Question about GE WBSR3140DW Top Load Washer
Won't fill during rinse cycle
When my washer gets to the rinse cycle, the tub will not stop up to catch the water and the water just continues to run. One night it ran for over twelve hours!
    President:
  • 1,294 Answers
It keeps spinning or you just hear noises and it doesn't end cycle ? Following your description regarding water in tub when you start a new cycle,check for : * Switch level - The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will remove the cabinet, you will find it easily. Clear first any obstruction in the tube,In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react,you should replace it. * Pump and drain host - Check that pump works and that you have no blockage on your drain line. Good luck !! (courtesy dovi)
Posted on Apr 13, 2007
SOURCE:
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 26, 2011 | Maytag Washing Machines
GE Spacemaker Washer/Dryer. Model # DDPI380GAMWH. Water won't stop filling. It continues to fill during all cycles. Fills during agitation. Agitates inproperly. It agitates in short pulses as water...
Thanks for choosing FixYa and welcome. This sounds like a problem with the water level switch in the washer. It controls the amount of water entering the tub. It is probably defective. You may want tomake sure the switch is getting power first by testing the wires with a voltage meter.
Jun 18, 2011 | Washing Machines
No water during any cycle.
if no water is coming in how is it agitating?is it filling at the beginning,then it starts to wash the clothes,now does it drain and then it won't fill again,send the model number and more info,
Jul 02, 2010 | Kenmore 24032\24036 Top Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Stops during rinse cycle
Dear customer,
              We recommend the following when a washer's cycles dont advance..
  1. If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  2. If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  3. If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
For details on how to self test these parts plz refer to http://www.acmehowto.com/howto/appliance/washer/washer.php
Plz rate this solution.. thank you..
Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
GE WBSR3140DW Top Load Washer Logo
67 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
