Question about Philips Car Audio & Video
Philips rc026 cd changer not working.
I have a philips rc 026 cd change manufacture fitted but the cd does not work. the fuses are ok but not power what can i do
Eagleeyes
  • 199 Answers
SOURCE: CD NOT WORKING
Ok guys thius it how it works.
Blaupunkt supply a repair kit for this unit, this basically is a fix. but only works for 8 out of 10units.
its a pain to fit too.
you have to replace the 3 spindle guides and arms. the part number is : 8619001490 there a reall complicated thing to fit.
i am looking to get a install guide sorted. and will soon be selling the kits on my website
www.carradiospares.co.uk
Regards
Mark
Blue ICE
Posted on Feb 24, 2008
pjstanley
  • 185 Answers
SOURCE: renault espace radio / pioneer cd multi changer
iwish i can help but i cant
Posted on Jun 02, 2008
freetek
  • 5568 Answers
SOURCE: CD CHANGER EJECT BUTTON
Inspect the tray or door to see if there is a very small hole in it. If so, this is an 'emergency' ejection hole and a standard paper clip, unfolded, can be inserted there to manually eject the tray. This is a real common problem caused by the slippage of a clutch mechanism that is supposed to protect the tray mechanics from being damaged if the tray is somehow impeded during its travel.  It must be tougher than rocket science to properly design this feature -
Posted on Oct 28, 2008
SOURCE: cd multi changer
I understand that there is a 'clear' or 'reset' button on some cd changers that must be pressed after unit is connected in car. The instructions for my model said to use the tip of a pencil.
Posted on Aug 13, 2009
SOURCE: 6 disk CD changer in 2004 Chevy Suburban
I am having the same problem with my CD changer in a 2004 Suburban. Have you found a solution yet? Chevy dealership told me that I would have to replace the radio.
Posted on Feb 20, 2010
My car battery died.when i put in a new my cd player stop working
If your radio is still working, then your power is OK. The Sony CD changer gets its power from the Sony Unilink cable. It is possible that it passed a power spike down to your CD player while hooking up your battery cables.
I just had a CDX-757MX just die a few days ago myself. My radio, amps, and other changers are still working. Could be an unfortunate coincidence.
Sep 09, 2009 | Sony CDX-454RF 10-Disc CD Changer
No power to cd changer
use a test light and go through all the fuses by checking each post on the fuses
Mar 21, 2009 | 1999 Ford Explorer
Kenwood kdc-c710
It sounds like a blown fuse to me, or problems with the power to the player. Check all connections and power to the unit.
Take special care to make sure you know where the unit gets power from, it could have more than 1 fuse.
Regards
Philip
Jul 19, 2008 | Car Audio & Video
I have a philips cd player model# FW-C70/37, that has power going to it but has no sound coming from any of the speakers, nor will the cd changer open.
cd players work without use of volume controls coax cables hook up's and then by setting reciever to proper button so sound can come out
you might have had a power surge that fried your system but lets look at easy stuff first
fuses
lines in properly and connected
test on an old sterio with speaker hook ups and test your speakers by plugging in to old beat box
make sure wires are not scorched
turn on receiver fm see if speakers work change channels to sterio and mono settings if speakers start to work on sterio or mono setting chances are power surge blew out your system
hope this worked
May 07, 2008 | Audio Players & Recorders
Cd changer will not work
I had the same problem with my 2002 307SW.
I read on another forum to switch ignition off, remove CD changer from dash and disconnect. It then told me to remove the lid from the case unscrewing the screws marke 1 to 5 then remove the Cd's. The only problem with this is you need a special size 'star' driver bit which i did not have at home and could not unscrew them. What i did was to use a terminal screwdriver in the 2 larger screws that fasten the front plastic cover on the unit. Once I had done that I could remove the CD's.
I then connected the changer back up and inserted it back into the dash. I then powered the radio back up anf loaded a CD and the problem had gone away so I loaded the 5 CD slots and everything works fine now.
Jan 09, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
CD NOT WORKING
IT MAY HELP IF YOU CAN REMOVE THE CD PLAYER AND THE POWER LEAD THEN REMOVE THE CD'S FROM IT (WITHOUT FORCING THEM) AND THEN RECONNECT THE POWER
Nov 06, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
Car Audio & Video Logo
122 people viewed this question
Top Philips Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Philips Car Audio and Video Expert? Answer questions, earn points and help others
