Question about Yamaha RX-V463 Receiver
Ccr1cd keeps turning off my yamaha receiver rx-v480 keeps turning off when i turn it on
    Novelist:
  • 236 Answers
Check your speakers cables, connections. check for possible cable short. If seem ok, remove all speakers, turn the unit on and see if still turning off. if it does then you have a trouble in your power amplifier, defective output sectiuon. could be your power and driver transistors. possible dirty or corroded system control board. try cleaning.
Posted on Feb 10, 2009
How do I set the clock on my ccr1cd?
stevej9_98
SOURCE:need instructions for Wharfdale ccr1cd micro clock alarm
Press the STOP/CLOCK button for about 3 seconds till the hour number flashes
use the forward and reverse buttons to set the time on the hour
press the stop/clock button again to move on to minutes numbers
use the forward and reverse buttons to set minutes
Press the stop/clock button again to complete process
Posted on Mar 28, 2010
May 27, 2018 | The Audio Players & Recorders
Yamaha receiver keeps turning itself off model .RX-V490
Have you tried the unit without any speakers connected at all?
Oct 31, 2016 | Yamaha RX-V490 Receiver
Connection of a subwoofer to yamaha rx v480 receiver
Get an output from the receiver pass it through a crossover and you will get a low frequency signal , plug in into the sub..there you go.
Feb 09, 2014 | Yamaha Audio Players & Recorders
Re: Yamaha RX V670 Receiver Powering Off
I have found there are capacitors failing through the output circuit. Look for 10, 33, 47, etc.. microfarads.In that range. I charge typicaly 150 to $200 with parts on something like this. Larry's Electronics ledstiles@hotmail.com
Apr 23, 2010 | Audio Players & Recorders
I have att an uverse remote that turns on my Yamaha receiver, but won't control the volume. Model No rx v480
You need to try other codes for Yamaha, as clearly the one you have put in the remote is incorrect, perhaps it was for an earlier model.
Mar 07, 2010 | Yamaha HTR-5730 Receiver
Yamaha RX-395 receiver problems
This may be a relay problem, could be fixed for under 100.00 this is a normal problem for this unit.http://www.nextag.com/yamaha-home-theater-system/compare-html
Feb 18, 2010 | Yamaha RX-395 Receiver
Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
Jan 06, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Jan 02, 2009 | Yamaha RX-V995 Receiver
Yamaha RX-890
I have the same problem with a RX-V995 Yamaha Reveiver.
Tim
Sep 05, 2008 | Yamaha RX-V995 Receiver
Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Jun 04, 2007 | Yamaha RX-V2600 Receiver
Yamaha RX-V463 Receiver Logo
316 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
