Question about SanDisk Sansa e250 MP3 Player
Sansa mp3 player could not detect micro sd add on card
Iam using SANSA (sandisk mp3 player) with 2 gb capacity.It has provision to insert micro SD add on card to extend the memory.I tried inserting 1 gb microsd card but the mp3 player could not detect it and it still reflects the same size it initially had.Please let me know the steps to make it detect the add on memory card.
Thanks
Kaartikraaj
  • 1 more comment
  • greenbren66 Dec 24, 2008
    using sansa 240 can not figure out how to get micro chip 1 gig to get recognized
  • csscllc Dec 25, 2008
    Inserted memory card and e250 does not recognise it, so no extra memory, how do I solve this?
  • Anonymous Mar 28, 2009
    facing same problem, any solution?
    Welcome Back:
    Visited the website for 2 consecutive days.
I believe you can fix it by going on the player, then to settings, then to USB mode, and switching it from MTP to MSC. If you're in MSC already and it fails to recognize, then I don't know. :(
Posted on Dec 30, 2008
2 Suggested Answers
SOURCE: sansa mp3 player could not detect micro sd add on card
Ok so as was mentioned its a SDHC card. and a v1 player won't play it.
you have a "v1" is your firmware starts with 01.xx.xx.xxx etc
to fix this you can "rockbox" your e260 (www.rockbox.org)
it makes the player much much better imo as well as allow it to read 8 gb sd cards.
though i have to put it in my card reader to add files not sure why but my player does read and recognize the files so thats a plus.
Posted on Feb 17, 2009
Why is there no manual with my sansa fuze
For the Sansa Fuze there's a manual available in pdf format on the Sandisk support site:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Save this file to a location on your computer for later use.
When you explore "My Computer" the micro SD card with x GB memory, should be available as an extra external drive.
This drive will show up as an extra drive letter with a total capacity of x GB .
Apr 24, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
Installing Micro SD card to Sansa e260R
The Sansa e260 Rhapsody (e200R series) supports:
1. micro SD cards ( not the HC type )
2. micro SD cards up to 2 GB of memory capacity
See next site:
http://kb.sandisk.com/app/answers/detail/a_id/200/related/1
Jan 10, 2010 | SanDisk 4GB microSD High Capacity Memory...
How to Add 16G Micro sd card to Sansa c240 MP3 player?
is that mp3 player have the facility to add memmory card... then see in the side of the player their will an space given to insert that mcardf
Sep 02, 2009 | SanDisk Sansa c240 MP3 Player
Sandisk Sansa C250 won't recognize 8Gig micro chip
Your model doesn't natively support SD cards over 4GB, however I hear you can install something called "Rockbox," it's a free third party firmware that allows you to dual boot between "Rockbox" and the Sansa firmware. "Rockbox" adds the support you need for SD cards with a capacity of 4GB or more. I've never used this firmware, but it does sound promising.
Download it here
Sorry I couldn't be more help.
Jun 03, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
I have a sansa e260, 4gb capacity, that has a spot for micro sd mini chips. I recently puchased a 4gb mini sd ghip that is 4 gb and loaded it up with about 3.89 gb of music and the sansa will not detect...
The Sansa, in common with many devices which have been around for a while, will only recognize standard micro SD up to 2 GB, not the SDHC (High Capacity) variety.
Feb 18, 2009 | SanDisk Sansa e260 MP3 Player
Can 8GB micro SD be use in SanDisk Fuze 4GB mp3 player?
In order to use an 8gb micro sd, the device has to be SDHC approved. If you don't see an SDHC (Secure Digital High Capacity) logo on the device or on the owners manual, It isn't compatible. It will read up to a 2 gb micro sd card.
Dec 10, 2008 | SanDisk Sansa MP3 Player
Adding a 8GB MICRO SD card to the Sansa e260
I read somewhere that a 4 GB Micro SD card is the largest you can put in the SanDisk Sansa E260 expansion slot. It's maximum capacity is 8 GB, with internal + external memory put together. This is from what I've read. Hope this helps.
Sep 20, 2008 | SanDisk Sansa e260 MP3 Player
Anything over 4GB is a Micro SDHC card, not a Micro SD card. It is a completely different type of card format on the inside, and despite the compatible size and shape, it will not work on devices labeled only as Micro SD card compatible. The Sansa e200 and up (e250, e260, ect.) are NOT COMPATIBLE WITH MICRO SDHC CARDS (Micro SD cards that exceed 2GB in capacity).
Dec 16, 2007 | SanDisk Sansa e260 MP3 Player
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
748 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
