Question about Pioneer 6CD CHANGER
How to remove disks from teh CD changer - Pioneer 6CD CHANGER
How do i unstick disc from hp pavilion mx70
Posted on Jan 15, 2009
Cd disc changer
As with ALL disk drives, you need to dissemble the changer to remove the disk by hand. Usually not as bad as it sounds, have done it many times.
Dec 31, 2013 | 2006 GMC Envoy Denali
Got cd struck in factor 6 dis changer 00 mitsubishi diamante
If the disk is stuck in the changer then the changer has a defective part and will need to be removed and sent out for repair, Send a note with it that you want your CD back with the repaired changer.
Sep 12, 2012 | Cars & Trucks
2004 GTO will not eject CDs, says CD mech error.
I just had this happen the other day. It completely jammed up. I ended up having to remove the radio and disassemble the upper changer section to get the disks out. The problem with mine was that one of the disk trays broke and jammed the mechanism. I ended up gutting the changer and and reassembling the radio and installing it in the car to use the AM/FM function. I'm currently in the search for a new radio to swipe the CD changer off of since even radios that you do not have the security code for will work as the coding is in the radio section and not the CD changer. The changer attaches to the top of the radio with 2 T8 and 4 T10 screws and connects with a ribbon cable between the two modules. You'll see the ribbon cable when the top CD changer mechanism. Be careful removing CDs this way as if the player's rotating assembly is not retracted, it is very easy to scratch the disk. Unfortunately I lost a Velvet Revolver disk this way. Good luck! If you are on one of the the big boards I go by TR GTO on both if you need to contact me and I'll walk you through it.
Jun 23, 2011 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd is stuck in 6 cd changer and it wont come out or play
I had this problem with a CD changer in my vehicle once. I had to remove the Changer and open it up to get the disk out.
Jun 20, 2010 | 2004 Honda Accord
I have a 5-6 year old 5 cd changer and a cd is stuck in it and It will not open. I cut all power to it, but that did not work.There is no info in the manual regarding what to do if this problem occurs. I...
Is the unit a rotary feed (meaning its a round wheel with all disks on same level and when the tray opens it rotates to give access to teh disk) or cartridge type where you load the CD's into a cartridge and then teh cartridge into the player? If its a rotary type once the power is cut you can carefully pull the drawer out... Do it patiently and gentle...rush it or pull too hard and you will strip gears. POWER MUST BE OFF or the motors will resist and you will strip gears too. Once out you can reach teh CD. If its a cartridge type some support sites from manufactureres have an all eject process by pressing the power button and eject button at same time. If the disk is STUCK/Misfed and has caused a misalignment then none of the CD's would change and in that case you would have to determine if you want the CD player or CD more as you are going to have to dissasemble the player to access the disk.
Jun 02, 2010 | Audio Players & Recorders
Cds are stuck in the changer
Hi.
Ensure that the CD changer is powered, check cable and connection.
Disconnect battery for one minute and try again.
If that does not work, disconnect battery again, and try repeatedly pressing the eject on changer while someone else connect power back.
If that does not work the changer must be taken apart to remove the disks. Disassembly involves removing external cover, and usually it is not too complex.
Regards.
May 22, 2010 | Jeep Liberty Six Disc CD Changer -...
Cd System in 2000 Chrysler 300M
Had same problem wit my 4 disk. A CD was jammed. Remove and open the unit up and remove the CD. The mechinizem might be jammed also. Try this before replacing. Seems like a common issue with these units. The newer 300Ms came with 6 disk changers.. not sure if these will work with the existing radio.
Oct 19, 2009 | 2000 Chrysler 300M
6-disk cd changer in '03 silverado z71 is jammed
the radio is failed internally, you need a new radio - its possibly jambed and you can remove the top plate on the radio and remove the discs - but it might lock up again
May 25, 2009 | 2004 Chevrolet Silverado 2500HD
Jeep RDS CD Problem
Did you change the battery ? If so try disonnecting and reconnecting the CD changer.
Dec 27, 2008 | 2005 Jeep Grand Cherokee
1998 - 2002 Honda Cassette 6 disk CD changer Radio
the cd changer is malfunctioning, the factory cd changers usually don't last that long because of the heavy use and many mechanical puts
Jul 29, 2008 | 1997 Honda Accord
Pioneer 6CD CHANGER Logo
122 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
