Oce cs2044 error message "check printhead"
I push "OK" and then push "online" and all is well. But I have to do this for each plot. Is there a way to turn off the error message? Everything works OK and the printhead is apparently also OK.
  • Anonymous Jan 23, 2009
    Same problem as scluck's
3 Suggested Answers
  • 75 Answers
SOURCE: HP Designjet 1050c begins to plot, then stops
you need to lubricate the slide bar with some thin oil ( sewing machine oil).put the oil on your finger and then touch the bar this way you wont spil oil into the printer
Posted on Nov 04, 2009
  • 202 Answers
SOURCE: I have a HP1050c plotter
Hello Dear .....This type of problem occurs when one of the print head completed his duty cycle, so pls replace them as indicated by machine.replace them your problem will be resolved.give the rating if problem resolved
Posted on Oct 28, 2010
Oce Colorwave 600ps errorcode 16702 what does it mean?
The media output sensor didn't detect the media in time.
Ensure that you are not pulling your plot out before the CW600 actually delivers it. The CW600 stops printing, cuts the plot, delivers it to the top delivery tray, but pauses for a second before fully delivering it to the tray. See if you get the same problem if you output to the rear. If this problem persists, please call an authorized Oce/Canon service representative.
Apr 06, 2017 | OCE Office Equipment & Supplies
Oce TDS 300 Printer. Erore Prob. Hi I have a printer Oce TDS 300, I Get A new Erore code 8507,i want A Solution
Turn off the printer, and let it cool for an hour. The problem will return, but you may have the ability to get some emergency plots out in the mean time. The error code has to do with a thermistor in the fuser section. These thermistors are made out of a delicate ceramic and are easily broken or cracked if installed incorrectly. I would recommend that you call an authorized Oce/Canon service representative unless you want to spend several hundred dollars on incorrect, or broken thermistors you may get via other official channels. Each Oce model may have a different rating of thermistor, so just putting any thermistor in most likely will not solve your problem and may cause others.
Mar 10, 2017 | OCE Office Equipment & Supplies
My oce fx 2081 trouble code 05 help me pleas
OCE clear error message replace toner oce fx 2081 ... - Fixya
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ... > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
Sharp ARM 550/620/700 Reset Machine with Error Code ...
Dec 15, 2015 | Office Equipment & Supplies
Printer screen had update message. After I pushed the OK button, it gave error code Oxba10AACC
Hi Wendy!
Sorry to tell you but OX___... messages means "failed printhead or ink system"
You should try to change the printhead because an error occured and the printhead it's no longer working
Hope you found it useful, for every futher question i'm here
Source: HP Troubleshooting
Dec 04, 2015 | HP Office Equipment & Supplies
Our Oce Plot Wave 300 is going through toner very fast. The toner waste bottle is supposed to last through two toner bottles but fills up in less than one bottle. The OCE technician has looked at it but...
the service engineer is right, Pl. check the resolution of the printer, next check the toner cart. if possible try disconnect the ground connection to the doc.blade.
Mar 03, 2015 | Office Equipment & Supplies
Why am I getting the error code 22550
It would be helpful to know the exact model number of your printer and the software level. If this is a PW300, it is an Initialization Error. Something is out of place that is not allowing the printer to start up properly. Opening and closing the lids may temporarily solve the issue but if it keeps on returning without having jams, there is either a sensor problem or the code level may need to get upgraded. New code levels have fixes that prevent false jam indications.
Jun 24, 2014 | OCE Check Plot Bond Paper, 20 lbs., 34" x...
Error code on oce colorwave 650
It is a printhead or "imaging device" issue. Call your authorized Oce/Canon service representative. These printheads are proprietary and not available outside of official channels. If you find one outside of official channels be wary of the quality. If there is a a color in in the tube of where the toner pearl goes in, it is a used head and can not be used in any other color except the one that it was originally intended.
Apr 12, 2014 | OCE Office Equipment & Supplies
HP Designjet 1050c begins to plot, then stops plotting with the error message "Turn of printer, check printhead path". What is the problem?
Nov 03, 2009 | HP DesignJet 1050c InkJet Printer
Error in Oce 9400 Plot Director Win 2000
There are a few possible solutions.
First, only the last version of Plot Director (3.4.3) works in Windows 2000, so make sure that is the version being installed.
Secondly, once PD is installed and uninstalled all registry references must be removed before attempting to reinstall or you will encounter errors.
Third, make sure you have Administrator privileges when installing or editing the program.
Last, because there has been no development on PD since 2001 it may be having issues with security, such as the ability to edit files that are in a protected zone or communicating thru a firewall.
As a test make sure that none of these programs are active during installation or configuration.
Feb 20, 2009 | Office Equipment & Supplies
595 people viewed this question
