Question about Nespresso Aeroccino Automatic Milk Frother
Brand New Nespresso Essenza just stopped working..
I purchased a new Nespresso Autmatica yesterday, it worked perfectly for the first two cups of coffee and this morning it refuses to produce any coffee. The machine turns on, goes through the usual routine of flashing lights etc then they stop as if to show it's ready. When I place a capsule in and press the cup sign nothing happens, it flashes for a few seconds and then stops. No noise nothing...... HELP?????
  • Anonymous Mar 16, 2014
    we inserted the capsule, pushed down the arm. No coffee, no buzzing sound, just a low hum. Tried to put the arm up to adjust the capsule and it is totally STUCK! Can we get into the capsule area from below if we turn it upside down? We can't really see it or feel the capsule though.
  • 333 Answers
If you just bought it you should return it immediately and try another.
Posted on Dec 24, 2008
Why too little coffee
The machine is calibrated to produce a certain amount of water depending on which button is pressed (Lungo or expresso - larger or smaller cup). This can be altered by holding down the relevant button - check this manual..
http://www-media.nespresso.com/ecom/websites/manuals/inissia/inissia_C_krups.pdf
Aug 23, 2014 | Nespresso Inissia
Nespresso leaks coffee in capsule tray
check the gaskets or orings for cracks and replace if they look bad .perhaps a little lubricant is needed
Mar 19, 2013 | Coffee Makers & Espresso Machines
Nespresso pixie c60 cup stuck
Can't make the coffee and can't open the lever of pixie nespresso machine
Feb 10, 2013 | Nespresso C60 Pixie Electric Titan Single...
Where to buy replacement water tank for Nespresso Essenza C100
I need to find a replacement water tank for my nespresso essenza C100 coffee machine. Mine broke, any ideas where I might be able to find one?
Jan 12, 2013 | Nespresso Essenza C100 Espresso...
WHEN SWITCHED OFF, WATER LEAKS AT THE BASE OF NESPRESSO C100 MACHINE
I opened mine when this did this - it also happened to my second Magimix Nespresso Manual machine. A short pipe carrying pressurized water had burst. I called Nespresso . parts were not available and they offered me a new half-price machine. We are talking a 4 inch piece of plastic tubing here. Shame on you Nespresso for encouraging me to throw what is otherwise a fine machine....
Nov 14, 2010 | Nespresso Essenza C100 Espresso...
Will not dispense the water into the cup when the button is pushed
I have had this issue. First, check to make sure water tank is filled and correctly in place? Try descaling it; a kit came with coffee maker. (It just removes hard water build up, it may be blocking your water flow.) If that is not the issue, pull the tray where the used pods are dropped -Is it wet? Like the coffee is pouring into this tray rather than in your cup? If so, I have removed round silver plastic piece from around coffee spout,(gentle -do not crack it) then removed and washed the black spout, I even used a toothpick once, to remove the stubborn coffee ground, Once it was cleaned - it worked perfect. If you run water from the faucet into spout it should flow smoothly. I warn you though, not sure what this does to any warranty, but don't mess with my morning coffee! If the POD tray is not wet, I would tell you not that most likely your machine is not clogged by grounds, so you may not want to take snout apart. I hope this helps.
May 02, 2010 | Nespresso Essenza C100 Espresso...
Small and large cup lights won't stop flashing
Tish3030 response worked PERFECTLY. Thank you, Tish.
Apr 19, 2010 | Nespresso Essenza C100 Espresso...
Water not coming through nozzle of nespresso essenza
I have had this issue. I have removed round silver plastic piece from around coffee spout,(gently -do not crack it) I then removed and washed the black spout, I even used a toothpick once, to remove the stubborn coffee ground, Once it was cleaned - it worked perfect. If you run water from the faucet into spout it should flow smoothly. I warn you though, not sure what this does to any warranty, but don't mess with my morning coffee! I hope this helps.
Jan 09, 2010 | Nespresso Essenza C100 Espresso...
Nespresso Aeroccino Automatic Milk Frother Logo
1,247 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
