I got a system from a friend of mine that appears to be in great shape however, when I hooked it up I can barely hear the sound out of the speakers. I tested the speakers with another system and they were fine. If I crank the volume up to 'full blast' I can hear it but faintly. Its like standing next to someone who has ear buds in and the volume is too high, you can hear the tinny overflow but its not really music.
I looked for something that would look like a fuse or switch on the outside of the case but nothing. I pressed the help/reset button and the text says system is operating correctly.
Any advice is appreciated. I have it connected to a tuner and a cd player and the result is the same regardless of the source.
You may have the tape monitor button pushed in or if you look on the back of the unit you may find a pre-out/main-in set of rca jacks. If you don't have a switch to bypass those jacks then you will need to use a set of 2 RCA jumper cables or some stubs made for that purpose. Hope this helps.
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on I can barely hear output even when the volume is at 100%:
Solution #2
posted on Aug 12, 2007
Guest
Rank: Apprentice Rating: 0%, 0 votes
I know exactly what this problem is, you have a dry joint inside. I get exactly this problem every couple of years, I take it to a repair centre and its back and working in a day or two.
