Question about Brother MFC 420CN All-In-One InkJet Printer
Trying to print in black with no yellow ink
I have a Brother MFC 440 and my yellow ink cartridge is empty, why will it not allow me to print in black!!!!!????? This is very frustrating. Then I attempted to save it on a disc and my computer tells me to contact my admins. to gain access to that drive; I am the admins.!!! Now what?????? Please help!!!
  • 1 more comment
  • drive786 Apr 20, 2009
    where can i put the black tape on the mfc-490cw . thanks i.j
  • Anonymous May 04, 2009
    i have the same problem, I have black ink available but it will not let me
    print as it is saying I have no yellow
  • timaka_brown
    timaka_brown Nov 15, 2012
    GREAT TRICK IT REALLY WORK NO MORE BUYING COLOR INK!
  • 832 Answers
The black tape has to be places around the "nose" of the cart. If you look at the small front side of the cart, you can see a black platic flag. This flag signals the inklevel to the printer. Stick the tape around the flag so that it is covered in total. B/W only printing: If you only want to print/copy/fax in b/w choose the solution above and drill a simple small 1-2mm hole into the C/Y/M carts (e.g. into the brandname "brother" on top or the handle). The color ones will run dry, but the tape signals "full". After the color ones are down, air will be in the capillarysystem and part of the printhead, but black will work without probs (This will be the only cart to change when its empty!) :-) You can use the START MONO function for copy. You have to change the printerdriver settings to plain paper (for all type of paper!) and greyscale to print without any probs! Enjoy!
Posted on Sep 27, 2007
OMG! I am going through the same problem. I don't get it, my Cyan is out and my Yellow and Magenta are low and it won't allow me to print when my BLACK IS COMPLETELY FULL! WHy is this happening? I tried unplugging and reinstalling the ink packs but nothing works. Any ideas?
Posted on May 11, 2007
Thank you all. Black tape???????? Who would have thought it would be so simple. fixya.com is the best answer to all my troubles with computers.
Posted on Jan 18, 2010
Worked great!!! thanks for sharing the info!!!!
Posted on Aug 13, 2008
It realy worked thank u all
Posted on Nov 14, 2007
The black tape has to go on the end with the grooves. I've found it worked best to have a short piece of electrical tape and stick it to the middle, then use a small device to push the tape into the grooves on both sides of the middle. Once it's stuck in there good, just put it back in the printer.
Posted on Oct 08, 2007
On the blank tape solution for 420cn can some please very precisely explain where tape goes as I'm having no luck. many thanks!!
Posted on Aug 24, 2007
    New Friend:
Thanks so much! And to all the pole smokers at Brother big F.U.!
Posted on Dec 30, 2012
I was having this problem as well. I could scan or do anything. I tried the black tape trick. I went too far and covered the whole area in black tape as I didn't know exactly where the sensor is pointed. I'm considering a permanent marker when I get the chance. This solution might delay the frequent replacement. You will just have to watch the print quality more often.
Posted on Jan 29, 2010
    Problem Solver:
  • 4 Answers
I have an HP all in one with multiple ink cartridges. I have all printing options set to 'black cartridge only' and 'print in greyscale'. When I want to print in color I change the color settings. Having said that I found out like ya'll did that for some strange reason printing in b/w requires some yellow ink. I ran out of yellow and got error message but thanfully the HP prompts me to 'use black ink only' when it runs out of yellow so I can still print in b/w AND it looks just fine w/o the yellow. I still have no clue why printers 'demand' yellow ink to print in b/w.
Terri
Posted on Jun 02, 2009
I used white-out on the little ink window (in the middle of the back part). Worked great
Posted on Aug 28, 2008
Slick trick with the tape. I used white vinyl tape myself (since it was here on my desk) and worked fine.
Posted on Jun 16, 2008
Thanks a lot the black tape worked just fine !
Posted on Oct 19, 2007
The solution for the brother model MFC420CN. the color cart, its a very simple fix. This is what you must do. It's assume you are familiar with changing the cart already. Now, when you remove or replace color cartridges, follow this. On the top of the cart stamped with the 'brother', this is the side you must place the black tape.  First remove it, using this orientation, you will notice a narrow notch down this side, grab some black tape, and tape this side piece. make sure it's secure and snub to confirm with the cart original shape. place in printer. repeat for all remaining cart same process.
lastly, just unplug, and plug again, it will initialize and recognize ok.
I've tried this tonight after some careful inspection of this particular printer, it works!
Good luck! :)
Posted on Oct 16, 2007
I have always used 'multi cartridge' printers and in each case they have had to have a full set of cartridges in place to enable them to print, in whatever colour I require it to print. Personally I have no problem with this method as I always have at least one complete spare set in stock and replace each cartridge as it becomes empty. Perhaps, if you only wish to print in black it would be preferable to by a monchrome printer. However, if the black tape methods works then it is a solution.
Posted on Sep 06, 2007
Thank you for the black tape solution because that saved me money. I really thought my printer was te bomb, until now. I know now how to save extra money. Do you now the trick for if black ink runs out?
Posted on Aug 20, 2007
I had this same problem and I have a solution! very simple...take black electric tape, take a 1 inch strip and cover the bottom part of the ink cartridge (where it slides into the printer). The sensor reads the ink level and the electric tape bounces it back as full! problem solved. :)
Posted on Jul 27, 2007
I heard this is a deliberate ploy by brother to make you use up lots of ink. Allegedly they keep the cost of the printers down by making a fortine on the ink. The printer automatically cleans your cartridges without you asking and sucks out a bit of ink each time. Therefore, even if you are only printing black & white, it will quickly use up the colour ink. All four cartriges must be full and loaded in order to print B&W or colour. Brother will tell you it won't print without all four cartridges full. BUT there is a workaround for some models:- Take the cartridges out and cover them with thick black tape. This fools the sensors into thinking there is still ink in there and it will print B&W. Hope that helps. I will NEVER, EVER, EVER buy another Brother machine. I have a seething hatred for my Brother MFC. There are all sorts of faults, the manual is full of errors, it steals ink, the scanner won't work, the answer-machine is a joke and it interferes with incoming calls. My advice is - don't give them any more money. ! Good luck ! Wendy
Posted on May 17, 2007
SOURCE:
Brother- MFC 90CW black ink just replaced, but not printing, even the test print didnt print propaerly, it came out very light in other colours but not in black? what to do? is it a toner problem?
Thoughout my experience of fixing computers, I have seen this happen twice. Once was because the "new" ink cartridge was empty (which should cause the LCD display to say "cannot print"). the other was because the end user did not remove the protective yellow cap before installing the ink cartridge (yes, they made it fit). If neither of these are the cause you should try cleaning the print head. You can do so by pressing "ink", then scroll down to "cleaning", then scroll to black and press "ok".
Nov 06, 2010 | Brother MFC-5890CN All-In-One InkJet...
Printer keeps telling me that the yellow cart is empty and I have put a new one in
Are you positive it says the yellow cart is empty? Because that brother printer is designed to say that a cartridge is empty whenever ANY of the color cartridges are empty. Usually it doesn't tell you which one is really empty either. So even if you replaced the yellow cartridge and say, the black cartridge is empty, it still won't let you print until you replace that empty black cartridge, nor will you know which of the cartridges is empty unless you pull them out of the printer and manually check the ink levels.
Its pretty much a guessing game with those old brother ink printers.
Hope this helps :)
May 03, 2010 | Brother MFC-5440CN All-In-One InkJet...
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
Wont print
what are you trying to print in black? the best way to test out a black ink is to open word pad and type some thing random and print it and see if that works. if you have a all in one printer u might have 2 inks one color and one black in the printer
Jun 01, 2009 | Brother MultiFunction Center MFC-440CN...
BROTHER MFC 440
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Brother MultiFunction Center MFC-440CN...
Replaced ink cartridge printer continues to say no cartridge
you need to follow the whole procedure on your to ensure proper installation as soon as you install the new one, follow the instruction on the screen to calibrate your new ink
Nov 08, 2008 | Brother MFC-440CN InkJet Printer
Printer says ink near empty
Black electrical tape works like a charm on a Brother MFC-465CN. Thanks for the tip! :-)
Jan 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
3,799 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
