Question about Tascam 102 MKII Single Dual Cassette Deck
Tascam 102 mark 2 cassette
When i rewind the tape, it locks up when i press play.then i cant eject the cassette. i hear clicking like it was to start playing. i power off the cassette unit, once sometimes twice and it free's up the cassette so i can now eject the tape. what could be wrong?????????????
  • 68 Answers
There is a mechanical problem in your tape deck. probably a losen rubber band. it clicks because the rubber is too lose to move the mechinal parts. so when you power off, it losen the whole machanical parts..it is very easy to replace..opend the deck and check it out..good luck
Posted on Apr 15, 2007
Harmon kardon dc520
Dual cassette deck are often poorly built and full of problem with age. They are typically not worth repair. Get a good deck like the Tascam 122 Mk II as these can be repairs.
I have consulted with clients that have dual decks and the cost to repair will get you a Tascam 122 Mk II in restored condition and it works much much better. I should know as I have been repairing decks for 40 years so far.
Sep 20, 2016 | Audio Players & Recorders
How to play cassette
Hi Louise Siegel
By using the a standard Cassette Player
  1. Open the tape compartment door by pressing the eject key, usually far to the right and marked with a raised square.
  2. Insert the cassette, label side up, with the tape edge facing out.
  3. Press and lock down the play key (green with a raised circle / triangle) to start the player.
May 22, 2016 | Audio Players & Recorders
Tascam 302 Tape Deck - When I press play it rewind/fastfoward
There is either a cam belt that is lose or the flywheel assist can not move the head base due to hardened grease. It needs to be serviced.
May 16, 2013 | Tascam 302 PRO DUAL CASSETTE DECK Single...
Need belts for tascam 102 mk2 cassette player
This is easy to take care of just contact Marrs Communications and select the
Supreme" CASSETTE KIT $19.95
http://marrscommunications.com/tascam-cassette-kits
Oct 11, 2011 | Tascam 102 MKII Single Dual Cassette Deck
I've a Mitsubishi HS-U770 that has not been used for several years. When I tried to use it today, the tape loaded but would not play, rewind, or fast forward (I hear what sounds like gears slipping). The...
Mine did that, and when I opened it I found that a small drive belt (visible from the bottom with the cover removed) had deteriorated into goo. This unit had been in storage a while and the rubber just deteriorated, I guess. The trouble is that now I cant tell what size it is, or what length. I think this belt drives the mechanism that loads the tape in and out, and the rest of the mechanism is triggered by the tape cassette moving into position. Since it cant get loaded properly, the rest of the machine doesnt work right, either.
Jan 17, 2011 | Mitsubishi HS-U770 S-VHS VCR
Unit accepted cassette, won't eject
check the tips in my profile
May 10, 2010 | Sony EVC100 Hi8 VCR
It is likely that either the drive belt has broken or is slipping. Because the unit is still in "play" mode, the mechanism won't let the door open up. If you have not opened up these units before, do not attempt it now. This unit should be taken to an experienced tech for repair. Where are you located?
Dan
Apr 08, 2010 | Sony EVC100 Hi8 VCR
Ford cassette rewinds a couple of times then
clean the pinch roller for the tape
Sep 14, 2009 | 1999 Mercury Sable
VCR ejecting my cassettes
Try removing the top cover & have a look to see what happens when you put the tape in & press play/rewind etc. Is the take up spool (right hand spool) turning properly or is there slack tape not being taken into the cassette? Are the heads spinning ? I think your problem is more likely to do with the tape not travelling smoothly around the tape path. Possibly the clutch gears need cleaned or the soft brakes may not be dis-engaging properly.
Jul 19, 2009 | Televison & Video
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
592 people viewed this question
Top Tascam Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
