Question about Microwave Ovens
Microwave - Keypad (Maytag MMV5156AAQ Over the Range )
Several buttons on the keypad are not working or responding. Does this (can this) be replaced?
  • Microwave Ovens Master
  • 9,098 Answers
Yes.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 26, 2008
Having an issue with the keypad - not responding
I would contact Samsung, they seem to be aware of the issue with the control panel failing on there otr model and are replacing them free of charge under there "epidemic warranty"
May 06, 2013 | Samsung 1.8 Cu. Ft. Over-the-Range...
Maytag microwave keypad
see this causes and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Troubleshoot maytag keypad control board
Oct 01, 2012 | Maytag Appliances Over-the-Range Microwave...
Microwave does not work nothing on the control pad work the pad just says se
Hello
Check the power supply. Make sure the microwave is firmly plugged into a working electrical outlet and that your wall outlet is active if your home uses outlets controlled by a wall switch. Check your home's fuses or circuit breakers to ensure they have not been tripped. Without power the microwave will not respond to any input.
Make sure the parental lock is inactive. Some ovens, like the one shown in the image above, feature a keypad lock to prevent children playing with the controls. Most keypad locks can be cancelled by holding down a button or combination of buttons for a few seconds.
Make sure the door is firmly closed. Some microwave ovens will not allow any control panel input if the door is open.
Remove the microwave from the power, wait 10 seconds, then plug it back in. This will reset the microwave oven if there is a temporary problem with the software.
Press the "Stop/Cancel" button several times to cancel the current operation and return the microwave to standby mode. Re-enter your cooking instructions using the keypad as usual.
Oct 04, 2011 | Maytag Microwave Ovens
Error code SE on Maytag Microwave
The error code SE stands for " Systems Error " which indicates there is a short in the keypad membrane causing the system to lock up. The only option is to have the keypad replaced for normal operation.
Mar 27, 2011 | Maytag Appliances Over-the-Range Microwave...
Screen displays -SE- , none of the keypad buttons work
The word -SE- , means systems error, the cause is a short in the membrane of the keypad. The only solution is the keypad must be replaced.
Mar 05, 2011 | Maytag Appliances Over-the-Range Microwave...
My over the range microwave is not working properly the buttons are not responding. there is any thing can do to fix his problem
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it's still not working, you probably have a bad membrane keypad.
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If it does not dry out over time, it may need to be manually dried or blown out.
If the keypad is bad, you may need to replace the control panel frame, which comes with a new keypad.
To order Goldstar / L.G. parts, visit Encompass. You'll probably have to call them at 866-779-5835.
Aug 21, 2010 | LG Over-the-Range Microwave
Keypad barely works
Keypad replacement is something most DIYers can handle okay, or for only $39.95 plus parts, we do them for customers nationwide.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 16, 2008 | Maytag MMV5000 Microwave Oven
LG LMVM2055SB over the range microwave keys not working
Is it possible someone may have sprayed cleaner directly onto the keypad area?
This causes moisture to get into the keypad and sometimes onto the control board.
This could mean that they control panel frame with keypad (membrane switch) would need to be replaced.
Can you give more details on the cleaning?
Nov 18, 2007 | Microwave Ovens
At times some butons don't work
You may have a bad keypad, which in many cases can be replaced.
A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated.
Moisture and contamination can be caused by not using the fan when boiling on the stove top (for over the range models), direct spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation.
I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller.
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Aug 10, 2007 | Hotpoint RVM1425 Microwave Oven
Microwave Ovens Logo
403 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
