Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Repairman answer for F150?
Was it an electrical issue? What did it cost to fix? Was it worth fixing? Mine is actually a WTW6400STO.
  • 15,935 Answers
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Kia Sportage Compression Issue
hardly worth fixing at those prices
Oct 21, 2012 | 2001 Kia Sportage
120v Dyson DC41 plugged into 240V
You could take it to a Dyson repairer and get a quote.
I suspct it would not worth repairing and converting to 240 volts. Most likely the motor needs replacing and possible other electrical components.
Feb 03, 2012 | Dyson Vacuums
If it is head gasket problem how much does it cost to fix and is it worth fixing. a friend of mine checked it out and said all i need is a turbo rebuild kit and that should fix my problem
A turbo rebuild kit has absolutely nothing to with a head gasket. I don't know if you are planning on doing this job yourself, but a Volvo is a Swedish made car and the price for parts can get really expensive. If you are going to take it to a mechanic to get it fixed the labor alone will cost more than the part itself. Also when changing a head gasket you needto make sure that your head isn't cracked. I'm not sure of the year and condition of your vehicle, so I can't really tell you if it's worth fixing or not.
Mar 28, 2011 | Volvo 850 Cars & Trucks
My 1998 3.8 mustang has had some electrical problems for the past 2 years. (or so i think) When it comes to cars, I do not have the knowledge needed to diagnose problems and I do not want to be ripped off...
As for the A/C, Does the compressor not run or does the blower motor not work. Did they tell you it need a compressor relay or a relay module that runs the compressor?
May 17, 2010 | 1998 Ford Mustang
You click the trigger the saw starts only for a couple of seconds then runs out of juice.Local chainsaw out fit wont look at it .is worth repairing
the armature is heating up also the bearings could be bad.. on speculation actually you need a new electric chain saw. it will cost more to have that 1 fixed than what you paid for it...
Nov 13, 2009 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Black screen/wireless lan won't connect
Ok. I have this exact same laptop and the exact same issue except mine has actually failed. THIS LAPTOP WILL FAIL AND IT IS NOT YOUR FAULT. Go to hplies.com and you will see almost 2,000 users with the same issue. The problem lies with the nVIDIA GFX chip on the motherboard. THE ISSUE IS UNREPAIRABLE. Any repairs will force the laptop to fail again.
This issue has actually landed me in small claims court where I am suing for hte full cost of this laptop because not only is hte laptop defective, nVIDIA admitted it, and HP covered it up.
Join us at hplies.com and we will give you the know how to get this issue fixed/your $ back. We even have links to all of the information!
Nov 13, 2009 | HP Compaq Presario F500 F700 and G6000...
Campbell Hausfeld Air Compressor auto shut off switch not working
i have the same one and mine was broken by my kids , i had to replace the entire component, DONT RUN COMPRESSOR with out the regulator working IT CAN EXPLODE IF OVERFILLED,a must fix situation i believe i got mine from sears , a great unit ive used it painting and with many air tools over many years now , well worth fixing mine is a little loud but dependable good luck.
Mar 15, 2009 | Air Tools & Compressors
Creative Zen: Screen blank, but plays.
I have seen that problem with other Creative players including my old Zen Xtra 30GB. If it is less than 3 months old I would suggest sending it in for replacement. Creative's warranty period is only 90 days. If it is out of warranty, it may cost more to get it repaired or replaced than it is worth. Creative products are great but in recent years their support and warranty policies have gotten horrible and repair costs are usually not worth it.
When mine did that I put it away for a week or so and when I turned it on again, the display worked normally. It started acting up one other time, and I came to the conclusion that it was a heat issue causing my problem. Unfortunately it developed power issues and as I said, they wanted more to fix it after a year than it was worth and I opted for an iPod.
Cheers and best wishes.
Dec 31, 2008 | Creative Labs Zen Digital Media Player
LCD flickering / Purple/Green Photos
I'm sorry to tell you, your CCD its death, no human intenvention can fix it, you must replace it, when a CCD fails, it's literally death, you can not fix it, its a very delicated part, and the fail it's some kind of microscopic evaporation or filtration problem, I'm pretty sure that it has no fix. I spend the last year trying to fix mine, but with negative results.
Aug 17, 2008 | Fuji FinePix S7000 Digital Camera
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
74 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
