildation problem take it to near by electrition he will resolidate your screen and it will then work fine..
Aug 27, 2009 | Proview PL 566s 15" Flat Panel LCD Monitor
Laptop LCD display problem
The backlight is the light bult that illuminates the screen. Before it finally goes out completely it will turn your screen a pink color on startup (and then usually become brighter and the pink fades). It is also possible that the backlight, also called a Cold Cathode Flourescent Light, CCFL, died an immediate death. But usually they take a while and signal with the "PINKNESS" first. If you found that your computer is working just fine connected to an external monitor (and you moved the base of your laptop around while connected to the monitor to be sure and left the computer on for a long time) then you have verified that the screen is the problem. It is usually two things: (1) the inverter, a circuit board that increases the voltage to supply the LCD which eats around 700 volts (yeah baby); or (2) the backlight itself. The first problem is a relatively easy and inexpensive fix. You can find how to replace an inverter by downloading the Hardware Maintenance Manual for the T40, T41, etc., from IBM/Lenovo's site. Replacing the backlight itself, a bulb that is like a strand of speghetti and even more delicate, is a tougher job. I would suggest purchasing a replacement screen in that event rather than replacing the backlight yourself. (The HMM probably does not show you how to replace the backlight/CCFL as it is a potentially dangerous job.) That suggestion assumes you can find a cost-effective replacement screen and do not mind opening the TP and putting the new screen in. At least look at the HMM to see what is involved. Good luck.
Apr 07, 2009 | IBM ThinkPad T42 Notebook
I can't install XP on Thinkpad A20P #2629
im sorry to say this laptop is just not fast enuf to run windows XP you best bet for this would be to run windows 98 or a distro of linux that fits your needs  there are no bios updates at this time that will allow you to install XP on this system. sorry
Mar 27, 2009 | IBM ThinkPad A20 2629 Notebook
Back light on ibm t21
This is an known problem I think you must replace the backlight:
look for example ebay partnr: 260327530145
only for example if this is your problem.
PRODUCTS ITEMS
LCD CCFL BACKLIGHT LAMP IBM THINKPAD T20 T21 14.1" SCREEN
LAPTOP & MONITOR LCD SCREEN PROBLEMS
SOME COMMON SYMPTOMS FOR BACKLIGHT LAMP REPLACEMENT
- Flickering, red or pinkish hue to display and even total darkness. These symptoms are a result of a failed or ageing backlight or a failed, damaged. This is caused by the defective backlight lamp and all you need to do is replace the backlight.
DESCRIPTION
Our high brightness LCD cold cathode lamp (CCFL) with long life, it is more than 50000 hours, with Japanese new cathode, phosphor, glass, and other materials, they are perfect for all LCD backlight application and other purpose, such as instrumentation, medical devices, and all type devices.
COMPATIBLE MODELS
Suit for
Any 14.1” LCD Screen (2.0mm in diameter and 290mm Length) and (2.0mm in diameter and 292mm Length)
CUSTOMER SERVICE / CONTACT US
Email: mkproco@gmail.com (12 Hours Response Time)
Oct 14, 2008 | IBM ThinkPad T21 Notebook
IBM ThinkPad A20 2629 Notebook Logo
169 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
