Question about Canon PIXMA iP4000R InkJet Printer
Canon ip4000r doesn't print 3ebk (black)
I have done everything: head cleaned, new ink inserted, head exchanged by a new one, but problem does still exist. anyone an idea? how can i reset the printer, perhaps this could be helpful...
  • Anonymous May 16, 2009
    Same problem here :(
    Tried everything...it still doesn't work!
    Problem Solver:
  • 5 Answers
First of all... have you tampered with the printer's firmware? If not, it's unlikely it became corrupted. But if replacing the ink cartridges with fresh ones, and using a new print head did not fix your problem, you may be out of luck.
Is this a new problem, or has it always been like this?
Could it be that the print driver is always printing photo? In that case, it uses the narrow black ink cartridge instead of the fat 3eBK cart. You should print a nozzle check pattern and verify that you see the 3eBK cartridge pattern. If you do, the problem is likely SOFTWARE... your driver settings, not the printer itself.
I hope this helps.
Posted on Feb 24, 2009
The printer is recognising that the Yellow is full but when I print out a test page the yellow doesn't print. Is this a printer or cartridge issue?
try to do deep head cleaning, few times. If this doesn't helps you need to remove the ink's and print head and bottom of print head ( where are ink nozzles ) few times press on wet cloath.
Then repeat the deep cleaning.
Aug 04, 2011 | Canon PIXMA iP4000R InkJet Printer
My black large black ink cartridge is not printing. (BcI-3ebk) I have done all the cleaning suggestions and put in a new cartridge. Still nothing..
Unfortunately you have a blocked defective printhead. You could try removing the ink cartridges, remove the head and then dip the tip of the head into hot water for a minute or two. Dry the head, re install and run cleaning cycle again.
This does not work very often. You probably will need a new printhead and they cost more than a new printer.
May 26, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
Main black print(BCI-3eBK)seems clogged and nozzle check shows only partial pattern. The cartridge seemed to be stuck to the print head. This happened before about two months ago. My technician cleaned it....
Sounds like you need a new printhead, and the only thing you need for cleaning is a damp cloth. All the Canon inks are water soluable. The printheads don't clean very well and don't last long if you do clean them.
Nov 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Hi, our black 3ebk will not print. we have deep
Check if there is a tape over the top vent intended to let air into the ink tank and so ink can flow out to the writing head.
Sep 27, 2009 | Canon PIXMA MP780 All-In-One InkJet...
3eBk will not print. Canon MP780
Replacing the printhead may work, but it could be a problem with the cleaning assembly. Take out the 3ebk and run a cleaning, if the ink goes away on the pad where the ink cart. goes, then clean assy. is OK, and you need a new printhead.
Jul 14, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Black ink 3eBk wont print
Ok what you need to do is make sure that the ink cartridge is properly inserted all the way. If it's not then you won't be able to print out black ink at all.
Jun 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
IP5000 3ebk problems
I had a similar problem. Pages in blue, but nozzle check in black. Tried what you tried. Changed the ink ($). Still no change. Then tried the maintenance option to clean the bottom plate. And now it is working. Go figure.
Apr 08, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
PIXMA MP780 printing trouble
If you haven't done so, I would try another new cartridge. It is entirely possible (and occurs frequently) that you got a bad cartridge. Assuming you removed the tape from the cartridge before putting it in, this is generally indicative of either a bad cartridge, bad print head, or that heads or ink tanks may need cleaning.
The Canon support page for this printer is at:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=10444
However, as Canon pages come up as generic pages (without the text I input for you), you will have to type in "missing black ink" (without quotes), to see the material they have posted in this regard. You will find instructions there in regard to how to clean the print heads, etc., if that is necessary. However, I would definitely try another cartridge first, especially if you haven't had that much use on the printer, such that you think these other measures may be necessary.
Please post back if you need further help, otherwise thanks for rating FixYa!
May 27, 2008 | Canon PIXMA MP780 All-In-One InkJet...
New printhead will only print 3eBK, no color
If you're concerned with a clogged printhead try to clean it with acetone solution. Also, check the cable connections to your printerheads they might be loosened..
Feb 23, 2008 | Canon i860 InkJet Photo Printer
Canon PIXMA iP4000R InkJet Printer Logo
322 people viewed this question
old marine
old marine
