Question about SanDisk Sansa e260 MP3 Player
If sansa put to charge it only shows the round blue light
Only blue light glows and after that is neither gets start nor closes
  • Ricky Rocket Dec 26, 2008
    When I charge it I only get the blue light around the dial and nothing comes up on the display.
    President:
  • 948 Answers
Try resetting the device by holding down the power button for about 20 seconds. I'd try a firmware update if that doesn't help - http://www.sansa.com/support/sansa_e200/troubleshooting
Posted on Dec 25, 2008
Batteries keep going flat
No it does not, there is no connection.
If the alternator was not charging, your charge light should glow to tell you that. If the charge light is NOT glowing while driving, then you simply have a dying battery which cannot hold a charge for long.
The oil light not glowing when the ignition is turned on shows only that the globe has failed.
Jan 25, 2014 | 1997 Mitsubishi Montero
Advent Roma 1001 laptop. Turning on the laptop via the mains supply, the laptop springs to life and have no problems. The battery icon shows 100% charged and the battery l.e.d. light glows blue. Turn off...
The fact that the laptop is recognising the battery's presence and yet is not receiving any power from it is not a good sign I'm afraid. There are batteries available online for around £40 but you may want to take the laptop to a repair centre first where they can usually tell you (for around £7-£10) if it is definitely a battery malfunction or not before you splash out on a new one.
Sorry I can't be any more help, battery issues are usually pretty black and white, they're either broken or working. Hope you manage to get it sorted either way.
Jan 17, 2011 | Advent Netbook
I have sansa e250. when i switch it on only blue light glows all round the joystick. i could not switch on my sansa. i tried resetting by pressing menu key for more than 15secs, also i removed and...
i have sansa e250. when i switch it on only blue light glows all round the joystick. i could not switch on my sansa. i tried resetting by pressing menu key for more than 15secs, also i removed and re-installed the battery but it is not working. pls solve
Oct 21, 2010 | SanDisk Sansa e250 MP3 Player
I was listening to my sansa mp3 and it stopped playing. Center neon blue circle is on and glowing but screen is blank and no sound comes through. Computer does not recognize it either.
First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
Jun 12, 2009 | SanDisk Sansa MP3 Player
Will not come on only the blue navigator button light works
Try connecting it to your computer. Once here, go to My Computer, and right click on the device. Scout for "Format Device" or something similar. If you don't see it, scout around. Try opening the device and looking there. This deletes the device and resets everything.
Jun 07, 2009 | SanDisk Sansa e260 MP3 Player
Won't turn on, computer won't recognize it anymore...
Comment by c-lesha, posted on Jan 06, 2008 mine won't charge shows sansa in blue then lock pic then turns off won't turn back on doess this every time i put it on charge when in "charging" it shows a little blue box if it is showing the locked picture then it is locked and you need to hit the switch on the side to unlock ~Temp
Jan 06, 2008 | SanDisk Sansa m260 MP3 Player
Doesn't do anything??
Remove the battery for about 30 seconds or so. Put it back in and restart it. This should work. Mine does the same thing.
Nov 20, 2007 | SanDisk Sansa e260 MP3 Player
MP3 problem
Mine does this, and so does my friend's player. Just unscrew the back, remove the battery for 30 seconds, put it back together. Works for me.
Mar 17, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
42 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
