Question about Maytag MGR5875QD CleanDesign Gas Kitchen Range
Maytag MGR58750DB oven not working properly
The oven will not heat to the selected temperture. It will slowly heat up but then stop. For example, if you select 425, it will slowly heat up and the maximum it will get to is 200.
  • 2 more comments
  • bberg Dec 24, 2008
    So how do I fix that? If the door is closing properly....
    Is it easy enough to replace: the sensor?
    the thermostat?
  • bberg Jan 02, 2009
    This started happening after the oven was run through a self clean cycle, can this have caused it?
  • bberg Jan 05, 2009
    Thanks. This seems to be the problem. How long should these last?
    Sergeant:
  • 311 Answers
Hi bberg thats your ignitor.its right at the brink of failing.so because of its weakness it lets some gas in then gives up and then will try again.its located under the oven pan and a failing one will have a soft glow,new one a brite glow.you can buy one one line or at your local appliance store.about 50$.please help me with my rating if i have been helpful.God bless ypur house,tom
Posted on Jan 02, 2009
  • 470 Answers
Note that in some cases, but not all, when the fan oven element fails it will trip the consumer unit's rcd. Once it is reset the following symptoms will be apparent:
1. Fan oven is not heating up, however
2. The fan in the oven is working fine, and
3. All other functions of the oven are working ok
4. The thermostat light does not go out.
5. On removal of the Fan Oven Element (see below) there are visual signs of burning, blowing, or splitting etc.
6. Using a test meter the Fan Oven Element is ‘open circuit’.
First of all ALWAYS isolate the oven/cooker from the mains supply.  If your oven is ‘hard-wired’ in then turn it off at the wall AND at the consumer unit.  These types of installations SHOULD have there own circuit to isolate at the consumer unit.  NEVER rely on the switch alone.  Some of the modern single built in ovens use a standard plug; ensure that it is removed before you attempt to replace your fan oven element.
  • Antonio Buenafe Jr.
    Antonio Buenafe Jr. Jan 03, 2009
    yes it can cause it, especially if you were not isolate the main switch pattern,, in you have a general clean on it,, you should open and put a safety measures on it to prevent contaminant
  • 1,031 Answers
  1. Make sure the controls are set properly: that the oven selector switch is set correctly and that the temperature switch is set to the desired temperature. Where applicable, make sure the oven timer is set to manual.
  2. If nothing else on the Range, Oven or Cooktop is working then:
    1. Check the circuit breaker or fuse.
    2. Test for power.
  3. Test the oven elements
  4. Test the oven thermostat.
  5. Test the oven selector switch.
Posted on Dec 24, 2008
  • 4 more comments
  • Starnley Johnwells
    Starnley Johnwells Dec 24, 2008
    The oven heating elements are large resistor wires with enough resistance to generate significant heat. There are two heating elements in each oven: a bake element and a broil element. The bake element is found on the bottom of the oven, while the broil element is found on the roof of the oven. On some models, the bake and broil elements will work simultaneously to preheat the oven cavity
    1. Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!
    2. To access the bake element open the oven door, remove the oven racks and then remove the screws that hold the element in place.
    3. There is normally a small amount of excess wiring attached to the terminals on the element that allow a little room for maneuverability (you may have to tilt the element to get the terminals through the holes). Look for loose or disconnected wires and if there is no sign of burning, reconnect the wiring to the back of the terminal. If a terminal end is damaged, replace it with a terminal end designed specifically for oven use only.
    4. To remove and test the bake element, slide the element forward and remove the wires by removing the screws from the terminals or by pulling wires off the bake element terminals. Remember to label the wires for future reference.
    5. Visually check the entire element for signs of burn.
    6. Test the element for continuity. Using the ohmmeter, set the range scale on R x 1 and place the probes on the element terminals. There should be continuity, with readings ranging from 19 to 115 ohms. Readings will vary from manufacturer to manufacturer and according to unit size and the wattage. Be sure to check your manual for the manufacturer's specifications.
    7. If there are any signs of element burning, or if there is no continuity, replace the element.
    8. To test for a grounded bake element, place one probe on the element outer surface and the other on the element terminal. If continuity exists, the element has shorted and should be replaced. Remember to test both terminals.
    9. To install a new back bake element, reverse the disassembly procedures (Step 4 above) and reassemble, being sure to follow the wiring diagram and install wires to the correct terminals.
    2. To access the broil element located on the roof of the oven cavity, first open the oven and remove the oven racks. Remove the screws that secure the element to the oven, remove the holding brackets from the element and slide the element forward.
    3. There is normally a small amount of excess wiring attached to the terminals on the element that allow a little room for maneuverability (you may have to tilt the element to get the terminals through the holes). Look for loose or disconnected wires and if there is no sign of burning; reconnect the wiring to the back of the terminal. If a terminal end is damaged, replace it with a terminal end designed specifically for oven use only.
    4. To test the broil element, remove the wires from the broil element terminals by removing the screws from the terminal or pulling the wires off the broil element terminal. Remember to label the wires for reinstallation.
    6. Test the broiler element for continuity. Using the ohmmeter set the range scale on R x 1 and place the probes on the element terminals. There should be continuity, with readings ranging from 19 to 115 ohms, however readings will vary from manufacturer to manufacturer and according to unit size and the wattage, be sure to check your manual for the manufacturer's specifications.
    8. To test for a grounded broil element, place one probe on the element outer surface and the other on the element terminal as in the ground test for the baking element. If continuity exists, the element has shorted and should be replaced. Be sure to test both terminals.
    9. To test a dual broil element, remove the wires from their terminals. Using the ohmmeter, set the range on R x 1. Place the probes on terminals A and C to check for continuity, followed by terminals B and C. To test for a grounded element, place one probe on the element outer surface. With the other probe, touch terminal A, followed by B and then C. If continuity exists, the element has shorted and should be replaced.
    10. To install a new broil element, simply reverse the disassembly procedures and reassemble, being sure to follow the wiring diagram and install the wires to the correct terminals
    Oven Thermostat Testing:
    An oven thermostat is a switch that opens and closes in response to the temperature it senses. It is typically found in the control panel, where a liquid-filled temperature-sensing bulb senses and maintains the internal oven temperature by cycling heat on and off.
    2. Access the oven thermostat, which is located in different places depending on the make and model:
      1. On freestanding ranges, access the thermostat by removing the screws that hold the back panel in place at both ends.
      2. On models with front-loading controls, remove the panel and tilt it for access. Be careful not to let the wires disconnect from their components
      3. Some built-in models have a removable backsplash. Lift the backsplash, rest it on the cook top and remove the screws from the backsplash, which holds the rear panel.
      4. On wall ovens or eye-level ranges, access the control panel by opening the door and removing the screws that secure it. The screws may be under the exhaust hood or below the control panel. If the control panel is hinged, simply tilt it towards you.
      5. On some models both the rear and front control panels must be removed. The screws may be found on the trim and occasionally the trim must be removed.
    3. When testing the thermostat switch contacts for continuity refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced.
      Adjusting the thermostat:
    4. Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
    5. If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration.
    6. Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat.
    7. To remove the thermostat:
      1. Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire.
      2. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place.
      To install a new thermostat, reverse the disassembly procedures (Step 7 above), transferring the wires individually from the old unit to the new.
    Oven Selector Dial Testing:
    In order to test the oven selector dial on your electric range, the following steps should be taken:
    2. In order to gain access to the oven selector dial, first move the range away from the wall and remove the back cover panel by undoing the retaining screws. This will expose the back of the oven selector dial.
      Note: There are many styles of ranges. If this does not describe your range, refer to your owner's manual for instructions on gaining access to your oven selector dial.
    3. Now you can begin to test each pair of switch contacts for continuity with your VOM. Using the ohmmeter function, set the range scale to R x 1, and touch one test lead to each terminal of the switch contacts to be tested. There will be several pairs of contacts, one pair for each setting (eg. broil, bake, etc.). Refer carefully to your wiring diagram (often placed on the inside of the access panel) when testing. It is a good idea to label the wires as you test and only remove one pair of wires at a time. If there is no continuity between any pair of contacts, the switch is defective and must be replaced.
    4. To install a new oven selector dial switch, remove the old switch from the control panel by undoing the nut or screws holding the switch in place, leaving all wires attached. Transfer the wires one at a time from the old switch to the correct terminal of the new switch. Check your wiring diagram to make sure all wires are on the correct terminals. Now mount the new switch to the back of the control panel and replace the cover.
    hope this helps goodluck and merry xmas
    Genius:
  • 1,550 Answers
Your thermostat is not working properly also check whether door is closing properly .
  • SAM ANDERSON Dec 24, 2008
    Your oven sensor is bad . Yo can get one from the link below
    Sensor for maytag
    You need to replace it . If your problem still continues it indicates that you need to replace the thermostat part in your oven
Oven not working properly
Do you mean 200 degrees Celcius or Farenheit? If Farenheit then the most likely culprit would be the thermocouple in the oven which can usually be replaced relatively easily by someone mechanically minded, if Celsius then you should suspect the elements although a working broiler would suggest that there is at least one element that works fine. Maytag says; "Why won't the oven heat up? First, make sure you've properly set all the oven controls. Check your user's guide for more information on your model's controls.(see below for the link to the manual if you need it) If your range offers the option of a delayed oven start, check to see if it's been selected. If so, the oven won't begin to heat until the selected time. If your oven has a lockout feature, check to see if it's been selected. If so, it will prevent you from using the oven. If your oven still won't operate, please contact an authorized Maytag service provider for more assistance." Here is the link to the manual; http://www.maytag.com/assets/product/8113P564-60.PDF and here is the link to Maytag Service if you need it - hopefully not; http://www.maytag.com/support/service_parts.jsp The other possible culprit would be the electrical supply to the oven - it may be adequate for the stovetop or grill but the oven may draw more power than the circuit can handle - even if it was fine before, this can change and may be caused by corrosion, rodents, overloading etc. and may not necessarily trip the breaker switch - if you suspect this at all then get a qualified electrician to check - it shouldn't take long to check so should be cheap, although repairs if necessary may cost more Hope this helps :)
Jun 21, 2007 | Maytag MER5555Q Electric Kitchen Range
Bad ignitor? I have a Maytag oven CRG9800BAE displaying F7. No oven heat. Stovetop burners work fine. Got the code cleared, clock is working fine. Is this a bad ignitor? If so, could you confirm the...
Thanks for choosing FixYa and welcome. If you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defetive heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
May 12, 2011 | Maytag Ovens
Over will not heat up beyond 175F, according to temp display enven when high temp selected. When Self cleaning selected oven does not heat up ,
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 07, 2011 | Maytag MER5875QAS Electric Kitchen Range
Bottom oven heats VERY slowly. Whay could be the cause?
heatman101
Dec 25, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Oven is not heating properly
heatman101
Dec 18, 2010 | Maytag MEW5530D Electric Single Oven
Oven not working bottom element not working top on broil works ok
heatman101
Sep 05, 2010 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Oven heats very slowly
If your top burners work ok, regulator should be ok. Majority of times the fail part in the oven is the ignitor...turn oven on and check for a flame after 10 mins. small flame could mean a bad safety valve.
Jun 09, 2009 | Maytag MGR5870 Gas Kitchen Range
Electric oven does not heat up enough
I had the same problem before the warranty expired. The heating element had exploded and there was white powder all over the inside of the oven. They replaced the heating element and it works as it should, however, this oven has never baked right. It gets hotter on the right hand side than it does the left and I have to constantly watch whatever I bake. I'm not very happy with this oven.
Apr 27, 2007 | Maytag MER5755QAS CleanDesign Electric...
Open Questions:
Maytag MGR5875QD CleanDesign Gas Kitchen Range Logo
522 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
