Question about SanDisk Sansa e260 MP3 Player
My sansa e260 wont work
I have had my player for a couple of months and worked just fine until today all the sunndun when i tryed to turn it on it shows the sandisk part and fads away to a white screen and does this over and over and wont go the the menu screen
  • ekinchen Oct 16, 2008
    i had my sansa device for about a year now. everytime i cut it on, it says refresh data. then it jumps to a blink screen.
Mine did that too, i had to put it in recoverymode, by locking it n holding down the "record" and "on" button at the same time n then pluging it in, n then reformat it...which bascially deletes all ur files on ur mp3player and u just have to reload thm all on ther again, its a pain i know
Posted on Sep 05, 2007
Maybe your battery is bad, not holding a charge
Posted on Apr 13, 2007
SOURCE:
My computer wont recognize my USB
Try the following steps:
Resetting the device:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
NOTE: Resetting will turn the player off while it is frozen.
If that doesn't work, then you may download and install the Sansa Firmware Updater and update to the latest firmware.
Jun 04, 2009 | SanDisk Sansa e260 MP3 Player
No sound, just clicking
try recovery mode. to do this just connect it to your computer and push the hold button so the orange is showing. next push and hold the record button and the power button. it should go into recovery mode.
Feb 10, 2008 | SanDisk Sansa e260 MP3 Player
Freezing
try turning it off, just push the power button down until it shuts off, then leave it off for a couple of hours. if that doesn't work, call geeksquad, i guess......
Jan 09, 2008 | SanDisk Sansa e260 MP3 Player
IT wont turn on
tyr holding both the power button and the play button for 20seconds at the sametime
Dec 28, 2007 | SanDisk Sansa e260 MP3 Player
E260 Won't detect my music
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Nov 29, 2007 | SanDisk Sansa e260 MP3 Player
Please help me!!! im desperate!!! sandisk sansa e260
if your sanas e260 does'n syncronize with your computer or say data base..., take the battery out and conect it with out the battery.
May 08, 2007 | SanDisk Sansa e260 MP3 Player
Help!
Media converter is for videos, not for music
May 19, 2007 | SanDisk Sansa e260 MP3 Player
Black screen blue ring
Try holding the Menu button for about 15 seconds.
Apr 01, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260 says connected but device not recognized
I agree with the above suggestion. Try setting the USB Mode under "Settings" on "MSC" on the Sansa. My computer would not recognize the e260 when the mode was set to "MTP"; works fine on "MSC".
Dec 27, 2006 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
