I have model mer5765rab. When baking the oven will quit and the baking light will flash with no temp show. I have tried to clean the oven but it will quit and the bake light flashing again.
SOURCE: Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
SOURCE: oven will not stay on when baking regular none at all, convection have to set a couple of times
I had a similar problem when you turn the oven on it would shut off either on broil or bake,I tried switching the lock for the oven cleaner back and forth and now the oven works.
SOURCE: My oven's bake/broil element won't heat
It could be the stat (temp probe) or the cut outs. if these are faulty then it will not allow the elements to heat up
SOURCE: Kenmore electric range 790. Both the broil and
Kenmore oven 790.91072601, bake & broil not working, relays are cycling but no heat... Sounds like I have the same problem but its the night before Thanksgiving and Iam in panic mode... I've orderd a new Temp Probe part # 316233902. did you ever get yours fixed
