Question about Maxent MX-42V1 42 in. Plasma Television
Picture transitions from blue screen to red to green and to white
While watching TV during a heavy rain day (I've dish network connection), the picture went off and after the satellite picked up the signal again the screen went red then green then blue and white over and over; sound could be heard and I could not turn it off either through the remote or the off button on the TV itself; I unplugged the TV and plugged back up again afer a few seconds, the picture came back for a few minutes but it went back to the colored screens
SOURCE: Maxent 42' Plasma sound but picture looks like red, green and whites digital specks
the color card in the plasma is not okay.ihad the same problem and fixed it.
Posted on Apr 25, 2007
SOURCE: color patterns
Mine did the same thing,I sent my in to costco to be fixed and I was told it was the main board that went out. Hope that helps.
Posted on Sep 01, 2007
SOURCE: My Maxent turns off when it comes back on it has dark colors.
goto maxentuse.com, open user manual and look under troubleshooter.
Posted on Jul 28, 2008
jewellgirls
  • 12 Answers
SOURCE: Maxent p4202yd05
have you tryed to find the "lamp" on it ... it sounds like your lamp has gone out you can get them from walmart or best buy or another type of electronics stores... they are normaly cheap compared to the price of a new tv and all it is is a light bulb for your tv... good luck to both of you
Posted on Oct 16, 2008
SOURCE: Maxent 42" Plasma TV takes 3 - 5 minutes to sync after turning on
I had the same issue....thankfully, I had purchased an extended warranty from Best Buy...I had been in a panic, because I NEVER thought I would pay a grand for a tv, but I LOVE it...anyway.....I had the "Geek Squad" come to look at the tv....the tech took 30 secs....there is a problem with your Y-SUS (Y-sustain board)...it will need to be replaced...and...the tech called another tech, and he advised that the Z-SUS be replaced as well (apparently he had to go back to the same home after a Y-SUS replacement to change out a failed Z-SuS).....retail on Y-SUS is about $300...ebay has them for less than half that, if you think you can do it yourself...keep in mind that "Maxent" is a Zenith/LG product, so finding parts might be a challenge if you base it upon Maxent....hope this helps!!
Posted on Mar 14, 2009
IGO tv connected with dish sound come from tv but pictur not show only blue color show
Component RCA Connectors are RED, BLUE, GREEN for picture. Sound is RED and WHITE. The red and white for sound work the same with the YELLOW that does picture. If the RED, BLUE, GREEN are in the wrong order you will get a blue or green picture. For the sound, try the other red and white connectors nearby. Make shore the right red connectors are connected correctly for sound or picture. Otherwise there could be a cable fault or a TV fault. If you get the picture right but not the sound, connect the sound into a stereo.
Jul 17, 2017 | Televison & Video
I have a Sony model KF-50WE610 tv. We moved it today and once it was set back up the picture is black and white. I have checked all connections, cables, and signal and nothing makes a difference. It is...
The cables connected are in the wrong spaces, either on the receiver or the television. Using component style cables, Green, Red, Blue for video, and White, Red for audio, one of the video cables is in the wrong spot. Using RCA type cables, Yellow for video, White, Red for audio, the Yellow is inserted into a green component somewhere. The ViP 722 is compatible with HDMI, which has a much higher resolution (1080p max with the ViP 722) and a better refresh rate (the ViP 722 max is 30Mhz), and as there is only one cable for both audio and video, is much easier to use, if your TV is compatible, you should look into using HDMI instead,
Jan 25, 2015 | DISH Network Televison & Video
I have a flat screen and Dish Network for my cable. I switched the "source" to watch a dvd, and when I switched it back to channel 3 I have a blue screen. cable (dish network) is on and working....
It all depends on how your dish cable is connected to your television. The possibilities I can think of would be by composite cables (not HD)--these cables are the yellow red and white combo. It could also be component--the video cables are the blue, green and red. The other possibility is a single HDMI cable which looks like a rectangle and delivers both the video and the sound from the cable source to the T.V. as one cord. Depending on which of these you are using to output the signal from the cable box to the T.V. will determine which "source" you should select when trying to watch tv. Hope this helps!
Aug 25, 2011 | Niko Televison & Video
NO VOLUME AT ALL - GREAT PICTURE We have Dish
You will want to start by unplugging the receiver for ten aseconds. If this doesn't resolve the issue check the cable from the receiver to the TV if it is a single cable with a flat end then just ensure both ends are firmly connected. If you are using component cables with 5 colored ends (red, green, blue, white, and red) make sure the red and white audio cables are connected on both ends. If this fails to resolve the issue reply to this and I will get back to you!
Daniel Busa
DISH Network
Customer Service
Jun 24, 2011 | Sharp LC-32SB24U 32 in. LCD TV
My picture is in green. The convergence seems to work just fine. Why would my screen be green?
You might have the yellow for video, white, and red for audio (composite connection) plugged into the component plugs green, blue, red for video, white, and red for audio (component connection) somehow combined together on the back of your TV to whatever source your watching.
It should be color to color from your source to your TV.
It's that or only the green plug is plugged in for the component video. Hope this helps.
Jun 20, 2011 | Zenith R57W46 57" Rear Projection...
The screen displays in black and white
Hi:
First thing is to determine what type of video connection you are using to watch TV.
If you use componet video cables to watch tv check teh green cable to make sure its connected also check the red and blue because if the green come off the picture will appear B&W
May 31, 2011 | Coby TF-TV1514 15 in. LCD TV
I have the dish network box which is HD although I can get a video feed on the television I get no audio
The first step you want to try is unplugging the receiver for ten seconds. After that check the cabling if you have component cables (red, blue, green, red, white) make sure the red and white are connected firmly. Also make sure they are connected right next to the red blue and green cables on the back of the TV. If you have an HDMI cable try connecting it to another port on the back of the TV. If that fails try replacing the cable.
Daniel Busa
DISH Network Customer Service
Jan 30, 2011 | Samsung PPM42S3 42 in. Plasma Television
I,ve connected my wii to the led tv using a wiii component cable(5 leads) but have used only 3 of them red green & blue 1,s leaving a red & white 1 left i have good picture but no sound help please
your cable is split into two different connections for your tv... the red green and blue cables are for HD only. They are their own little set. the yellow cable is your video cable for normal tv's. the red and white cables are sound cables, also for normal tv's. I would unplug the red, green, and blue cables, and use the yellow, red (right sound), and white (left sound).
Dec 31, 2010 | Nintendo Wii Console
How to connect to TV
The Yellow/Red/White connectors are Composite+Audio
Yellow carries a composite signal and Red and White Carry left and right audio channels.
Red Green Blue Connectors are Component
Each coloured connector carries one 'component' of the picture
So yes, your extra set of red white yellow cables would be fine to use, just make sure you connect the same colors at each end red-red green-green blue-blue
However..... the red green blue only carry the video, you will still need to carry the Audio, this is usually done either by the red and white (L & R stereo) or your DVD may also have an optical or coaxial output to carry the sound. if there is no equivalent connector on the TV then you may be stuck swapping the red/white cables, usually though there would be 2 sets of red/white connectors one set to go with the yellow, one set to go with RGB.
Apr 22, 2009 | Televison & Video
I have picture by no sound. It's on video...DP42647 model We use dish network
I am going to assume this is a self install meaning you just got a new tv. If you have an HD receiver connected with red/blue/green wires ensure that you also use a set of red/white from the same TV output on receiver to the same audio input on the TV that you have the other wires ran to as the RED/BLUE/GREEN only carry a video signal. Some poor quality HDMI cables will also require the same red/white wires to gain audio as they do not always function properly. Other than that I can think of no other reason you should not be receiving audio other than internal speaker in tv being turned off. This usually is true when a surround sound is in use but the dish receiver was not integrated into the surround but the TV itself. I hope this is of some assistance to you. Thanks for using Fix Ya and if I can be of anymore assistance please let me know.
Oct 08, 2008 | Televison & Video
Maxent MX-42V1 42 in. Plasma Television Logo
35 people viewed this question
Top Maxent Televison & Video Experts
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
