Question about Toshiba SDV-592 DVD Player / VCR Combo
DVD Picture jumps and freezes
My toshiba dvd/vhs combo SD-V592SU when a clean and scratch free dvd is put in it will play for a minute and then the picture starts jumping or freezes up. I cleaned the laser. I also tried adjusting the rails the laser rides up and down on. Is there a speacial whay to adjust those rails? If so Please how?? Also could it be the laser going bad? Thanks
    Top Expert:
  • Toshiba Master
  • 76,016 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Oct 07, 2017
  • 82 Answers
SOURCE: movie skips and freezes during play
CD and dvd disc cleaners will not solve the problem, a deeper and delicate cleaning procedure by cleaning the lens manually with an cotton swab is needed...
Although the quality of newer discs is to be discussed.
Posted on Dec 08, 2007
SOURCE: Toshiba SD 3960 DVD player
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
SOURCE: Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Posted on Jan 18, 2009
  • 3422 Answers
SOURCE: Toshiba DVD player says every DVD is a bad disk
HI,
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.see if the player tries to read the disc. Load a disc and listen.
Posted on Feb 10, 2009
  • 56 Answers
SOURCE: Just got this Toshiba DVR620KU and need to record
Good one!
Sounds like you are doing everything right. Only things I can think of are:
- Make sure the disc is a blank one.
- Try a different disc.
- Make sure the tape you are trying to dub is not encoded with Macrovision copyguarding. If it is a home-made recording then you are OK, but a factory recording on a store bought tape may cause some difficulties.
If you are still having troubles try a complete 15 minute reset by unplugging from the power source.
Posted on Apr 22, 2010
Samsung DVD-V3650 Combo Player ejects most videotapes without playing them
You can only compensate for minor scratches. As for the vcr side the rollers could be dirty or the brake worn out. The tensioner may be too sensitive as well. Basically the mechanism probably needs servicing.
Sep 06, 2016 | Samsung DVD-V3650 DVD Player/VCR
How do I program a RCA universal remote to my Toshiba SD-V392 vhs/dvd combo player
Turn on device , look up the code number for a Toshiba vhs/DVD combo then press setup and hold until it blinks then press device vhs/DVDs then enter code and press off button when device turns off it is programmed
Aug 29, 2015 | Toshiba Televison & Video
Can not play DVD made on Toshiba combo in computer
You might try downloading (free) VLC Media player; it has dealt with a variety of formats that others don't:
VLC download
If it works for you, comment back here (to this thread) for the benefit of others-
May 01, 2010 | Toshiba SD-V392 DVD Player/VCR
Picture "freeze up" during playback
your laser lens is probly dirty ;/ just use a qtips and alcool and gently clean the lens if it not work proper ly may be your laser assembly going out...
hope that will help you....
Apr 20, 2010 | Toshiba SD-3750 DVD Player
Panasonic DVD VHS combo DMR-EZ48V will not play region 1 dvd
This is happening because your DVD is NOT all region, you need to change the Code.
en.wikipedia.org/wiki/DVD_region_code -
www.dvdexploder.com/ -
www.dvdexploder.com/multihacks.htm
www.allformp3.com/dvd-copy.../dvd-region-code- free.htm -
www.dvd.reviewer.co.uk/info/multiregion/ -
Ok check those links out they will help you sort it.
Apr 01, 2010 | Panasonic DMR-ES40VS DVD Recorder/VCR
SD-V592SU: static noise
That's a stumper.
Personally, I have a simular unit and I just leave it on all the time.
Other than that, borrow a DVD or VCR or combo from a friend and see if it does the same thing. At least you can narrow it down to the combo player or the TV.
Dec 26, 2007 | Toshiba SD-V392 DVD Player/VCR
Toshiba SDV-592 DVD Player / VCR Combo Logo
112 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
