Question about Oster 5834 ExpressBake Bread Maker
Won't Start I gought this for my mom and after she put everything in it wouldn't start. Any ideas?
  • Sarad789 Dec 27, 2008
    The exact same thing happened to me. The machine was purchased at a yard sale, and was used once without trouble. However, the next time I tried to use it, it simply refused to start. The controls functioned -- all the settings could be entered -- but nothing happened (except a beep) when "Start" was pushed.
  • 3 Answers
I wrote to Sunbeam customer service and received this response:
"Breadmaker model 5890 has a 30-minute delay cycle on the Wheat setting. This allows for a period at the beginning of the cycle to “soften” the ingredients for better results. During the first 30 minutes, the machine does not do anything."
Apparently, this is by design in many machines.
Posted on Feb 26, 2009
Have a 1999 yamaha 1200 xl wave runner when try to start nothing happens except start button lights up
Mine was doing the same thing it was the starter solenoid,may also be the starter if the motor does not crank over
Jun 11, 2013 | Water Sport
Murray m2500 won't start after one day of having it
bad coil in it, i had bought a m2500 murray weedeater from walmart .did same thing i replaced the coil. bad when you buy something from wal mart and have to get it fixxed before you can use it. now it works fine
Apr 23, 2013 | Cars & Trucks
2003 Goldwing won't start...just one click when start button pushed
you may have blown the starter solenoid or even worst the starter motor
i cannot diagnose without seeing the bike properly
i strongly suggest you put in a workshop and get it diagnosed properly
Apr 12, 2013 | 2003 Honda GL 1800 Gold Wing
Ford 500 transmission problems
LOCAL MECHANIC sounds like the linkage got bent perhaps
Dec 14, 2017 | 2007 Ford Five Hundred Limited Sedan
Yz 250 won't start
HiStart by taking apart the carburetor, replacing the gasket and cleaning it. Then change the spark plug and put fresh gas in. The air filter wouldn't be a bad idea either but you can look at it and tell if you need that. If it doesn't start after that, find someone that can help you troubleshoot.
Hope this works
Feb 23, 2012 | Motorcycles
HOW TO INSTALL STARTER ON A 97 FORD THUNDERBIRD
I'm not sure that your starter is in good condition .You have to pull your starter out from engine .
Ensure the safety dental starter and the engine .
If you find that the dental starter Moving north and right .
You have to replace the starter .
good luck , and let me know .............
Nov 02, 2011 | Cars & Trucks
Husqvarna Model 51 won't start. Was running fine and has never had a problem starting (owned since new, 14+ years). Chain slipped off. Fixed and then saw wouldn't start. Good bright spark &...
If you have a good spark, and there is fuel at the plug, the only things to stop it fireing up are a sheared flywheel key knocking the timeing out, or the engine has low compression due to wear or damaged piston and ring.
Sep 07, 2011 | Garden
I was putting in a new car stereo and when I went to start my car it wouldn't start. I got a jump start from a friend and that did nothing as well. I did hear a little zap when I put in the stereo...
check it out with a multimeter ,but i think your jump leads may not be any good and you have just flattened the battery ,but check the big fuses in the power distribution box under the bonnet
Aug 01, 2011 | 1991 Volkswagen Passat
Hello. My 1997 Chevy Tahoe refuses to start. The problems began with a bad fuel pump. I changed. It worked. The fuel pump died again. I changed it again and it has been working. I parked it for two weeks....
Now you have a good battery & a starter that turns over the motor
Have you cycled the key on & off with a fuel pressure gauge on the
fuel rail?
Do you have a fuel filter that isn't over 3 or 4 years old?
Have you checked for spark while cranking ? Use an old plug on the wires,
if you have ignition wires,don't ground the wire without resistance
If you removed the ducting & MAF Sensor it won't start
Tell us what you checked & exactly how that was done.
Jun 09, 2011 | 1997 Chevrolet Tahoe
Oster 5834 ExpressBake Bread Maker Logo
85 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
