It blows air fine most of the time and without warning cuts out and i can hear the fan barely turning. turn off motor and sometimes it will come on again, sometimes not?
Resistors are for reducing voltage to anything in an electrical circuit, and what you describe sounds like a motor that is giving out. When hot, it cuts out or quits working, but cools down and begins again. This is most likely due to the windings having shorted out somewhere in the windings. Some motors have a breaker switch located "inside" the motor casing.
SOURCE: Blower for AC/Heater stopped working
hi
my heater blower has stopped working all together i have checked all the fuses but do not no where the relays are for the heater.
SOURCE: AC not blowing cold air at times
poss causes are, sticking low pressure switch, defective Ac compressor clutch closing coil or incorrect clutch driven plate air gap, spec is 0.26 thousands.
SOURCE: 2000 Ford Expedition front air not blowing
TRY JUMPING THE BLOWER MOTOR APPLY 12 VOLTS TO THE MOTOR IF IT STARTS THEN THE PROBLEM WOULD BE THE SWITCH IF IT DOES NOT START THEN THE MOTOR IS THE PROBLEM GOOD LUCK HOPE THIS HELPS
SOURCE: No air blowing 1998 Ford E350
blower motor location is in the heater box down by the passengers feet the fan relay in out under the hood in the power fuse box check this first
check to see if the blower motor turns you can do this by removing the three screws the motor and squiral cage will come out spin it if it moves freely putit back replace the switch assembly
SOURCE: I HAVE A F150 AC BLOWER IS NOT WORKING
Does it blow the fuse if you unplug the blower motor. The motor might be shorted.
meant breaker fuse, not "switch" but if your motor had one it would blow and motor would not run anymore.
