Question about Ruud UBHC Air Conditioner
When my furnace goes to start the blower motor whines or sounds like it is having a hard time starting up? If you turn the blower wheel it seems to turn freely? Could it need a motor or a run capacitor? How can you tell which one? It is a UGDG-10EBR JR 100,000 BTU
  • 306 Answers
Motor is getting old. The start side of the motor is getting weak. I would replace the motor and when you do the capacitor is a good idea to change also. ken
Posted on Dec 24, 2008
Blower motor makes noise, but does not work goodman
its either a bad motor or bad capacitor if you try to spin the wheel by hand and it starts then its the capacitor
Dec 26, 2012 | Goodman Heating & Cooling
Rheem furnace had trouble blowing. blower replaced. capacitor replaced 3 times. fan still kicks on and off.
this is all on your inside unit??? Your blower motor has a capacitor? If so it sounds like you are using the wrong motor, the wrong capacitor, the wrong supply voltage or possibly even have the wrong transformer or it's not wired correctly on the primary side of transformer. any idea what the total external static pressure is on this machine, I'd be finding a different technician. best wishes!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 08, 2017 | Heating & Cooling
Furnace whines when a/c is on
Hello, sounds like the bearings are starting to go bad. You will have to change out the motor soon.
May 19, 2012 | Heating & Cooling
I have a carrier furnace and when my main blower starts up there is a short vibration just when the blower starts though and it doesn't seem to be getting any worse. the flame fires up ok and there doesn't...
I would remove both burner and blower compartment covers and reach into the blower housing and grip the center section of blower where it mounts to motor shaft. Try sliding the squirrel cage back and forth horzontally. If it slids much more than 1/8 inch then the motor bearing are probably just getting worn and allowing the motor tomake some extra noise when motor starts. If it has oil ports I would remove plugs and use 3-4 drops of machine oil and clean blower with brush and shop vac.
Other then that I don't think I'd worry much about it yet. Thank you and hope that helps.
Dec 13, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have a Lennox Pulse furnace. It's making a
The bearings are bad. You need to replace the motor. Motor cost $75 to $125. Labor is on avg. $150 to $400 with an decent A/C Company . You can try to oil it but its not recommend by Lennox. That furnace at the time they build it was top of the line. Good Luck.
Oct 14, 2009 | Heating & Cooling
Inducer Fan Seems To Be Rattling
what make of furnace check for birds and blockage
unfortunatley when they go there gone the squirrel cage wheel will not come of shaft u will need motor n wheel or a "plug n play housing all in one"
Oct 05, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Knock Noise When Carrier Furance Starts Up
have the ac company check the actual blower wheel itself it may be slowly coming apart
Apr 20, 2009 | Carrier Heating & Cooling
Coleman forced air furnace blower
Rmove the two screws holding the blower in place and slide it out. With the power off, rotate the wheel and inspect for debris or an impingement. If everything turns easy, you have a bad motor or start capacitor. If you have rubbing, adjust the wheel. If the motor will not turn, replace it.
Dec 11, 2007 | Coleman Propane Forced Air Heater...
Ruud UBHC Air Conditioner Logo
122 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
