LG RH177 DVD Recorder/HDD Recorder Logo
Anonymous Posted on Sep 07, 2012
How to do channel set up for LG recorder - LG RH177 DVD Recorder/HDD Recorder
Anonymous
Level 2:
Sergeant:
  • Expert 239 Answers
  • Posted on Sep 07, 2012
Anonymous
Expert
Level 2:
Sergeant:
Answers
239
Questions
0
Helped
64044
Points
730
This link has the manual: http://www.lg.com/uk/support-product/lg-RH177#
But I would look in menu for tools and look for set up and channels manual or auto.
How to do channel set up for LG recorder RH1777S
look in menu for set up for channels auto or manual...
1helpful
How to set up LG RH 387H HDD/DVD recorder for recording fron T.V
First, please note that your LG 387H is capable only of tuning analog channels, not the digital ones...
The easiest way is to connect your recorder directly to your incoming cable, then connect the output of your recorder to the TV set. Depending on what your set has available, either connect the HDMI OUT to HDMI IN on your set (best picture), or the A/V OUT to your sets A/V IN. Leave your set on the input you have selected, and use your recorder to change channels.
Can the LG 990W VHS VCR receive digital TV signal
VCR is analogue, However you can still use it to record digital programmes when connected via a digital set top box. You can only record the channel you have selected on the screen. In other words, you cannot record a channel programme while watching another channel. I use mine on a second TV and when recorded I take the tape out and put it into my main TV for viewing at a later date. I don't watch too much TV so it works fine for me for the odd programme.
The description for setting up the LG RC897T VCR/DVD recorder says to "tune the TV to the recorder output channel (3 or 4) and set the recorder channel selector to the cable output channel" - so where do...
it means that your tv has to be on channel 3 or 4 to use device. once your tv is on one of those channels, you should be able to program your dvd/vcr to record and check to see if there is a menu button on your controller. if it is a newer tv, try setting menu on component1, aux 1 or anything but tv..if there is a menu button on controller for dvd/vcr player select that once you see the home screen on tv...
Hi just got a LG dvd/vcr Model RC897T. I have it hocked up right, but i can't get it to switch over so that it would be seen on the TV. can you help
If a cable box is not required for cable signal reception, connect the cable line to the ANT. IN connector on the recorder.
If a cable box is required for cable signal reception, connect the cable line to the IN connector of the cable box. Connect a coaxial cable from the OUT connector of the cable box to the ANT. IN connector of the recorder.
To view or record a CATV channel:
  1. Tune the TV to the Recorder output channel (CH 3 or 4).
  2. Set the Recorder channel selector to the cable output channel. (Example: CH3).
  3. Select a channel using the cable converter.
With this connection, you cannot record one program while viewing another.If you are using a cable box to tune channels, it is not necessary to do Auto Channel Set.
Can't use timer setting to record Foxtel on LG RH397D
Are you trying to use video plus?try manual setting and in the channel space put av1
2answers
Can't record from camcorder to VHS tape on LG Model VCR
ok,uve gone OUT of cam and IN to VCR player?,then press play on cam and record on VCR,u should see whats recording as long as your on your normal video channel
2helpful
How to record digital tv thru reocrder
You need to go into the menu and set the "av-2 out put" to DTV, that should solve the problem, remembering to connect the "in" scart on the recorder to AV-2 on the tv.If there is only 1 scart on the recorder it will be a 2 way connection, sending and recieving a signal.
LG RC797T not showing broadcast digital
re setting the channel set up has worked with my machine. just have the recorder search for all channels. go to menu and set up.....
Feb 25, 2008 • LG RC797T
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
