Question about Vizio L37 Television
No picture i dropped the remote and now i have no picture, i can get the tv guide menu so i know that it is something with the remote...help
  • Vizio Master
  • 5,568 Answers
Go thru the menu and make sure that dropping the remote didn't misset the choice of signal input; antenna, cable, etc.
Posted on Dec 24, 2008
I have a blue light and an orange but my tv will not come on
If you are referring to an R15 (the big box in the picture with your post), there should be 3 blue lights on the front of the DVR: one to the far left (power), a big circle in the middle, and one on the right indicating the resolution the DVR is currently trying to send to the TV. The orange light indicates that something is being recorded; either a show or something from DTV like channel listings. The orange light has nothing to do with your TV but may indicate that the DVR is downloading setup information.
As for turning your TV on, when you first get DTV, the DVR remote does not know how to talk to your TV set, only the DVR, so you have to teach the remote to talk to your TV. To do that, turn your TV on with the remote that came with it (or the on/off switch on the TV if you're a dinosaur like me) and change the TV input to whatever input the DVR is attached to - usually HDMI or Component. If you see something (a TV show, a guide, a DirecTV logo, etc.) you're in the right place. Now hit the Menu button on the DTV remote and you'll see a menu on the left that includes "Setup". Use the arrow buttons on the DTV remote to move to Setup, press Select, and then select Program Remote. Follow those instructions carefully, step by step, and you should be all set. (Caveat: I am working from memory so the exact wording might not match and I might have missed a menu level. If so, I apologize.)
May 27, 2014 | Directv Plus DVR DTV Receiver / 100-Hours...
I'm trying to find or download your user guide....but in the meantime, I would like to know how to get the picture to be full screen on my new insignia 32" tv??? Thank you.
check the remote and menu for format options. the remote may have a button that says "format" "size" "aspect" "wide" the tv menu will have an option to change the size in either the picture settings or something like that.
Jan 06, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Nov 21, 2008 | Zenith DBZN-311 Remote Control
Zenith tv model # H27H38DT
You can get the installation guide for a Zenith H27H38DT free at the following location. Look on page 36 to go into the VIDEO MENU and set PICTURE PREF to PRESET. That should restore the factory settings, so try that first. If you go into the actual Installer Menu on page 41, proceed with caution.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=cd7a9896391874248d179a4781a1ac71&q=Zenith+H27H38DT&e=1
Jul 26, 2008 | Televison & Video
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Mar 08, 2008 | Televison & Video
RCA TV f27422 TURN OFF THE GUIDE PLUS
Hello, I have had my TV for 3-4 years and have dealt with this stupid guide popping up for the last 2 when I got curious to see if it was something I wanted to use. FINALLY I came across a solution - so far so good but tomorrow it could be back? I did not have the option field some suggested to use. So saw another suggestion for something else and so far so good. When going into the setup guide. Select the USA, place all 0's in the zip code area and NO for everything else.... no VCR no cable, etc.
Hope this helps..
I also was able to do this without the remote - IF you can get the menu to pop up you just have to use the numbers to select what you need. Found the remote and saw nothing different as far as menu options. Good luck.
Jan 17, 2008 | RCA F27442 27" TV
Guide plus
can you let me know if you got help for this? the gude plus menu is blank and keeps popping up in the middle of a show for no reason. then the picture goes out behind it. the sound works ok though.
Jan 10, 2008 | RCA F32649 32" TV
My TV
go to picture in the menu drop... game ON OFF is first option
Dec 13, 2007 | Sylvania 6413TC 13" TV
RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Oct 27, 2007 | RCA F32450 32" TV
ESA TV
My screen shows only about 2 inches of picture, horizontally across the center of the TV
Sep 11, 2007 | ESA ET427E 27" TV
Vizio L37 Television Logo
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
